HeadlightArmor
Old 12-13-2012, 09:47 PM   #43
jrpxxii
jrpxxii's Avatar
Originally Posted by stangkilr View Post
Going to run stock casting LSA heads untill I have lifting issues. I think ill be fine untill I go over 1200rwhp.
What kind of boost are you looking for? Boost more than the actaul power level will lift the heads as you will need to look at the heads closely for seapage as Im guessing at that power level its going to take alot of boost. I have 6 bolt heads and lifted them earlier this year but new gaskets and retorqueing them fixed the issue but this is still on a lower boost tune of 26lbs. My intake setup is similar as well and you can split the elbow in half and weld a piece of sheetmetal to split the airflow in half to help with airflow from front and back cylinders unless you have software that allows you to tune each individual cylinder for air and fuel. I am running the Holley Dominator EFI software and I can adjust each cylinder to exact specs and make sure each spark plug reads identical.
Old 12-13-2012, 09:54 PM   #44
stangkilr
stangkilr's Avatar
Drives: 2017 Camaro ZL1
I am going to run about 25lbs of boost but at the compression I am at and on E85 its a little easier to make big power on less boost. My last combo was a completely stock 6.0 LQ9 shortblock, stock ls3 heads, LS9 cam and on 22lbs it was 1,100hp. On my edelbrock elbow its already split inside..? I have been reading that they always were not split so I find it interesting mine is. I had good luck on my last setup not pushing water. LS9 gaskets, copper coat, tq to 85ftlbs, heat up the car and re-tq. Its crazy how much they suck down once the motor is ran and warm.
2017 ZL1
2014 Corvette
2002 Camaro
stangkilr is offline   Reply With Quote
Old 12-13-2012, 10:30 PM   #45
jrpxxii
jrpxxii's Avatar
Sounds like you have a good game plan and good luck with everything as thats a sweet setup. The elbows need to be split as it helps even the airflow to all the cylinders from front to back.
Old 12-13-2012, 10:40 PM   #46
stangkilr
stangkilr's Avatar
I just looked through your build jrpxxii, what rear control arms are you running for the 15" wheels? Nice car btw!
2017 ZL1
2014 Corvette
2002 Camaro
Old 12-13-2012, 10:57 PM   #47
jrpxxii
jrpxxii's Avatar
Thanks I am running the Xtreme Innovations & Fabrication 15" conversion kit as this is a complete kit that includes everything needed to run 15" properly. Craig at Xtreme did my cage and front K member and suspension as well as this guy knows his stuff and makes everything personally at his shop and it is all direct bolt in parts.
Old 12-13-2012, 11:01 PM   #48
stangkilr
stangkilr's Avatar
Thanks for the info...btw I posted a pic of your car on my fb page..its getting some likes!
2017 ZL1
2014 Corvette
2002 Camaro
Old 12-14-2012, 10:41 AM   #49
Sean@Phastek
Sean@Phastek's Avatar
Drives: 2010 Camaro X5 Turbo
Killer build. Can't wait to see it in action at TX2K13!!
Sean@Phastek is offline   Reply With Quote
Old 12-14-2012, 12:42 PM   #50
jrpxxii
jrpxxii's Avatar
How do i find u on facebook
Old 12-14-2012, 12:46 PM   #51
jrpxxii
jrpxxii's Avatar
Look me up on fb as there r alot of pics and video. Jason Parker in Bowling Green, KY
Old 12-14-2012, 01:14 PM   #52
MANNYS2SS/RS
MANNYS2SS/RS's Avatar
Drives: 2010 Camaro 2SS/RS,LS3
Do you have any pics, of how they split inside of the elbow?
LS-3, ProCharger D1SC
665. rwhp /562. rwtq @ 9.3 psi
MANNYS2SS/RS is offline   Reply With Quote
Old 12-14-2012, 01:38 PM   #53
stangkilr
stangkilr's Avatar
I have a fb page "stangkilr productions"
2017 ZL1
2014 Corvette
2002 Camaro
Old 12-14-2012, 01:41 PM   #54
stangkilr
stangkilr's Avatar
I can get some for you.
2017 ZL1
2014 Corvette
2002 Camaro
Old 12-14-2012, 03:05 PM   #55
Detoxx03
ЯєŧąяĐ Єlímíиąŧ°я Ö
Detoxx03's Avatar
Drives: 2008 Corvette
The picture made 1320's page too
D1SC Procharger 932/758 on E85
A Futral Motorsports Creation
https://www.facebook.com/DetoxxAtomic
Detoxx03 is offline   Reply With Quote
Old 12-14-2012, 04:45 PM   #56
stangkilr
stangkilr's Avatar
Like a boss!
2017 ZL1
2014 Corvette
2002 Camaro
