BeckyD @ James Martin Chevy
Old 12-11-2012, 01:01 PM   #15
JLE58
Drives: CGM,twin turbo, cam 2010 SS/RS
I hope you over built that transmission. Ptc builds a great TC but I had quite a bit of issues in the past running their th400 untill I just it to my local guy and he found quite a few issue and got me squared away. Also if your not running 36 element sprag and drum and some billet shafts it won't last very long with a heavy car.
JLE58 is offline   Reply With Quote
Old 12-11-2012, 01:11 PM   #16
GFORCE1320
Drives: 05 GTO
Originally Posted by stanwilliams View Post
Be aware that you will probably have to run more fuel and less timing to the rear cylinders because of the way the air flows around that elbow. I have something similar on my 10.5 car but it comes in from the rear and the front cylinders get all the air. Its not a problem just pull all the plugs and compare after some WOT pulls. I had to adjust something around 15% on my car from front to rear.
After I said this I wasn't sure the stock OS allowed this. I have Big Stuff on my racecar and it does. However I just looked and HP Tuners does allow a Static retard vs Cylinder and an Injector Gain vs cylinder. I have never used this with HP tuners and there is a warning that some operating systems can cause high rpm operational problems when using this.
^^^ This guy knows his stuff!
Stan, any plans to build a crazy fast 5th gen?
Stop by our shop sometime, we moved since last time we spoke.
Thanks
Chris
GFORCE1320 is offline   Reply With Quote
Old 12-11-2012, 02:07 PM   #17
stangkilr
stangkilr's Avatar
Drives: 2017 Camaro ZL1
Its got a billet drum, pro mod sprag, billet shafts. Should hold some shit.
2017 ZL1
2014 Corvette
2002 Camaro
stangkilr is offline   Reply With Quote
Old 12-11-2012, 02:08 PM   #18
stangkilr
stangkilr's Avatar
I have already been reading some stuff on the elbow. I guess we will see. This one isnt the super low profile one but if we run into this problem im sure we can fix it. If not, COPO hood and Holley high ram time.
2017 ZL1
2014 Corvette
2002 Camaro
Old 12-11-2012, 02:49 PM   #19
stanwilliams
3000 hp 648 ci beast
stanwilliams's Avatar
Drives: 86 Outlaw 10.5 Camaro, 2SS/RS LS3
Chris Derrick years ago had a wierd looking elbow that Mike Duffy from OKC built. It looked like a big 12 round air cleaner with a 5 in throttle body stuck in the side of it. It slowed the airflow down and made it come in from all directions. I thought it was goofy back then but now can see its advantages.
Another friend/customer of mine Dewayne Mills had a billet elbow made by someone, can't remember who, that had deflectors made into it to redirect the airflow. I don't think it really worked out that great. He still had to trim the cylinders differently.
2SS/RS, LS3, 6M, IOM w/black hockey, IO interior, sunroof
mods: ******** setup. Whipple supercharger....Need suspension upgrades now... 4" stroker kit, ARH, cam on my wish list.
stanwilliams is offline   Reply With Quote
Old 12-11-2012, 02:54 PM   #20
stanwilliams
Thanks
Chris
Thanks Chris. I have lots of stuff I'd love to do to my 5th gen but allimony payments have put a damper on that for a while.
I will have to stop by sometime, Nice to have a great vendor so close to home.
Old 12-11-2012, 03:43 PM   #21
GFORCE1320
Drives: 05 GTO
We look forward to you dropping the car off for your 9" kit Justin. Thanks for your order! See you in a couple weeks.
Thanks,
Casey
Old 12-11-2012, 03:48 PM   #22
stangkilr
stangkilr's Avatar
Thanks Casey! Thanks for working with me to get me what I need to keep this
thing on the road. Should be a fun ride when finished.
2017 ZL1
2014 Corvette
2002 Camaro
Old 12-11-2012, 04:20 PM   #23
Ivan @ Southwest Speed
Stupid sick build....makes me happy inside. Good luck and see you in Houston!
Ivan
Old 12-12-2012, 01:42 PM   #24
JLE58
What heads are you going to run? and how fast are you wanting to run?
Old 12-12-2012, 03:17 PM   #25
se7en
Drives: 87 Pinto on 32's
That setup with a GForce 9" you cant go wrong. Please post up more pics as you go
se7en is offline   Reply With Quote
Old 12-12-2012, 05:06 PM   #26
Unobtainium
Fabricator
Unobtainium's Avatar
Drives: 2011 2SS Summit White
Looks good. Should haul!
Roto-fab CAI
Unobtainium Welding Exhaust
ARH LT's
393whp L99
GPI VVT Turbo Cam-in
Twin Mini's...soon
Permagrin...Always
Unobtainium is offline   Reply With Quote
Old 12-12-2012, 06:48 PM   #27
stangkilr
stangkilr's Avatar
Going to run stock casting LSA heads untill I have lifting issues. I think ill be fine untill I go over 1200rwhp.
2017 ZL1
2014 Corvette
2002 Camaro
Old 12-12-2012, 07:11 PM   #28
JusticePete
JusticePete's Avatar
Drives: Camaro Justice
