BeckyD @ James Martin Chevy
Old 12-11-2012, 02:27 AM   #1
Tulkas
Drives: Holden ve sv6 2007 manual
Tuning issue
Hey everyone, I am having issues with my cam tune.
Here is the short story:
When the 226/226 profile cams went in 5 months ago, despite the fact that the car was slow, I could drive my car around without any issues and NO error codes popping up for 2 months.
Once I got my 1st tune, which I'm pretty sure its the same tune as when Yellow_Glide had when his car was being tested with the 226/226 profile cams, the car got 30rwkw instant which is a GREAT bonus...BUT... there is an error code that has been popping up almost everyday for the past 3 months now and I have to delete it because once it pops up the car has enough power to drive to the side to delete it.
The error code is P2189 - System bank 2 running lean at idle.
I have received an updated tune almost 1.5 months ago which I was told they increased the fuel ratio into the engine when its sitting at idle.
BUT now the car stinks fuel, its dumping fuel which is a waste and the error code is still there.
I used an ELM bluetooth controller to get some readings from the Torque app and also the ScanXL pro app on windows, and here are the readings:
AFR: 14.7 at idle
MAF: 47-52cfm at idle
V.E.: 22% at idle
Are these idle readings correct?
Has anyone else had this issue and might know how to fix it?
My car is a Holden ve sv6, alloytec engine LY7 manual.
Any help is much appreciated.
Cheers,
Peter
Tulkas is offline   Reply With Quote
Old 12-11-2012, 12:31 PM   #2
kjkjr27
COTW 9/16/13
kjkjr27's Avatar
Drives: 2011 2LT/RS Camaro IOM
Are these the first batch of Mave ones? Didn't they have to be grounded down some?
kjkjr27 is offline   Reply With Quote
Old 12-11-2012, 02:06 PM   #3
Yellow_Glide
Yellow_Glide's Avatar
Drives: 2011 1LT "Chakita". 04 Yota
Hi Tulkas- is that correct on the AFR?!? I'm at mid 11s at idle.
Kjkj- The 226s in the LY7 did not have to be resized.
Hi, my name is Chakita. I have cams!!!!
Build thread: http://www.camaro5.com/forums/showthread.php?p=3847083
Yellow_Glide is offline   Reply With Quote
Old 12-11-2012, 02:37 PM   #4
Matt @ FSP
Matt @ FSP's Avatar
Drives: 2011 Camaro SS
At idle that is correct.. Should be oscillating in the 14.68:1 range, depending on what cell you are in, afterstart enrichment etc. Your wide-open is mid 11's, not the idle
Tulkas: What are your long term fuel trims.. These are what would trip that code, most likely you are +10% or above on the LTrims on bank 2 (Passenger), and that is what is tripping the code. This can be from vacuum leaks, fuel pressure, etc.
- Matt
Matt @ FSP is offline   Reply With Quote
Old 12-11-2012, 03:00 PM   #5
Yellow_Glide
- Matt
That's why I need to be closer to FL - so I can hang around the shop!!!
Old 12-11-2012, 09:54 PM   #6
Tulkas
- Matt
Thanks for the reply, I did some logs but they look healthy.
I also did a exhaust system leak check but that came out healthy too.
Would you think that if the error code is ignored the ecu will popup something else?
