Old 12-08-2012, 08:48 AM   #1
louque_ss2_2012
louque_ss2_2012's Avatar
Drives: 2012 camaro ss2 6speed
3.91 gears
will the 1le 2013 3.91 gear fit right into me 2012 ss? theyre on sale right now for 250 dont want to miss the deal
louque_ss2_2012 is offline   Reply With Quote
Old 12-08-2012, 08:59 AM   #2
RobertHarriSS
RobertHarriSS's Avatar
Drives: 2SS/RS M6
Yes.
RobertHarriSS is offline   Reply With Quote
Old 12-08-2012, 09:05 AM   #3
Rabamaro
Drives: 2010 ABM SS/RS
What all is needed to make this bolt in? Any install kits? I'm sure labor is still in the $600-$800 range.
Vararam Tune CAI, Vararam Power Wedge, 160 degree stat, VMax ported throttle body, Ceramic coated ARH 1 7/8" LTs with X-pipe, Borla S-Type Axle back, MGW short throw, 3.91s, Ported stock IM, BTR Stage IV cam, Heritage Grille, Backup camera, UMI Performance trailing arms and toe rods, dyno tune
Rabamaro is offline   Reply With Quote
Old 12-08-2012, 09:07 AM   #4
67motorcat
Blown Cool Breeze
67motorcat's Avatar
Drives: 2011 Black on Black 2SS M6
The GM 3.91 gears are going in my friends 2010 car today
A bunch of us are going to watch,get schooled and take notes from a professional.
I'm sure he will post it up the butt dyno results later
Had a 2010 IBM 2SS M6
Enjoy life.Think of all the women on the Titanic who passed up dessert.
67motorcat is offline   Reply With Quote
Old 12-08-2012, 09:56 AM   #5
JohnnyBfromPeoria
JohnnyBfromPeoria's Avatar
Drives: 2012 LS M6, Black
Surprisingly few parts. An install kit would need to include some seals, but not new bearings. Gear lube.
The skill part comes into play when the tech sets up the gear set. Through adjustments and or shims, the contact area in the R & P has to pattern just right or the rear end is going to be noisy and won't wear correctly. Likely the tech will paint the gear teeth with Prussian blue to analyze the contact pattern so it can be made right.
Labor seems about right, but I haven't torn one of these down, so I couldn't say for sure.
John B.
12 LS M6, IPF S/C, ASA GT-5 wheels, VMax PTB
1995 Mitsubishi Montero SR
1987 Dodge Raider Turbo Project
1986 Mitsubishi Montero 2.4l FI Transplant
JohnnyBfromPeoria is offline   Reply With Quote
Old 12-08-2012, 07:02 PM   #6
67motorcat
Blown Cool Breeze
67motorcat's Avatar
I'm sure my friend will post up when he finds this thread.
The install wasn't bad at all.The GM gears comes with ring gear bolts and a new crush sleeve.We didn't need any additional parts or a "install" kit.
The diff cover seal is a reusable O ring gasket to boot!
There were no shims to be found,just a machined spacer on each side and it went rite back in no problem.We reused the bearings as they were fine.
Just need a bearing puller and a press to press the bearing on the new pinion.
That's the only special tools really needed.Torqued up the new crush sleeve with the pinion nut till it bottomed out and viola,it spun perfect,then pinned it.
I was amazed the contact pattern was absolutely perfect also reusing everything put back in it's original location.
I'll bet this has a lot to do with the gears being OEM and the superior close CNC machining tolerances of the housing.
If the bearings were to be changed there might be more steps to get it rite,can't comment on that.
Back in the day it was a nightmare getting the correct pattern with aftermarket gears in the 10 or 12 bolts rear ends.
Don't know if we got lucky or what, but this was probably the easiest gear swap on the planet.
The GM 3.91 gears are definitely making there way into my car very soon
Old 12-08-2012, 08:49 PM   #7
Ucantctchme
Ucantctchme's Avatar
Drives: 2010 ss. 1990 RS the faster one.
I had shims available when I replaced my gears with 1le gears. They weren't needed though. This mod is by far the best 220$ I've spent on the car. I will be putting a cam in it over Christmas. Should be a Fun in the passing lane.
Ucantctchme is offline   Reply With Quote
Old 12-08-2012, 09:07 PM   #8
stikSS
9691 & 97586
stikSS's Avatar
Drives: '10 Camaro SS and 2LT
Well.... I just finished up everything on my car today including the gears. Like motorcat stated... the gear swap is beyond easy and if one has access to a press you're golden. I will post more on my install tonight or tomorrow.
In the short.... I can definitely tell the difference in first and second gear
Sent from Apple sued Galaxy Note 2
stikSS is offline   Reply With Quote
Old 12-08-2012, 10:22 PM   #9
Racecarguy
Drives: 2011 CGM vert
Recommend these for a A6 SS cammed? I'm thinking about them or the what are they 73's off the top of my head....
Racecarguy is offline   Reply With Quote
Old 12-08-2012, 10:57 PM   #10
Johnthegreat
Johnthegreat's Avatar
Drives: 2012 2SS/RS black camaro
Why does the auto get 3.73 vs 3.91 gears?
Johnthegreat is offline   Reply With Quote
Old 12-09-2012, 12:49 AM   #11
HubStep
HubStep's Avatar
Drives: 2010 Victory Red 2SS
and these are on sale where?
HubStep is offline   Reply With Quote
Old 12-09-2012, 08:44 AM   #12
67motorcat
Blown Cool Breeze
67motorcat's Avatar
Originally Posted by X3n0s52 View Post
and these on sale where?
Maureen has them for $248.00 shipped.
Parts Taxi for about the same as well as your local GM dealer.
Truly a remarkable deal for OEM parts
Old 12-09-2012, 10:09 AM   #13
ssmike
BliSSard has come!
ssmike's Avatar
Drives: '16 Camaro 2SS, '13 Equinox CRT
What does the crush sleeve look like? I don't think my gear set came with one. Got it from Maureen.
Old 12-09-2012, 10:19 AM   #14
67motorcat
Blown Cool Breeze
67motorcat's Avatar
It came with stikSS gear set.
