Old 01-10-2013, 09:05 PM   #155
grocerygetter
instigator
grocerygetter's Avatar
I respect your perseverance.
-John S.
Thanks to:
Tony@ dv8motoring
TCAudio in Benton AR
Old 01-10-2013, 09:14 PM   #156
Alvin@PCMofNC
Drives: 2010 IOM RSS
Have you tried a new PCM yet? Being a Tune shop (our main focus) we've seen this a good number of times. Some pcm's are worse than others like the P12 but I have seen a handful of E38's and E67's do this and the only way to fix it is to get another.
Alvin@PCMofNC is offline   Reply With Quote
Old 01-10-2013, 11:26 PM   #157
QuickZoh6
Drives: 2006 ZO6
Poor Aeromotive and Autometer LOL. Seems like they were getting reamed before the problem was figured out for sure. I've always had great luck with both companies. I'm glad your issue was resolved though!
QuickZoh6 is offline   Reply With Quote
Old 01-11-2013, 04:34 PM   #158
MA2010SS
Drives: 2010 Camaro SS
Good to hear, no more 4000lb paper weight for you anymore
2010 Camaro SS Whipple SC, CAI Inc Intake, TSP 1 7/8" LT headers no cats, 3" magnaflow exhaust, HPT, RX Catch Can, LSR Toe Rods, LSR Trailing Arms, ALKY Control Meth, McLeod RXT Twin Disc, ZL1 fuel pump, 3.73 ZL1 Differential Kit, BTR PDS Stage 2 Cam, Tuned by SLOWHAWK Performance Bridgewater MA
MA2010SS is offline   Reply With Quote
Old 01-11-2013, 05:11 PM   #159
Unreal
Drives: 2006 Z06
Good to hear. Now go find the next issue.
Nick
Corvette Z06 -1200ish rwhp
Old 01-11-2013, 08:43 PM   #160
BullF-16
USAF retired! Thank God!
BullF-16's Avatar
Drives: 2011 1SS, 1LT red,1LT/RS SGM 98Z28
next issue is no fuel pressure with the key on....pump runs....no pressure....but prime the ALKY meth pump and Garth Vader fires right up. I have noticed that the pressure gauge takes a good 20 seconds plus to start registering 58psi at the Aeromotive regulator. Damn, its nice to have my car back!!!!!!!!!!!!!!
HKE LSX427(Mast blk lbl 305 6bolt LS7heads, PatG231/246 blower cam, RWHP/TQ: 1281/1133 SNL Performance Custom Twin PT6766 BB turbos 4 to 25psi selectable on the Boost Leash controller, Squash dual 400LPH/ID2000s, ALKY 4 gal meth, Autometer AFR/Bst/oilpres/oiltemp/fuelpress gauges, Pedders Justice road crs pkg: All HD bushes, supercar 12kg coil overs, supercar ZL1 sways, camber plates all setup by JusticePete! :Gforce 9" 35spline S-Trac, 1500hp Outlaw axles, 3.5"alum DS, Monster Triple disc; 4xForgeline 19x10.5 4xBridgestone 305/30R19 RE-11, CTS-v calipers/rotors/Cobalt friction XR1/3 pads
BullF-16 is offline   Reply With Quote
Old 01-11-2013, 09:02 PM   #161
Z_Rocks
Z_Rocks's Avatar
Drives: everyone crazy...
So which one you like better, the F-16 or your car?
Z_Rocks is offline   Reply With Quote
Old 01-11-2013, 09:20 PM   #162
G200 Pilot
G200 Pilot
G200 Pilot's Avatar
Drives: 2010 Camaro SS/RS purchased 5/2010
Happy for you Bull! How was it, when you got on it close to home? Are you planning on taking it to the track?
G200 Pilot is offline   Reply With Quote
Old 01-11-2013, 11:15 PM   #163
Jayrcr3
Jayrcr3's Avatar
Drives: 2011 IOM 2SS/RS
Glad to see your getting it worked out. I'm curious to. What's faster to 120, the falcon or your car?
Sent from my HTC One X using Tapatalk 2
American Racing 1 7/8" Headers and Hi-Flow Cats, CAI cold air intake, Flowmaster AT exhaust, Vengeance Racing Stage 2 cam, VMax ported throttle body, TEA valve springs and titanium retainers, Trick Flow hardened pushrods, 180* T-stat, Comp Trunion kit, ZL1 Fuel Pump, ADM Fuel Pump Control Module, 20% window tint, Whipple Supercharger. Tuned by Mike Norris Motorsports. 656rwhp/584rwtq @10 PSI.
Jayrcr3 is offline   Reply With Quote
Old 01-12-2013, 07:28 AM   #164
ADM PERFORMANCE
Drives: 2016 CAMARO SS
The car is still not working or it is?
ADM PERFORMANCE is offline   Reply With Quote
Old 01-12-2013, 09:20 AM   #165
Unreal
Drives: 2006 Z06
Sounds like it just needs to use the meth as a starting fluid. Not a big deal.
Where in DFW are you? Got a job interview Monday in Flower Mound.
Nick
Old 01-12-2013, 09:29 AM   #166
SRT10KLLR
Drives: 2010 Camaro 2SS/RS
I have the same issue but different company. Haven't had time to check for leaks so I just raised the priming fro the factory setting of 2 seconds to 10. Might need a chech valve on the feed line.
2005 Dodge Ram 2500 RCSB Thunder Road Hemi Sport w/STS Turbo
2004 Dodge Ram SRT-10 - Silver - Stock
2003 Chevy 1500 RCSB Stepside 400SS - 408 in now awaiting Turbo
SRT10KLLR is offline   Reply With Quote
Old 01-12-2013, 09:34 AM   #167
blake-b
blake-b's Avatar
Drives: Black 2010
The Squash pump setup has a built in check valve.
Old 01-12-2013, 11:35 AM   #168
BullF-16
BullF-16's Avatar
Car running great, its that after the car sits overnight i have to push the alky test button to get the car to fire up. After it has run it starts fine, just takes up to 10 seconds to get the fuel pressure up to 58 on the gauge on the regulator. I wonder if since it was tuned with the big Aeromotive eliminator pump that the start up fueling needs to be adjusted since i am now running a single walbro 400lph at startup now. Im not a tuner but i am wondering?
