HURST
Old 12-04-2012, 04:41 PM   #1
ace32x
ace32x's Avatar
Drives: 2013 ZL1
Belt slip with 9.1" lower pulley zl1
any way to counteract this? under hard pulls in 4th and 5th around 4500-5k rpm im getting some belt slip. anyone have any idea's on a solution? belt isnt to loose either its the correct size.
C6Z06 400ci, twin gen 2 promod 88's,th400, Alky car
ace32x is offline   Reply With Quote
Old 12-05-2012, 08:36 PM   #2
ZO6 Bryan
ZO6 Bryan's Avatar
Drives: 02 Z06, 95 Trans Am, 2012 ZL1
Sure it's belt slip. Has the boost control in the tune been upped to allow more boost without dumping it at 192 kPa?
Bryan 695 SAE RWHP 2012 ZL1 9.55 pulley custom cam and Kooks headers, 2002 Z06 447 RWHP, 2006 Trailblazer SS, 1995 S/C Vortech Trans Am 570 RWHP(for sale)
ZO6 Bryan is offline   Reply With Quote
Old 12-05-2012, 10:23 PM   #3
ace32x
ace32x's Avatar
Drives: 2013 ZL1
it has not its stock tune, i havent heard of anyone else running into that issue yet though so i didnt even consider it. i was just out driving though and it was holding 11-12 psi fine at 1/2 and 3/4 throttle. but when i floored it seemed like it slipped. it could very well be dumping it and rebuilding it though. whats the stock boost cut on these?
Old 12-05-2012, 10:48 PM   #4
hognutz
hognutz's Avatar
Drives: 2013 ZL1
Isn't that like 26 psi or so? With tha pulley his peak boost would be 11.5.
I think 11.5 psi might be pushing it on stock tune though. Ted was running 97 octane at 10.5 psi.
Do you have a datalog? Your positive it is not knock retard?
2017 zl1 or GT350 hmmmm
2015 Hellcat-sold
2013 ZL1 -sold
2013 Dart
2013 Megacab 8" lift 38"mt's
hognutz is offline   Reply With Quote
Old 12-05-2012, 11:34 PM   #5
ace32x
ace32x's Avatar
Drives: 2013 ZL1
don't have a datalog. and i bought it from ted and he said the 9.1 would be fine with 97 octane, im mixed to 100 to be safe
Old 12-06-2012, 01:23 AM   #6
69NMYSS
69NMYSS's Avatar
Drives: '69 Camaro SS and '12 ZL1
I thought you might have problems with the 9.1 as that's about 14% OD. I think you would be better off with the 8.86" which is 10% OD. All of Teds test were with the 10% OD pulley.
69NMYSS is offline   Reply With Quote
Old 12-06-2012, 01:38 AM   #7
ace32x
ace32x's Avatar
Drives: 2013 ZL1
I wanted the 10% but there was a mix up when I ordered my set up. May just go ahead and order the 8.6 ring aswell it's only 130 and then the belt for 50. Need to log this on the Dyno and narrow the issue down first
Old 12-06-2012, 01:40 AM   #8
69NMYSS
69NMYSS's Avatar
Does Metco not have an 8.86"?
Old 12-06-2012, 01:50 AM   #9
ace32x
ace32x's Avatar
Drives: 2013 ZL1
they have an 8.6" ring
Old 12-06-2012, 03:00 AM   #10
69NMYSS
69NMYSS's Avatar
Gotcha. So that would be 7.5% OD.
Old 12-06-2012, 03:07 AM   #11
69NMYSS
69NMYSS's Avatar
Actually, Ted was running close to 12psi with the 10% OD pulley, Roto-Fab intake, and Torco at 97 octane. He mentioned 10.5psi was all the stock tune could handle WITHOUT Torco to boost octane.
Old 12-06-2012, 09:51 AM   #12
Stephen12ZL1
Stephen12ZL1's Avatar
Drives: '17 ZL1 A10
I bet the way you described putting on the belt with help from other people that the belt is actually too short and the tensioner isn't doing its job. You should be able to push the belt onto one of the smooth idlers then release and let the tensioner take up the slack. Try a belt that is one size longer and I bet it fixes your issue.
'17 ZL1 A10 Mosaic Black PDR/Nav 2:08.35 VIR Full
'15 Z/28 #325 black a/c & stereo. 2:10.1 VIR Full 1:44.74 Summit Point Shenandoah Circuit (sold)
'12 ZL1 10.52@131 1.55 60' 2:13 VIR Full (sold)
Stephen12ZL1 is online now   Reply With Quote
Old 12-06-2012, 12:39 PM   #13
hognutz
hognutz's Avatar
Drives: 2013 ZL1
he has the rotofab as well though so he is pulled to 11.5 but most likely running 12.5 or so.
I could be wrong he is running 100 octane but it is another varible that was not tested originally.
I would double check the belt it should slip on and then be tentioned but I would also want to see 100% that I don't have knock retard.
a dyno pull even would just show whats going on.
2015 Hellcat-sold
2013 ZL1 -sold
2013 Dart
Old 12-06-2012, 12:55 PM   #14
ace32x
ace32x's Avatar
Drives: 2013 ZL1
yea i was suppose to run it last night but my friend had to run to pick some stuff up so we werent able to get it on his dyno. going to run it next week and see what the issue is. the belt did seem to tight as the tensioner is maxed out on it just to get it on
