SDTW Custom Wheels & Tires
Old 12-11-2012, 03:00 PM   #15
willhe64
willhe64's Avatar
Drives: 2012 45th Vert, 2011 4x4, 9sec Vega
I'm going to say that it is in fact the Less restrictive air filter that all these intakes come with that do more for power gains than the shape and design of the tubes. On all brands.
I feel it only fair to warn you, I have a black belt in CAPS LOCK.
willhe64 is offline   Reply With Quote
Old 12-11-2012, 03:32 PM   #16
BplumCrazy-SS
BplumCrazy-SS's Avatar
Drives: 416 w/TH400
Cruuzin LV you have a 2012 so the over the radiator style Vararam will not work. They are redesigning the intake for 2012+, here is a link to the Vararam that will work on your car
http://www.camaro5.com/forums/showthread.php?t=258276
BplumCrazy-SS is offline   Reply With Quote
Old 12-11-2012, 05:31 PM   #17
Sharkss
Drives: 2010 CGM 2ss/rs M6
i can take my vararam out in less than 5 mintues. Its not hard just have to know what your doing. Love the IATs!!!!
Sharkss is offline   Reply With Quote
Old 12-11-2012, 08:12 PM   #18
axis
Search Ninja
axis's Avatar
Drives: 2010 Black 2SS/RS A6
Originally Posted by toehead93 View Post
It isn't all about flow. I actually agree with VR that most intakes probably don't flow much better than stock. The stock design is pretty good for what it is. There are no severe bends or restrictions at all, and the lower part of the air filter housing contains a large port to suck in cold air.
I believe most HP gains come from relocating the MAF and modifying the design to lower IATs. High IATs trigger the CPU to pull timing.
If someone had time I bet they could use a green filter and play with MAF locations in the stock intake and get similar gains to aftermarket intakes...but it will still look ugly!
Whole heartedly disagree. The stock system is ok for what it is, but there are several places that can and have been improved upon. The silencers and accordian section are killer for laminar flow. Add in that it gets air from one source and you have a somewhat restrictive system. I don't see your meaning about moving the MAF to get lower IAT's. ADM is the only one that moved theirs to the box but the rest of them are pretty much in the same place in relation to the filter. They get lower IAT's because they get more fresh air from several places instead of just one. The stock one gets ALL it's air right off the radiator. If the OEM system was as good as the aftermarket ones, someone would have shown a nice increase from just adding a aftermarket replacement filter. To date, no one has. There was one article from HPTV, I think, that showed it gained several HP but that same article showed the K&N typhoon making 25whp 20+tq with no tune.
Also not entirely true. All the OEM location CAI's have basically the same shape, yet some are quite a bit better than others. Lack of connections in the intake tube, a velocity stack, and other tweaks make a big difference when you put them all together. Obviously you need a good flowing filter as well but that's just one part of the puzzle.
All of the better CAI's are at or within a degree or two of ambient.
I'm intersted to see what VR is going to claim about their new intake, to say it's better than all the others since they are now in the OEM location. If you want to talk about wild claims, VR has had their fair share. I've seen them claim, 20+ degree LOWER than ambient IAT's, positive pressure created from their ram air, and DYNO PROVEN results when they in fact stated in their threads that they calculate their gains from track times. Obviously it's a decent intake but they have been FAR from straight forward in regards to their intake.
Halltech CF 102 fed
GPI modded intake manifold
Bo (knows) White ported TB
Kooks LT's/ Dynomax VT
Pfadted (springs/sways)
Dyno tuned by Rhino and GPI
Old 12-12-2012, 07:33 AM   #19
DRKS1D3
DRKS1D3's Avatar
Drives: 2011 Camaro SS Convertible LS3
THIS! They have a totally new design now.
MY RIDE: 2011 TRIPLE BLACK SS CONVERTIBLE (BOUGHT NEW 4-2011)--6 SPEED MANUAL, K&N TYPHOON INTAKE, FLOWMASTER FORCE II MUFFLERS, HOTCHKIS SUSPENSION, GLOSS BLACK 20x9 STYLE 41 WHEELS, 285-35-20 GOODYEAR EAGLE SUPERCAR G2'S, JBA HIGH-FLOW CATS, BBK HEADERS, LUNATI CUSTOM GRIND CAM: 227/235 .619/.626 114 +3
DAD'S RIDE: 2012 ZL1 #1866 (BOUGHT NEW 6-2012)--BLACK, 6 SPEED, EXPOSED CF HOOD, POLISHED WHEELS, SUNROOF, ROTO-FAB INTAKE
"Silly Americans, taking from the rich and giving to the poor only works in fairy tales. Success is earned here!".
DRKS1D3 is offline   Reply With Quote
Old 12-12-2012, 11:04 AM   #20
BowlingSS
Camaro Owner Since 1987
BowlingSS's Avatar
Drives: 2011 2SS/RS L99 RJT
One main reason I picked my CAI,Inc was the lower IAT's.
Bill
2011 Camaro 2SS/RS L99 RJT
CAI, Inc. Cold Air Induction;ADM Scoop
Rx Catch Can;Rx Breather;Roto-Fab Washer Container
VMax Ported RJT Throttle Body
XSPower Headers and XSPower 3" Exhaust System
Elite Engineering Tunnel Brace,
Gorilla Wheel Lock System; Bear Rotors, Hawk HPS
Tinted Windows 35%;EFILive Tune
BowlingSS is offline   Reply With Quote
Old 12-12-2012, 11:56 AM   #21
IMJ
IMJ's Avatar
Drives: 2012 SS LS3 | Silver Frost Metallic
Originally Posted by Cruuzin LV View Post
So here is my question does Vararam really expect people to believe that a simple drop in filter provides more air flow than the majority of the intakes out there with the exception of roto-fab?
I have no idea what Vararam expects people to believe. But did you have a real question in there about these filters, or flow rates, or intakes?
__________________________________________
Ironman John
IMJ is offline   Reply With Quote
Old 12-12-2012, 01:02 PM   #22
IndeedSS1
IndeedSS1's Avatar
Drives: 2010 Camaro SS LS3
Not if you have a temp probe directly in front of the throttle body (or in the intake manifold) and check. But hey there are those that don't believe people should actually try stuff for themselves, think out of the box, or even suggest it out loud.
She is only memory now.
IndeedSS1 is offline   Reply With Quote
Old 12-12-2012, 02:08 PM   #23
Cruuzin LV
Cruuzin LV's Avatar
Drives: 2012 Camaro SS 45th Anniversary
Bill
Yeah looking at this as far as money vs temp/flow. I'm really thinking of getting the blackwing and ceremic cote it and a green air filter and calling it a day.
Cruuzin LV is offline   Reply With Quote
Old 12-12-2012, 02:13 PM   #24
Cruuzin LV
Cruuzin LV's Avatar
Actaully my questions have been pretty much answered. Via this thread and other searchs. A good intake has good flow and low IAT's and since Vararam seems to back up their claims according to quite a few people I'm going to pull the trigger and select what makes sense to me cost/performance wise. Which is a ceramic coated blackwing tube/ intake box and a green filter.
Old 12-12-2012, 03:11 PM   #25
LSR SAL
LSR SAL's Avatar
Drives: faster than dirt...
Originally Posted by Apex Chase View Post
Don't be confused by manufacturer "claims" (marketing). Focus on real world results. There is some garbage out there but Vararam and a few others do produce very solid gains.
+1 there will always be marketing and companies trying to drive profits. sometimes you just need to see through the bull and read customers real world experiences.
LSR SAL is offline   Reply With Quote
Old 12-12-2012, 03:55 PM   #26
axis
Search Ninja
axis's Avatar
And who's put a probe there to check the IAT's from all the different CAI's? Since the PCM adjusts fuel/timing based off the IAT's from the MAF, that's the big one. Seeing how fast the air is moving in the intake, I don't see how you could get a appreciable change in temps in the ~1.5ft of tubing from the MAF to the TB.
Halltech CF 102 fed
Old 12-13-2012, 05:20 PM   #27
Jason@JacFab
Drives: 2016 1LT RS Camaro; 72 Chevelle
Send a message via AIM to Jason@JacFab Send a message via MSN to Jason@JacFab
I decided to do some testing today
I mounted my LS3 head/intake/tb to the flow bench and tested the stock airbox w/ stock filter, and stock tube, then I swapped the tube out for a tube similar to that which you would find in most intake systems (4" OD 16GA aluminum tube, ~16" long, 6" CLR)... Much to my surprise the stock intake tube with it's baffles & accordion section flowed more than the tube without that stuff...
The stock tube flowed ~0.75% more (~2 CFM) than the aluminum tube did. While I didn't compare the stock tube to a Blackwing because I don't have one, I imagine the results would be similar (little to no change).
After doing this and seeing the results, IMO the tube is a waste of money, all you'd get is more intake sound due to the lack of the baffle box.
The filter: I did compare the stock filter vs an S&B filter @ .500" lift on cyl#3 through the top end assy.
The S&B filter flowed roughly 1% better through the intake system/tb/intake/head @ .500" lift... (appx 3 CFM more)...
And who's put a probe there to check the IAT's from all the different CAI's? I don't see how you could get a appreciable change in temps in the ~1.5ft of tubing from the MAF to the TB.
I have... And you'd be surprised at the results.
Jason@JacFab is offline   Reply With Quote
Old 12-13-2012, 05:26 PM   #28
axis
Search Ninja
axis's Avatar
Post em up. The more data we have the better.
Halltech CF 102 fed
green filter, intake, vararam
