Old 12-26-2012, 02:37 PM   #29
headgamez
Drives: 2015 Camaro 1LE
pm pricing to 53089 please!!
headgamez is offline   Reply With Quote
Old 12-26-2012, 07:28 PM   #30
flht99b
flht99b's Avatar
Drives: 2010 Camaro 2SS/RS RJT
Please PM pricing to business zip 37932, if it makes a difference I'm with an AC Delco auto repair shop.
Ed M.
RJT 2SS/RS, AAM 3.70's, MTI Sway Bars, Shifter & SS brake lines, ZLI calipers & rotors, BMR Trailing & Toe Arms, full rear cradle & diff bushings, Pedders XA's, Camber/Toe eccentrics, Radius arm inserts, ZL1 Brembo Brake pads, GTO clutch reservoir, LS9 cam, Comp Cam valve springs, Melling 10296 oil pump, CR 5 timing chain, LS2 damper, CAI Cold Air Induction, ARH LT headers w/HF cats, GMPP touring axle back, Elite Engineering Catch Can, Forgeline 20x9.5 & 20x11 DS3 wheels w/Vredestein 275/40/20 & 315/35/20 tires, '11 Convertible spoiler, Lloyd "SS" Floor Mats, GM Camaro Trunk Mat
flht99b is offline   Reply With Quote
Old 12-26-2012, 09:12 PM   #31
Mr. Nasty
Emerald Coast Camaros
Mr. Nasty's Avatar
Drives: 2010 RS/SS Rally Yellow & 68 SS
Your car has a cross member but kit does not why not? I just run the 1/4 mile are you saying all i would need is the rear with out cross member. And will it work for a all stock suspension with out other up grades?
Mr. Nasty is offline   Reply With Quote
Old 12-26-2012, 09:30 PM   #32
Mr. Nasty
Mr. Nasty's Avatar
On the front two bolts with out full kit would it bolt to the sub frame???
Old 12-27-2012, 05:21 PM   #33
Hellrazor
Drives: 2011 1lt rs vr blk stripe
Can you pm me a price? Thank you
Hellrazor is offline   Reply With Quote
Old 12-28-2012, 12:40 AM   #34
Khmero215
Khmero215's Avatar
Drives: Victory Red 2SS
pm price please
Khmero215 is offline   Reply With Quote
Old 12-28-2012, 12:54 AM   #35
Birm
Birm's Avatar
Drives: Florida Speed & Power
Pm price pls
Birm is offline   Reply With Quote
Old 12-28-2012, 01:05 AM   #36
grocerygetter
instigator
grocerygetter's Avatar
the install instructions are on their website. One tip I can pass on...put the 2 outer center bolts in with the inserts and the carrier bearing brace bolts x4 in first. Bring the rear cradle four bolts and forward 2 most bolts all down evenly. Just work your way around back and forth. The brace pre-loads and this is the easiest way I found. Two guys with air impacts knock it out in 5 min. lol
-John S.
Thanks to:
Tony@ dv8motoring
TCAudio in Benton AR
Old 12-28-2012, 10:33 AM   #37
Anthony @ LG Motorsports
Anthony @ LG Motorsports's Avatar
Drives: 1994 1LE / 2006 Z51 Corvette
I'm confused on the cross-member statement, what is shown in the picture is the stock cross brace, which you can bolt right on. We did not feel it was required to use a bigger piece in this location.
It does not interfere with any of the control arms, or mounting locations so any subframe bushing kit, or aftermarket control arms would be fine to use, as would all stock pieces.
Anthony @ LG Motorsports is offline   Reply With Quote
Old 12-28-2012, 10:38 AM   #38
Pricing sent!
Old 12-30-2012, 09:31 AM   #39
huitt06
huitt06's Avatar
Drives: 2011 L99 SS
pm pricing please
TSP 1 7/8, CNT catback, VMAX, CAI intake, ADM scoop, 3.70s, Adm Tuned(374/391), SLP UDP, 18" nurbs/NT05r's , 3200 stall, Granatelli trailing arms....1/4 mi best 12.7
huitt06 is offline   Reply With Quote
Old 12-31-2012, 10:15 AM   #40
Originally Posted by huitt06 View Post
pm pricing please
Sent!
Old 12-31-2012, 10:51 AM   #41
dcoates18481
dcoates18481's Avatar
Drives: 2010 CAMARO RALLY YELLOW SS/RS/M6
PM Price please!
I LIKE TO GO FAST!
Lethal Racing Night Fury Cam Kit, Melling oil pump, C5R Timing Chain, Dyno Tuned by Shawn@Lethal Racing, Vararam Tuned intake, Vararam Power Wedge, LSR Tri Ax Short throw Shifter, VMAX Ported T/B, TSP 2" L/T Headers, TSP Cat delete, Borla axle back exhaust, Innovate A/F monitor, 471.7 HP/438.8 TQ
dcoates18481 is offline   Reply With Quote
Old 12-31-2012, 11:08 AM   #42
simon.w
Drives: 2011 2SS RS 6M Inferno Orange
Pm price please
simon.w is offline   Reply With Quote
