Caryle Racing
Old 06-08-2009, 07:27 PM   #1
Johnyoder
Johnyoder's Avatar
Drives: 2010 2SS RS M6 IOM
Any other LS3 owners have a bad vibration sound at 1500 RPMs
Hi Everyone, I have had my LS3 Camaro for just over a week now and at about 1500 RPMs I have a bad vibration sound coming from what sounds like the exhaust. Has anyone else had this problem? It happens in all gears at 1500 RPMs so about 63 MPH in 6th. Thanks, John
Johnyoder is offline   Reply With Quote
Old 06-08-2009, 07:31 PM   #2
Vash
Drives: 00 Blazer
Time to inspect the underbody. Exhaust, tranny and motor mounts and bolts.
If all that looks good then the wheels might also.. well.. let's just say it's hard / impossible to perfectly balance wheels with pressure sensors.
Old 06-08-2009, 07:33 PM   #3
Silverguardrail
Silverguardrail's Avatar
Drives: 2012 ZL1 #1448
Are there any heat shields ?
2012 ZL1 SIM, MN6, B92, RTQ
ZL1 - the true definition of joy ride
Silverguardrail is offline   Reply With Quote
Old 06-08-2009, 07:34 PM   #4
2010SSRS
2010SSRS's Avatar
Drives: 2000 Silverado
63mph in 6th gear????? wow. i have driven 75ish and haven't gotten outta 5th!
matter of fact, i haven't used 6th gear yet! i usually cruise with the rpm's about 2100 or so.
but no, no rattles here!
IOM 2SSRS LS3 R6P - VIN 7553 Delivered 5/22/2009 Kooks, Corsa and Roto-Fab - SOLD 9/2010
VR 2SSRS LS3 - Borla, SLP CAI
2010SSRS is offline   Reply With Quote
Old 06-08-2009, 07:35 PM   #5
Mr Twisty
Mr Twisty's Avatar
Do you feel it, or just hear it?
Mr Twisty is online now   Reply With Quote
Old 06-08-2009, 07:36 PM   #6
Kenny
Kenny's Avatar
Drives: 2010 SS RS IOM M6
If it's a sound and something you can't feel it's probably just the exhaust or a heat shield that needs to be adjusted.
I wouldn't worry too much but you should get it in to the dealer asap.
Delivered July 30 2009
Kenny is offline   Reply With Quote
Old 06-08-2009, 07:43 PM   #7
Johnyoder
Johnyoder's Avatar
Wow, thanks for the quick replies! I can't feel anything, it is just a real annoying vibration sound.
Old 06-08-2009, 07:48 PM   #8
Kenny
Kenny's Avatar
If the sound is there in neutral at 1500 get someone to push on the tail pipe with there shoe and see if the noise changes or goes away.
Old 06-08-2009, 07:50 PM   #9
jm88
RJT 2SS RS Auto -"Sookie"
jm88's Avatar
Drives: 13 BMW X6 50i - M Perf
Sympathetic vibration - something is most likely loose...
HOWEVER - I would still go to dealer and have them check.
jm88 is offline   Reply With Quote
Old 06-08-2009, 07:52 PM   #10
qbert48
qbert48's Avatar
Drives: 2SS SIM
agree sounds like a loose heat shield or may be a rubber out of a mounting bracket
2SS RS SIM gray leather stick shift ground FX
thank you gary richards @ classic chevy in sugarland
welcome home
1100 4-27-09
6000 6-27-09
yes i got to the dance late don't hate me
qbert48 is offline   Reply With Quote
Old 06-15-2009, 01:18 PM   #11
Embalmer
2G1FT1EWXA9103351
Embalmer's Avatar
Drives: 2SS RS, SIM, 6pd, 20"Alum
My dealer mechanic said it's a baffle inside the muffler that is rubbing against the outer wall. Apparently this needs to be replaced to correct the issue... I'm waiting to hear back from my dealer on this.
Embalmer is offline   Reply With Quote
Old 07-17-2009, 04:59 PM   #12
Mike's LazruSS
Drives: 2SS/RS, Black, CGM, Black int.
I am experiencing the same thing, just a subtle resonance around 1200 - 1400 rpm, notice it more at slow speed. It seems more noticable if I'm going just a little faster, and back down through that RPM range. A similar resonance at 72 - 74 mph on the freeway. My dealer, who is a great guy and has his own SS/RS, drove my car and says his feels the same. It's definitely in the exhaust, but so far the conclusion is that it's "normal." Anyone else? Thanks.
Mike's LazruSS is offline   Reply With Quote
Old 07-18-2009, 07:48 PM   #13
GLBL WMR
Booya
GLBL WMR's Avatar
Drives: Black 2010 2SS/RS
Jeez! I get into 6th around 60 cruising on the highway.
2010 Camaro SS/RS RP6 | 2SS package, M6, black, black leather
2000 Blazer LS | winter beater
GLBL WMR is offline   Reply With Quote
Old 07-19-2009, 11:57 PM   #14
cmgolfr212
cmgolfr212's Avatar
Drives: 2010 Camaro 2ss
I got the same thing on my exhaust. For me its right between 66-69 in 6th gear....pretty annoying since thats mainly what i'm driving around on the highway....o well. corsa here I come!
cmgolfr212 is offline   Reply With Quote
LS3 engine specifications Tran Wiki 3 10-06-2010 11:56 PM
LS3 Specs revealed: GM's 436hp Sick 6.2L LS3 TAG UR IT Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons 28 07-30-2009 07:02 PM
Check your Order here bvonscott Camaro Price | Ordering | Tracking | Dealers Discussions 665 06-29-2009 02:00 PM
To owners...how bad are the blind spots while driving? Ant 5th Gen Camaro SS LS LT General Discussions 52 05-25-2009 03:20 PM
Can a Superchagered Z28 have a lumpey CAM, and sound like a NA heads and cammed LS3 D-Unit Forced Induction - V8 12 07-29-2008 04:34 PM
