Old 12-08-2012, 10:35 AM   #1
Stephen12ZL1
Stephen12ZL1's Avatar
Drives: '17 ZL1 A10
New radiator! Mishimoto CSS-10
To combat the 240+ degree temps I saw at the road course in Nov, I decided to upgrade the radiator. This radiator is supposed to be much better than the stock Denso piece. Cost...amazingly only $380 and it looks great. The Be Cool is $850 ish and I couldn't see anything that appeared $400 better. It says it fits in the stock setup with no fabrication....we shall see. Here is a pic.
'17 ZL1 A10 Mosaic Black PDR/Nav 2:08.35 VIR Full
'15 Z/28 #325 black a/c & stereo. 2:10.1 VIR Full 1:44.74 Summit Point Shenandoah Circuit (sold)
'12 ZL1 10.52@131 1.55 60' 2:13 VIR Full (sold)
Stephen12ZL1 is offline   Reply With Quote
Old 12-08-2012, 01:48 PM   #2
charlietuna
charlietuna's Avatar
Drives: 2013 ZL1
keep us posted it looks great. Any weight savings with that piece?
Laus Deo
charlietuna is offline   Reply With Quote
Old 12-08-2012, 04:26 PM   #3
Bad@ssCamaro
Rogers' Rocks :-)
Bad@ssCamaro's Avatar
Drives: 2015 1SS/1LE
That's a great price. Dewitts has a high performance radiator for the Camaro and its $595, but it has an internal transmission oil cooler. The BeCool radiator is a bit steep for a radiator IMO. I can see if it was a custom radiator, but not for a production model. I will look into this as well, thanks for the heads up
2015 CRT 1SS/1LE RS/Recaro's/NPP/Nav/Rear vision pkg./BA speaker upgrade.
ARH 1 7/8 headers, CAI, BMR 1.25 drop springs, JPSS Billet Bushings, Peddars Cradle Bushings, DSS driveshaft ...421 whp...so far.
Old 12-08-2012, 05:14 PM   #4
Stephen12ZL1
Drives: '17 ZL1 A10
I doubt it is lighter. My feeling it is slightly heavier because of the bigger core.
Old 12-08-2012, 10:28 PM   #5
Stephen12ZL1
Drives: '17 ZL1 A10
unfortunately there are a couple problems with the install. Our ZL1 cars (at least my automatic) has a fitting at the base on the lower driver's side that isn't present on the new radiator...arrgh! I suppose I could use the drain plug location for a fitting. Also, the fan upper retaining screw bosses are 21" apart center to center and the original ZL1 is 22". I underestimated GM and "assumed" they used the same radiator as the SS to save money...not the case. I will proceed with removing the radiator and see if I can make the new one work. The way this looks, there may not be anything that fits our cars without consulting an expert such as Griffin or Be Cool directly. My fault, I should have contacted Lingenfelter or ADM first but I was sure this would be a slam dunk.
Old 12-08-2012, 10:36 PM   #6
Stephen12ZL1
Drives: '17 ZL1 A10
the dewitts part is correct. here is a pic of the right one.
http://www.dewitts.com/collections/c...minum-radiator
the mishimoto part doesn't look like it will be working for me...darn it.
Old 12-09-2012, 03:46 AM   #7
Bad@ssCamaro
Rogers' Rocks :-)
Will you be trying out the Dewitts? I have it on my wish list and it would be great if someone were to put it in and report definite improvements in cooling. Keep us posted.
Old 12-09-2012, 07:34 AM   #8
Stephen12ZL1
Drives: '17 ZL1 A10
The stocker is not going back in the car. I just ordered the Dewitts last night. It is more expensive for sure, but should be worth it. As I checked the various manufacturers pics, the Dewitts one is the only one that has the correct fitting as all of the others (Mishimoto, Stillen, Flex a lite, Be Cool) is lacking this extra hose connection. Anyone with a 10-11 SS want to buy a brand new Mishimoto radiator? LOL!
Old 12-09-2012, 07:47 AM   #9
Bad@ssCamaro
Rogers' Rocks :-)
You know, since you have a supercharged LSA, have you heard of the super chillers by AI Chillers? Here's the link from the forum:
http://www.camaro5.com/forums/showthread.php?t=204090
Old 12-23-2012, 05:36 PM   #10
madmaxx18
madmaxx18's Avatar
Drives: 07_tundra/08_zo6
does this fit an ss?
madmaxx18 is offline   Reply With Quote
Old 12-23-2012, 06:06 PM   #11
Stephen12ZL1
Drives: '17 ZL1 A10
yes...2010-2011 SS. check your stocker where the fan mounts. you can buy mine because 2012 is different. I will give you a good price.
Old 12-23-2012, 06:31 PM   #12
madmaxx18
madmaxx18's Avatar
ok sounds good pm me!!! not a hundred percent sure it will fit for me for me with my aftermarket supercharger though.
Old 12-23-2012, 06:49 PM   #13
madmaxx18
madmaxx18's Avatar
hey pm pictures of it please.
Old 12-23-2012, 07:10 PM   #14
Stephen12ZL1
Drives: '17 ZL1 A10
first post on this thread is the radiator as I unboxed it and found it wouldn't work on a '12
