Frankenstein Engine Dynamics
Old 12-06-2012, 12:37 PM   #15
ace32x
ace32x's Avatar
Drives: 2013 ZL1
Pic of the belt
ace32x is offline   Reply With Quote
Old 12-09-2012, 05:57 PM   #16
ace32x
ace32x's Avatar
Drives: 2013 ZL1
hmm i wonder if this has something to do with it. it says on the metco site that use of the 9.1 ring requires use of a smaller idler pulley. could be the contributing to my issue possibly? (currently it has clearence but is very tight)
http://www.metcomotorsports.com/prod...ankPulleyRings
C6Z06 400ci, twin gen 2 promod 88's,th400, Alky car
Old 12-09-2012, 08:24 PM   #17
Stephen12ZL1
Stephen12ZL1's Avatar
Drives: '17 ZL1 A10
Yeah...that is a good bet. At the very least get a 50mm lower idler for the stock bracket. I have a Lingenfelter relocation bracket and 76mm lower idler. Lingenfelter doesn't rx the 50mm idler. http://www.lingenfelter.com/mm5/merc...gory_Code=C412
'17 ZL1 A10 Mosaic Black PDR/Nav 2:09.68 VIR Full
'15 Z/28 #325 black a/c & stereo. 2:10.1 VIR Full 1:44.74 Summit Point Shenandoah Circuit (sold)
'12 ZL1 10.52@131 1.55 60' 2:13 VIR Full (sold)
Stephen12ZL1 is online now   Reply With Quote
Old 12-09-2012, 08:25 PM   #18
ace32x
ace32x's Avatar
Drives: 2013 ZL1
may just get the 8.6 ring and leave it be for now XD
Old 12-09-2012, 08:35 PM   #19
hognutz
hognutz's Avatar
Drives: 2013 ZL1
have you called ted Janetty or LPE or someboday yet??? I would try to talk to someone in person. the lingenfelter info I have seen list the 9.17 wtih everthing stock as acceptable. there is a section where they show they have another bracket you can run but it is not required until the 9.55 pulley.
2017 zl1 or GT350 hmmmm
2015 Hellcat-sold
2013 ZL1 -sold
2013 Dart
2013 Megacab 8" lift 38"mt's
hognutz is offline   Reply With Quote
Old 12-09-2012, 08:46 PM   #20
ace32x
ace32x's Avatar
Drives: 2013 ZL1
i bought the balancer and ring from jannetty and they never mentioned needing a smaller idler or a relocation bracket, stumbled across the 9.1 needing a smaller idler or a relocation when i was looking to order the 8.6" ring on the metco site. im not tuned im running the rotofab intake and torco. lingenfelter tested untuned to 9.17?
Old 12-09-2012, 10:50 PM   #21
Flavorwrench
Flavorwrench's Avatar
Drives: 2012 ZL1 & 67 RS-SS TwinTurbo
Always aim before pulling trigger!
http://weaponxmotorsports.myshopify....ng-mods-needed
Hope his helps.
Flavorwrench is offline   Reply With Quote
Old 12-09-2012, 11:19 PM   #22
ace32x
ace32x's Avatar
Drives: 2013 ZL1
Originally Posted by Flavorwrench View Post
possibly, i dont know if thats the issue tho, could be belt due to pulley or maybe knock retard XD i need to log it : /
Old 12-09-2012, 11:44 PM   #23
hognutz
hognutz's Avatar
Drives: 2013 ZL1
no they tune for 9.17 but it has the blower rpm and idler dia etc for the different dia pulleys. there info does not show it as required but I have not ordered yet. I am waiting till after x-mas just in case santa brings it to me ha ha.
2015 Hellcat-sold
2013 ZL1 -sold
2013 Dart
Old 12-10-2012, 12:36 AM   #24
ace32x
ace32x's Avatar
Drives: 2013 ZL1
thats weird metco does but lingenfelter doesnt, just going to get the 8.6 ring i think at see if the problem persists.
Old 12-10-2012, 05:13 AM   #25
Stephen12ZL1
Drives: '17 ZL1 A10
If you take a look at the side of the tensioner, there is a mark where the range of the tensioner needs to be. If you aren't in that marked range, you probably don't have the correct tension on the belt as per one of my comments above.
Old 12-10-2012, 11:35 AM   #26
ace32x
ace32x's Avatar
Drives: 2013 ZL1
took a look at it this morning and you were correct it is past the marks. For now i ordered the 50mm idler from metco and will throw that on and see if it eliminates the issue. will get it on the dyno after and get some logs and some power numbers to compare to stock aswell.
Old 12-10-2012, 12:00 PM   #27
Stephen12ZL1
Drives: '17 ZL1 A10
My bet is it will fix your problem as it will release the tension slightly and help your belt wrap at the same time.
Old 12-12-2012, 11:26 PM   #28
2012ZL1
CaRaHoLiC
2012ZL1's Avatar
Drives: '12 ZL1,67 Cam,68 Biscayne 427 4 sp
I'm running 18psi with no belt slip...
2012 ZL1
2.55 upper, 10" lower pullies, Innovators west billet hub and sfi balancer, solid blower drive isolator, 50 mm idler kit, full length S/S headers no cats, comp cams custom grind cam, comp roller rocker trunion kit, comp push rods,dual valve springs retainers and locks, Injector dynamics ID850 inectors, Rotofab ZL1 cold air kit, Lingenfelter 160 thermostat, Rotofab intercooler reservoir, stock plugs, LS7 90mm throttle body, GTO clutch reservoir mod, my own custom catch can, Tuning by Jannetty, install by me.
2012ZL1 is offline   Reply With Quote
