Old 01-22-2008, 10:12 PM   #1
stovt001
stovt001's Avatar
Drives: 2006 Cobalt, 2004 Taurus wagon
A Gen V hint?
On Leftlane News they have an article about the future of the Corvette in the face of the new CAFE regulations (linked below). I found one quote particularly interesting:
"Wallace added: "I don't think we're going to design a 700 horsepower Corvette."
Instead, Wallace says the next Corvette will have a heavy emphasis on pounds per horsepower. Although no figures are set, Wallace said that if the C7 Corvette were to shed 300 or 400 pounds, it could use a 4.7L V8 with 150 less horsepower than found in the 2008 models and still maintain the same performance. Lighter weight would also translate into better handling."
So does anyone else think this might indicate that one Gen V engine could be a 4.7L? The 280 hp figure just doesn't seem right though. They could easily make 280 hp with a V6. A 4.7L should get at least high 300 hp, nearly 400.
http://www.leftlanenews.com/corvette...gulations.html
stovt001 is offline   Reply With Quote
Old 01-22-2008, 10:24 PM   #2
SilverTurtle
Reality Check Specialist
SilverTurtle's Avatar
Drives: '02 Z28, 2012 45th SS
Send a message via AIM to SilverTurtle Send a message via Yahoo to SilverTurtle
as a point of reference, the supercharged 4.4L Northstar in the XLR-V makes 443hp and the 4.6L with VVT in the regular XLR makes 320hp
got tequila?
SilverTurtle is offline   Reply With Quote
Old 01-22-2008, 10:32 PM   #3
Scotsman
Auto Pilot
Scotsman's Avatar
Drives: Gunmetal
As long as we get to keep the V8 engine I'm stoked. If not; these cars will end up being some of the bastardized products I've seen yet from our beloved. I can make-do with less power as long as they engineer a way to make it a performance marvel, and there are definitely ways of doing that (BMW, Lotus,... anyone???).
"Let the rest of the world dream of Ferraris, Lamborghinis and dinky little British two-seaters. In this country speed doesn't look like that." Got SS?
Scotsman is offline   Reply With Quote
Old 01-22-2008, 11:36 PM   #4
Mr. Wyndham
I used to be Dragoneye...
Mr. Wyndham's Avatar
Drives: 2018 ZL1 1LE
I definitely think that it's a Gen V hint. But I also think that the hp humber was just a relative number to gloat(much deserved) and say - "you know we could do this....".
And although a V6 can make 280hp easily...IMO, V8's are easier to work with, and yield better results. Take that DI V6 right now...with all it's tech, it still 'only' gets nearly the same mileage as the LS3 in the Vette.
Now, on the other hand - put the Legendary performance, durability, and economy of a Chevy Small Block into a smaller package. Imagine the savings - in all three areas!!
Old 01-22-2008, 11:44 PM   #5
Scotsman
Auto Pilot
Scotsman's Avatar
Drives: Gunmetal
Now THAT sounds like a great idea. GM has too large a resource pool not to make the V8 engine more efficient.
Old 01-23-2008, 01:29 AM   #6
TAG UR IT
www.Camaro5store.com
TAG UR IT's Avatar
Drives: 2014 ZL1 #705
Calling jenny craig....could our Camaro end up weighing in at even less than the hoped 3,750? And, with a Gen V???
Old 01-23-2008, 05:22 AM   #7
asrapid
asrapid's Avatar
Drives: Stratus
If we look at LS3 it develops around 70 Hp/liter..so with V8 4.7 l displacement engine based on ls3 could develop around 330 hp..without using DI vvt etc. Maybe he thinks on Z06 engine since zr1 isn't on sale yet. So roughly 505 -150 = 355 hp..which could be achieved with DI, vvt etc in smaller diplacement engine. And if they need more they could turbocharged/supercharged it.
I hope GM didn't cancel Gen V ohv like they did canceled Northstar 2, and that it will get DI (and maybe 3 valve head)
asrapid is offline   Reply With Quote
Old 01-23-2008, 01:24 PM   #8
Grape Ape
Drives: 96 Bronco w/ a 5 speed
I don’t think that the mileage is comparable until GM offers both engines in the same car.
Considering how fat, wide (wind resistance) and stuffed full of power sucking doodads the Cadi is compared to the Vette, I think that it is pretty impressive that the Cadi even comes close on MPGs, even allowing for the missing 130 horses.
I do think you’re right that the 280 is nothing, hell the turbo 4 in the Kappas makes 260. I suspect the quote refers to the LS9. He is saying that the next step from the ZR1’s LS9 is not a 700 horse V8. Instead they are going to get Jenny Craig to help build a Vette that scoots with 470 horses (620-150).
A 470HP 4.7L would be worth bragging about, that works out the about 1.6 horses per cubic inch. And unless it was hand built like the LS7, there is probably a fair chance of the Camaro getting it as an option since the Vette’s weight advantage would be unassailable.
Grape Ape is offline   Reply With Quote
Old 01-23-2008, 04:44 PM   #9
The_Blur
Jayhawk USN
The_Blur's Avatar
Drives: Demon Super Sport
There's a lot that could be reduced to make less horsepower go farther. For example, if the Camaro uses fiberglass or aluminum panels, the weight could be significantly less than 3,700 lbs. I'm sure GM has some tricks up their sleeves.
FM: The_Blur/1110/USN//
TO: Camaro5//
INFO: RDP Motorsport//GEN5DIY//Cultrag Performance//JPSS//Rodgets Chevrolet//
SUBJ: Operation Demon//
REF: Buy at Invoice, Forum Rules
1. RESPECT ALL CARS. LOVE YOUR OWN.//BT
warn 145:154 ban
Old 01-23-2008, 09:23 PM   #10
camarocrazy28
camarocrazy28's Avatar
Drives: 1990 Camaro RS
With direct injection, and super/turbocharging many things are possible--even 400 hp. Remember, GM' s high feature 3.6 liter V-6 with direct injection has like 300 hp and the turbocharged I-4 Ecotec in the Saturn Sky Redline, Pontiac Solstice GTP and the new Cobalt SS (coming soon) has 260 hp.
camarocrazy28 is offline   Reply With Quote
Old 01-25-2008, 12:12 PM   #11
asrapid
asrapid's Avatar
Drives: Stratus
Guys , what do you think are chances we will se something like this in future- XV8 engine from 2001. Two cam in block , direct injection, 3 valves.
http://autospeed.com/cms/A_1193/article.html
I think it could with tune up for sports car and more displacement develop around 400 hp.
Old 01-26-2008, 01:29 PM   #12
mprhead5
mprhead5's Avatar
Drives: 04 MAzdaspeed miata 250whp
lower displacment and more tech will be a good thing. If they can pull 350-400hp in a 2900 lb corvette it will kick ass. the vette is already a fairly light vehicle though. they will have to come up with some new materials to shed that weight. unless they can mass produce cheaper carbon fiber
87 camaro v6 m5, 89 Trans-Am GTA, 96 Camaro Z28 M6.
current Ride: 04 Mazdaspeed MX-5 250whp 13.3 1/4m
mprhead5 is offline   Reply With Quote
Old 01-26-2008, 01:52 PM   #13
Scotsman
Auto Pilot
Scotsman's Avatar
Drives: Gunmetal
It's said that that's another ten years out. However, CAFE may change that.
Old 01-26-2008, 04:03 PM   #14
stovt001
stovt001's Avatar
They could also make it smaller, though one of the Corvette's selling points is better than average interior and cargo room for a sports car.
I'm not sure if I'll buy a 5th Gen. Camaro Moose 5th Gen Camaro SS LS LT General Discussions 68 06-13-2009 06:18 PM
Camaro ls3 news...true or false? Dark Knight Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons 74 06-05-2008 06:29 PM
Gotcha! 'Gen V' Engine Details... DOHC! LSxcellent Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons 28 10-10-2007 04:23 PM
Chevy Rev It Up Tour Dates-Featuring the 5th Gen Concept TAG UR IT 5th Gen Camaro SS LS LT General Discussions 3 06-29-2007 04:30 AM
