Old 12-15-2012, 07:22 PM   #1
onebad1le
Drives: 2013 1le
onebad 1LE MODS
Well just got my 1LE and now its time to start modding it.
My goals are 1 g in turns (done) 10 sec 1/4 mile -(might take some time)
and stop just as fast. and still maintain easy drive ability
my 1st mod was a drop in K/N filter and 2 mod is a one piece drive
shaft from drive shop -its 3.5 inch all aluminum piece
the stock drive looks weak but is surprising light and (i know the last pick has a tool in there)
was torqing it to specs
onebad1le is offline   Reply With Quote
Old 12-15-2012, 07:37 PM   #2
onebad1le
Drives: 2013 1le
next mods to come
I am going to install headers and bought some used C5-ZO6 rims with mickey thompson tires to get some base line results from 1/4 mile results -the rims will be paint black to match my other rims
Old 12-15-2012, 07:41 PM   #3
ssmike
BliSSard has come!
ssmike's Avatar
Drives: '16 Camaro 2SS, '13 Equinox CRT
Looks like it'll be a real beast when you get done! Good luck!
ssmike is online now   Reply With Quote
Old 12-15-2012, 08:10 PM   #4
Fraxum
Fraxum's Avatar
Drives: 2016 SS M6
OP taken it to the 1/4 track yet?
M6, Pray Ported TB and MSD, E85, LTs, cats, Rotofab Dry, BMR Trailing Arms
Old 12-15-2012, 09:02 PM   #5
onebad1le
Drives: 2013 1le
1/4 mile
not yet wanted to get drive shaft installed first and get some good tires
maybe next friday get some base times.
Old 12-15-2012, 09:17 PM   #6
newb
newb's Avatar
Drives: 2013 1LE
Why no stock runs for a true baseline?
Sent from a rainbow while riding a unicorn
It's a Dingledarm. It's there to dampen side fumbling. If your marzelvanes fumble too much they can cause total protonic reversal. It gets ugly from there. This is really the biggest problem with the new Camaro. That and the tri-pronged blivot.
Delivered 21 Jan 2013
newb is offline   Reply With Quote
Old 12-15-2012, 10:03 PM   #7
tramtwo
tramtwo's Avatar
Drives: 2013 1LE
Go back and look at that question!!
He has the mod fever!
Good job op!
tramtwo is offline   Reply With Quote
Old 12-16-2012, 01:13 AM   #8
newb
newb's Avatar
Drives: 2013 1LE
I still want to see numbers from a production car in the hands of a consumer. Mod fever or not.
Old 12-16-2012, 01:19 AM   #9
tramtwo
tramtwo's Avatar
Drives: 2013 1LE
Good Luck
Old 12-16-2012, 01:55 AM   #10
King Nothing
Under a Freightliner
Drives: Sentra, Durango and Camaro
I agree with newb. True baseline is as it was picked up from the showroom floor
Sold-2006 Pontiac GTO
M6 1 of 475
353rwhp 353rwtq
2000 Camaro SS A4 Hardtop #867 of 8913
1 of 103 Bright Rally Red Hardtop SS A4 in 2000
LQ build, 243 heads and LS6 intake
King Nothing is offline   Reply With Quote
Old 12-26-2012, 06:53 PM   #11
onebad1le
Drives: 2013 1le
headers installed
Well just installed my headers with no cats on my NPP exhaust and man its sounds perfect. loud but not to loud. Now for dyno and then cam.
Old 12-26-2012, 09:24 PM   #12
PYROLYSIS
Remember the Charleston 9
PYROLYSIS's Avatar
Cool. We will need to see video when you're done.
Old 12-30-2012, 02:12 AM   #13
onebad1le
Drives: 2013 1le
headers installed
Well just went to the shop and got the car tuned -mainly to get the check engine light off and found out the stock rev limiter is at 6700 RPM and that the tables are similar to the ZL1 . I will dyno the car when the shop get there new dyno installed in about 2 weeks and then i will have base line number before and after cam install.also 1/4 miles times when track reopens but for now just headers and drop in k/n filter the 1 st gear is worthless at full throttle-- car is very quick for such small things.
Old 01-31-2013, 09:53 PM   #14
onebad1le
Drives: 2013 1le
More mods
Well just installed (ls9) Cam and crank pulley and will dyno tune soon (HAD A problem with the wide band not working)
