Old 12-11-2012, 12:16 PM   #1
PieNsky
PieNsky's Avatar
Drives: Victory Red 1LS
Blower motor replacement
The blower motor is cast in and will have to be cut out. Don't freak, it was made to be cut out and has a groove to follow. Remember you have a knife in there around wires. This is easier to do with the passenger door open.
1. Open the glove box door. Release the door tensioner on the lower right corner of the door by pulling down on the cord, sliding it down and out. Push in on the sides of the door to free the door to drop down. It has an open hinge so that you may lift it out.
2. There are two screws in each corner that will be exposed when you remove the door. One holds the duct, the other will allow you to manipulate the opening. Remove the four screws and the duct.
3. Remove the screws that hold the center cover of the blower and unplug the motor.
4. There is a circular groove that you will follow with your cut. The plastic is thin so you will not need to push the knife in much. The second photo has a silver box cutter with the razor blade inserted into the groove to cut . The box cutter also prevents too deep a cut.
5. If needed, clean up your flashing from the cut, otherwise slide in your new blower and align it with the screw openings already cast in and not used. I used #8 by 3/4" screws to hold it in.
The last photo is the new blower being slid in. Notice the precast screw opening to align the one on the blower.
PieNsky is offline   Reply With Quote
Old 12-11-2012, 08:26 PM   #2
PieNsky
PieNsky's Avatar
And here is the missing photo of the removal of the old blower motor and one screw hole in the lower corner that had a screw . The 4th of three screws , held up the duct that has to be removed in front of the blower.
Old 12-14-2012, 08:16 AM   #3
SGNL99
Drives: 2010 2SS/RS CGM
Thank you for this DIY! My motor is just starting to "chirp" so I'll be looking at this replacement soon.
CAI Black Intake w/ Apex scoop & ww bottle kit; VMAX throttle body; Borla S-type Cat back exhaust; Skip shift eliminator; Elite Engineering catch can; MGW short throw shifter; Stainless Works LT Headers w/ Hi-Flow cats and one awesome JRE TUNE! BMR stage 2 suspension; 3.91 gears
SGNL99 is offline   Reply With Quote
Old 12-14-2012, 02:06 PM   #4
ITGuy11
Burning up tires
ITGuy11's Avatar
Drives: 2010 Camaro 1SS/RS
Good write up, do you have a part number for the replacement blower?
Blower, cam, supporting mods 644RWHP 615RWTQ
My Build Thread COTW 11/19/12
Detroit 5th Gen Camaro Club
ITGuy11 is offline   Reply With Quote
Old 12-14-2012, 05:51 PM   #5
PieNsky
PieNsky's Avatar
Rockauto.com is where I ordered it. It started not moving air well on low speed, and a clicking noise sorta. Went out about two months later.
Old 12-14-2012, 07:53 PM   #6
montreal2010yellow
montreal2010yellow's Avatar
I had mine changed by my dealer 2 months ago. 300.00$ Tax (15%) in. Canadian $$$.
Don't the cost of the motor though, but it was inclided.
Old 12-14-2012, 08:47 PM   #7
PieNsky
PieNsky's Avatar
$70.79 + shipping American at rockauto
By far the worst part is cutting it out. It is stiff, but you should be able to do all in an hour.
Dealer wanted around 125 plus at least one hour service, shop fees, tax. So about $250 I guess.
Old 12-21-2012, 07:55 AM   #8
mkschmidtjr
2K11 2SS w/RS Jewel Red
mkschmidtjr's Avatar
Drives: 2K11 2SS w/RS package Jewel Red
@PieNsky thanks for the DIY info.
..also for everyone on the thread I had my replaced last weekend and it was covered under my basic 3 year / 36k miles warranty so the dealer should cover it until then. I noticed my was chirping really bad when I would turn off the blower you could hear it when it was spinning down. Best wishes to all.
mkschmidtjr is offline   Reply With Quote
Old 12-21-2012, 12:28 PM   #9
Green2SS/RS
Drives: 2011 SGM 2SS/RS
My blower is "chirping" also. Dose any one know what is causing it to do that? I hope its not water getting in.
Green2SS/RS is offline   Reply With Quote
Old 12-22-2012, 07:05 PM   #10
CamaroJim56
Obsessed
CamaroJim56's Avatar
Drives: 2013 Crystal Red Metallic 2SS RS
Okay, somewhat related question... dealer jut replaced mine, and now the glove box door opens REAL easy, is there a tensioner that they forgot to connect? Where is it located?
thanks.
2013 CRT 2SS RS – Heritage Grille, CAI, ZL1 Style Splitter, Chrome OEM Wheels.
CamaroJim56 is offline   Reply With Quote
Old 12-22-2012, 07:11 PM   #11
camarowa
camarowa's Avatar
Drives: 2013 SVT Raptor, sold 2010 Camaro
Mine has been replaced under warrant twice already and the third one started acting up a few weeks ago. Just shitty quality!
- Pfadt Suspension Package; Springs & Sways
- Brembo Brake Upgrade (Yellow); Courtesy Fesler Built
- Custom Magnaflow Exhaust
- Blacked-Out Bowties & RS Emblems, Front bowtie delete
- Full Dynamat Extreme Trunk Coverage
- Tinted side markers
- Interior DSV Customs Leather Upgrades
- Airaid CAI V2
- Forgestar F14 Gunmetal 20x9, 20x11
- Doug Thorley Shorties
camarowa is offline   Reply With Quote
Old 12-23-2012, 10:39 AM   #12
PieNsky
PieNsky's Avatar
Whoops! This photo is upside down. I uploaded it from my phone.
@CamaroJim56, yes there is there is a tensionor and I didn't put that in the procedure. With the door open, in the lower right corner, you will see a horizontal clip. It is attached to a retractable cord. Pull the cord out and place the the clip in the lower right corner of the door.
Old 12-23-2012, 02:02 PM   #13
CamaroJim56
Obsessed
PieNsky,
Thanks! You are the best, found it, think the clip is broken, gotta look at it again.
Still under warranty so no issues other than the hassle.
Appreciate your help.
Happy Holidays.
Jim
Old 12-23-2012, 07:23 PM   #14
PieNsky
PieNsky's Avatar
That's is what mine was doing a couple of months before it went out. You could only hear it on low, and it didn't move much air anymore on low. Had to keep it on the higher setting and then they went out one night. Started back up after a few minutes, just kept going on and off.
Once that it has been cut out, it will be a breeze to replace. It is tiring cutting it out.
As to the cause, I think that the cabin filter needs to be changed more often and it appears as some of the air is returned and used to cool the motor.
