HeadlightArmor
Old 12-17-2012, 03:09 PM   #1
Garys16SS
Garys16SS's Avatar
Drives: 2016 SS, BLACK, MANUAL
Automatic rear diff to 6 speed rear diff
I purchased an automatic 2013 ZL1 and I would like to remove the stock diff complete with 3.23s and purchase a 6 speed diff complete with 3.73s and install. Has anybody accomplished this and if they have, what problems may or may not have occured.
2016 Black/Black SS, 6speed, MRC, Roto-Fab air intake, Vitesse controller,
1 7/8" headers and exhaust from Stainless Works complete with nonNPP mufflers and 5"outlets, Katech ported TB, Moroso catch can, MRR M017 polished powder wheels, Eibach lowering springs, and BMR upper/ lower trailing arms and upper control arms. ZL1/1le sway bars and Magnusson Supercharger with Jannetty tune. Stay Tuned!!!......More to come.
Garys16SS is offline   Reply With Quote
Old 12-17-2012, 03:33 PM   #2
DangerZL1
Drives: Future ZL1 Owner
Wouldn't it be easier and way less expensive to order the 3.73 gears and have someone install them? The first gear auto is lower than the first gear in the manual, so I also wonder it this is a good idea.
DangerZL1 is offline   Reply With Quote
Old 12-18-2012, 07:48 AM   #3
Drew P
Drew P's Avatar
Drives: Camaro ZL1
What is your purpose for the swap?
Drew P is offline   Reply With Quote
Old 12-18-2012, 09:47 AM   #4
Stephen12ZL1
Stephen12ZL1's Avatar
Drives: '17 ZL1 A10
With the 6 auto tranny ratios that are present, you really won't gain much from this expensive swap. Concentrate on airflow mods, boost, cooling, and tune for more performance and you will find there is no need to swap rear ratios. If it were your typical 4L60E with only 4 speeds, then maybe a viable option.
'17 ZL1 A10 Mosaic Black PDR/Nav 2:08.35 VIR Full
'15 Z/28 #325 black a/c & stereo. 2:10.1 VIR Full 1:44.74 Summit Point Shenandoah Circuit (sold)
'12 ZL1 10.52@131 1.55 60' 2:13 VIR Full (sold)
Stephen12ZL1 is offline   Reply With Quote
Old 12-18-2012, 10:13 AM   #5
radz28
Petro-sexual
radz28's Avatar
Drives: Ultra-Grin
Or stab a little loser converter in there
05 Hummer H2 SUV on OEM Air Ride
Forged 11.4:1 408 LQ4 (K1 crank & rods; Mahle pistons)/CPP LS3 CNC heads/BTR Stage IV LS3 cam/home ported L92 intake manifold/ported 90mm TB/custom Volant CAI/Kooks 1 7/8" LTs and 3" H-pipe/AFE dual 3" CB/Corvette Servo/el cheapo lift/Cognito UCAs/Sphon poly adjustable TA/Sphon adjustable rear LCAs/e'fan conversion/DirtyMax radiator/Moroso catchcan/HPTuners/HID conversion/LED exterior lighting/LED interior accents/Autometer Cobalts/AEM WB/ Pioneer AVH-5600BHS/Pioneer GM-9601/2-Pioneer TS-W310D4s/Obcon Labyrinth dual-12 box/lots of other little stuff
Old 12-20-2012, 05:09 PM   #6
Garys16SS
Garys16SS's Avatar
The costs are not the question, but Stephen12ZL1 and radz28 have made some suggestions that are plausable which I appreciate. I already have a Roto-Fab and presently looking at the pulleys/damper/headers. And to answer Drew P, I run my "hobby cars " strong on the streets/highways and "stop lite to stop lite". According to RPM Transmissions, they advised just buying the ZL1 6 speed rear and they have customers doing that. I tried buying the Chevy 3.73 6 speed gears but there is not a price listed for them according to the local Chevy parts person. Starting the mods!!!!
Old 12-20-2012, 05:14 PM   #7
SS ORANGE CRUSH SS
SS ORANGE CRUSH SS's Avatar
Drives: Inferno Orange 2SS RS Convertible
You will get rid of the drone!?!?!
Likes to Cruise!!!!
SS ORANGE CRUSH SS is offline   Reply With Quote
Old 01-03-2013, 12:13 PM   #8
Dega Man
Drives: ZL1
Have you checked with Richmond for a ring & pinion gear set? 3.73 in the auto is just going to have you spinning a lot more off the line. The more HP you add to your engine the better off you will be with the 3.23 gearing in the auto.
Dega Man is offline   Reply With Quote
Old 07-25-2013, 08:55 AM   #9
Garys16SS
Garys16SS's Avatar
Unfortunately, I have a ZL1 diff from a 6 speed sitting in my "mancave" and my mind wanders with ideas.
Old 07-25-2013, 12:12 PM   #10
mrvenicess
mrvenicess's Avatar
Drives: 2013 CRT ZL1 auto
Gonna be revving like crazy on the hwy!
mrvenicess is offline   Reply With Quote
Old 07-25-2013, 12:29 PM   #11
SC2150
If you want to go quicker in the 1/4 mile get a good stall converter like the FTI triple disc.
