Gen5DIY
Go Back   Camaro5 Chevy Camaro Forum / Camaro ZL1, SS and V6 Forums - Camaro5.com > Marketplace > Members Classifieds - Parts for sale or wanted > Forced Induction
Old 12-11-2012, 07:26 PM   #1
madskater5
Drives: GTO
WTB: 6 rib 3.6 Maggie pulley
As it says. Any help is appreciated. I've seen pullies of all sizes go for about $50, so that's what I expect to pay. Funds are in paypal, just waiting to be sent to someone...
madskater5 is offline   Reply With Quote
Old 12-11-2012, 07:31 PM   #2
2SS45th
2SS45th's Avatar
Drives: 11 Seconds or Faster
Is that the stock size on the blower? If so, I'll sell ya mine.
I Ain't About That Stock Life.
2SS45th is offline   Reply With Quote
Old 12-11-2012, 07:37 PM   #3
Supercharged SS
Drives: 2010 Camaro
They come with the 3.8.
Old 12-11-2012, 10:57 PM   #4
2SS45th
2SS45th's Avatar
You want a 3.8
Old 12-11-2012, 11:00 PM   #5
Supercharged SS
Drives: 2010 Camaro
You want a 3.8
My car has never even seen a 3.8! I started with a 3.4 back in 2009.
Old 12-11-2012, 11:11 PM   #6
2SS45th
2SS45th's Avatar
I'm starting with a 2.75 I don't need to have a mountain of pullies laying around!
Old 12-11-2012, 11:14 PM   #7
Supercharged SS
Drives: 2010 Camaro
I can't afford a 10 rib. :(Nitrous jets are cheaper.
Old 12-11-2012, 11:15 PM   #8
2SS45th
2SS45th's Avatar
I'm looking for a 10 rib off the bat, but might go 8 rib in the end. I agree, jets are always the way to go
Old 12-11-2012, 11:19 PM   #9
Supercharged SS
Drives: 2010 Camaro
The 8 rib is junk. You won't make the boost you want with it. LPE 10 is your best chance. I can only make a consistent 16 psi at sea level with the 8 rib. If I keep the blower ill try the 10. When I go down to my RIP 3.2 pulley I see near 18 psi but its slips all over the place and the car goes slower.
Old 12-11-2012, 11:34 PM   #10
2SS45th
2SS45th's Avatar
Doesn't IW have a 10 rib? That LPE stuff is spendy.
Old 12-11-2012, 11:37 PM   #11
Supercharged SS
Drives: 2010 Camaro
IW does but the LPE stuff is a different design. Much much better belt wrap. Plus you get a 10 rib water pump. With the IW you have to hope you can swap the pulleys out. The LPE is also anodized. I've actually worn the non anodized pulleys out. The ribs get pointy. In my discussions about going in this direction the consensus was, for me anyway, LPE or leave it alone.
Old 12-11-2012, 11:49 PM   #12
2SS45th
2SS45th's Avatar
Makes sense, LPE makes great stuff, can't really go wrong with that stuff. I know that the fuel pump I got from them is sweet.
Old 12-12-2012, 10:52 AM   #13
AngelSpeedFreak
Most hated in NM....
AngelSpeedFreak's Avatar
Drives: Sold the 6POINT2, went to a 50THZ06
In CO you will need it I run a 2.8 and only get about 9psi max.
OP - I might have a 3.6 (I think I do), I will check when I get home. I have collected a lot of these things over the last year.
Also dont forget you will need a new belt....
AngelSpeedFreak is offline   Reply With Quote
Old 12-12-2012, 02:28 PM   #14
madskater5
Drives: GTO
Plenty of belts around where I live, but if you have the pulley and an extra belt in the right size (I forget what I need at the moment. I THINK I have a 101.5 now, so it would have to be a little bigger.) I'll just take both.
A little backround here...its on a gto, not a camaro. They start underdriven with a 3.2 up front. I'm going over driven with the 3.6. More boost and more belt wrap. Ill have to cut a smidge out of an underhod brace, but that is no great thing. The overdrive is already on with a rich and much timing pullled safe tune until I get this 3.6. I have also been considering a 3.7 though, so I guess its whatever turns up first. I did hit it once as it sits, and it peaked at about 14.8lbs (3.2 front, o/d rear, stock crank)
I came here for the pulley since no one on a gto board has it. Since we start with the 3.2, no one collects any larger than that.
