Solo Performance
Old 12-07-2012, 05:31 PM   #1
Just_Bill
Camaro newbie
Just_Bill's Avatar
Drives: Camaro
Smile LED footwell lights install
Hi all, new guy here, the name's Bill, just Bill.
I've been looking at all the great threads on here and you all have been very helpful. However there is one question I have that I don't seem clear on you all might be able to help with.
I just ordered 2 sets of LED lights from AAC to go under the dash to light up the footwell for a friend who has a 2011 Camaro. I want the lights to come on when you open the door, but also have the option to turn them off or on anytime the car is running.
I made a crude (very crude) picture that hopefully shows how I think you can do that. Basically I assume you can link the 2 light sets together by just tapping into one light set wires, right?
Then I would make a hot wire tapped in between the lights and included on/off switch to the grey wire that is the dome light. I saw that in another thread here. That way they will come on when the doors are opened.
Then I hook the end of the wires coming from the on/off switch to a fuse and ground. That way you can turn the lights on or off when the car is moving. Yet they still come on when doors are opened.
Does that sound like it would work right? Oh, the reason for 2 sets of lights is I want to put one set under the seats to show the back seat footwells. Or maybe string them up in the trunk.
Any advice is greatly appreciated, I'm doing this as a Christmas gift. Thanks!
Just_Bill is offline   Reply With Quote
Old 12-07-2012, 05:37 PM   #2
nycfury
Banned
Drives: 2013 ZL1 Crystal Red Tintcoat
PROBLEM is when u turn on the switch your gonna turn on your dome light
nycfury is offline   Reply With Quote
Old 12-07-2012, 05:38 PM   #3
nycfury
Banned
also your ground should go directly to the LED'S...
Old 12-07-2012, 05:42 PM   #4
Just_Bill
Camaro newbie
Just_Bill's Avatar
Drives: Camaro
Hmm, problems already with that then huh? Thanks, your right, the dome light will come on. Well others must have wanted these lights to do what I want, anyone know how? Thanks again for your fast reply.
Old 12-07-2012, 06:47 PM   #5
Just_Bill
Camaro newbie
Just_Bill's Avatar
Drives: Camaro
Actually what would work is putting in another on/off switch on the lead going to the dome light, adding the ground wire to that also. But then it gets more complex than someone might want, having to deal with two switches.
Old 12-07-2012, 08:14 PM   #6
Just_Bill
Camaro newbie
Just_Bill's Avatar
Drives: Camaro
Well after some more looking around I guess my question has been answered in this thread:
http://www.camaro5.com/forums/showthread.php?p=1224402
Seems like I need a relay switch to do what I want. You have to go a few pages into that thread to find it. Sorry for bothering anyone, I'll post some pics when I get it done.
Old 12-07-2012, 08:46 PM   #7
Mr_Draco
Mr_Draco's Avatar
Drives: 2SS/RS
What you want is this;
Old 12-07-2012, 09:39 PM   #8
2SSRS@Gen5diy
2SSRS@Gen5diy's Avatar
Drives: To many to list
You guys like to make it hard dont you. LOL
Old 12-07-2012, 10:21 PM   #9
Just_Bill
Camaro newbie
Just_Bill's Avatar
Drives: Camaro
Thanks Mr_Draco, that's exactly what I need. Now I can really see what I need to do. Sometimes I just need to see it written down in front of my face.
Old 12-08-2012, 09:14 PM   #10
overhaulengines
overhaulengines's Avatar
Drives: Red 2SS/RS M6
we all dont have the great mind and wisdom of the master mod monster
lupe
overhaulengines is offline   Reply With Quote
Old 12-12-2012, 11:55 AM   #11
Just_Bill
Camaro newbie
Just_Bill's Avatar
Drives: Camaro
Sorry to bump this back up but I have one more question.
When I hook up in the fuse box, what fuse should I use? That is what amp fuse,, 5, 10, 15 or what? I got one of those add-a-fuse things but have no idea what slot to use it in for footwell LED lights?
I'll take pics when I do this and post how I made both the dome light connection and fuse power connection so you can switch to whatever way you want to use.
Old 12-12-2012, 07:28 PM   #12
Gator6977
Gator6977's Avatar
Drives: 2011 2LT RS
Easiest fix is to throw in a diode and keep the current from going back to the dome light. Easy install. Also, I would highly recommend not using a tap on the gray dome light wire as it can cut through the tiny wire... mine did and separated about two months after install. I should have shaved the plastic coating and either soldered the connection or wrap the hell out of it. Otherwise it's a pretty straight forward install.
Gator6977 is offline   Reply With Quote
led lights, led lights in footwells
