SDTW Custom Wheels & Tires
Old 12-12-2012, 09:12 AM   #1
jimbumbee
Drives: 2014 Summit White SS/2SS/RS/1LE
vent valve solenoid ???
car is a 2012 SS LS3 MN6 T3 with 5000 mi....went to leave work yesterday, check engine light came on...went straight to dealer, they said my vent valve solenoid was leaking...they replaced it under warranty..all is good so far...what is it and what does it do ?? thanks..jim.
jimbumbee is offline   Reply With Quote
Old 12-12-2012, 10:20 AM   #2
jimbumbee
thanks...
thanks SC2150 for the info....
Old 12-12-2012, 11:39 AM   #3
JohnnyBfromPeoria
JohnnyBfromPeoria's Avatar
Drives: 2012 LS M6, Black
Yep, like SC2150 said. Gas tank fumes are routed to the charcoal canister, then when the car senses proper running conditions it opens the valve to allow those fumes to be drawn in and burned via the intake manifold.
John B.
12 LS M6, IPF S/C, ASA GT-5 wheels, VMax PTB
1995 Mitsubishi Montero SR
1987 Dodge Raider Turbo Project
1986 Mitsubishi Montero 2.4l FI Transplant
JohnnyBfromPeoria is offline   Reply With Quote
Old 12-13-2012, 09:47 AM   #4
Chevrolet Customer Svc
Drives: GM Vehicles
It is definitely great to hear that they covered this under warranty! What is the name of the dealership? I am sure they would love the praise on Camaro5!
Brandon
Chevrolet Customer Service
Old 12-13-2012, 12:34 PM   #5
Camaro588
Drives: 2012 camaro LS
your the the 6th person including myself that have had this issue pop up on this forum. Could be something for other members to keep an eye on.
Camaro588 is offline   Reply With Quote
Old 12-16-2012, 05:09 PM   #6
firestone_ss
firestone_ss's Avatar
Drives: 2010 camaro ss
all vehicles come with a federally mandated 8yr/80000 mile emission componet warranty,most people dont know this doesnt matter if your original owner or not,
firestone_ss is offline   Reply With Quote
Old 12-16-2012, 06:51 PM   #7
Russell James
Russell James's Avatar
Drives: '69 Z28, '10 NASA TA2, '15 1LE SS
Location: In the garage fixing stuff, track breaking stuff, at work paying for stuff. Or check the bar.
The 8/80 is only for the Cats,PCM,ECM,TCM.
All other emissions components have a federal emission warranty of 2/24.
The bumper to bumper is 3/36, so actually the federal emission warranty is now meaningless. The evap sol. would fall under the 3/36 after the 2/24 expires.
....worked at a dealer for a while, had to memorize all that chit.
Old 12-23-2012, 03:49 PM   #8
firestone_ss
actually if you make your case all emission componets are covered,the key words are possible damage to converter,and since the only reason the check enigne light in obdII systems is supposed to illuminate is for emission failures that may damage the converter in the first place is to its an easy argument to make,but most manufactures have added so much other crap that the initial laws regarding OBDII get lost,its all about the envirement and less pollution,as funny as that is in the end
Old 12-23-2012, 04:10 PM   #9
TAPSHIFT
TAPSHIFT's Avatar
Drives: '11 IBM 2SS/RS '16 1GB Z51 ragtop
Warranty service
Brandon
You're surprised that a minor issue with a 2012 would be covered by the factory warranty and that a dealership would be competent enough to fix it ????
Well....perhaps the second part might be surprising I suppose...
TAPSHIFT is offline   Reply With Quote
Old 12-24-2012, 08:14 AM   #10
Drives: GM Vehicles
I just wanted to relay the praise. Everyone deserves good news where it is due.
Brandon
Old 12-24-2012, 08:22 AM   #11
wadew2lt
U.S. Army Veteran
wadew2lt's Avatar
Drives: 2LT/RS SGM M6 Polished 20's
Brandon
I agree!
And speaking of which.....
I had what I considered a VERY small scratch/crack on the face of my radio. When I showed it to the dealer, they said, "No problem, we'll replace it...covered!" And they did.
Independence Chevrolet of Bloomsburg, PA.
Great guys there!
wadew2lt is offline   Reply With Quote
Old 05-24-2013, 05:06 PM   #12
Cornflakes'Camaro
Counting down the days...
Cornflakes'Camaro's Avatar
Drives: Black 2011 2SS/RS
does anyone know the part number for the EVAP solenoid? I need to replace mine, and I would rather stay away from a dealership.
AAC Amber Halo's///LSR Short Throw Shifter///BMR Front & Rear Sway Bars///BMR Lowering Springs///Airaid CAI///BBK Headers & Mid-Pipes///Borla Exhaust///Martin Smallwood Custom Cam w/ Support Mods///Tick Performance Dyno Tune///Port&Polished LS3 Heads///Elite Engineering Catch Can///Gen5DIY Separate Clutch Reservoir///Harwood 5" Cowl Induction Hood
Cornflakes'Camaro is offline   Reply With Quote
Old 05-24-2013, 06:18 PM   #13
TooCool5
TooCool5's Avatar
I don't know if you want to do that, you have to drop the sub frame and tank.
OOOuch
Old 05-26-2013, 12:21 PM   #14
NFERNOSS
Drives: Inferno Orange 2SS
OOOuch
Originally Posted by SC2150 View Post
Agree w/toocool.
Not an easy job in the driveway.
Ask around for a good dealer service department and you will be in good hands.
Only have to drop subframe on the 2010's, as the whole canister with old style valve got replaced as an assembly, fuel tank doesn't get touched though. In 2011 they change the design of the vent solenoid. I can take the two bolts out that hold the canister down, position it, then reach up there through the control arm and twist the solenoid out with one hand. Reverse procedure to install.
NFERNOSS is offline   Reply With Quote
