BeckyD @ James Martin Chevy
Old 12-18-2012, 06:11 AM   #1
CarlC1
Drives: 2012 Victory Red 1SS M6
SCT Itsx So what can we do with it
First let me say thanks to Ted and the guys at Jannetty. Teds been a big help with some decision making over the last week.
Ok so beside the basic code checking, tune loading, and data logging what else can we do with it? Is the LiveLink software worth downloading? I'm not that much in the know on tuning but reviewing my datalog cant hurt.
Carl
2012 1SS 6spd Victory Red- Rapid Dominator 2X cam, kooks 1 7/8 x 3 headers, Kooks high flow cats, Airaid intake, AI 280cc heads, 72# injectors, Vmax tb.
507 rwhp/449 max torque SOLD
CarlC1 is offline   Reply With Quote
Old 02-26-2013, 08:37 PM   #2
OmniCamaro
US Veteran
OmniCamaro's Avatar
Drives: 2011 Silver Ice Metallic 2SS/RS A6
Carl
Valid questions I'd like to know myself. Google here I come I guess!
Dear Lord, give me the strength to carry on despite my Camaro addiction!
JRE iTSX tune, full cat-less Dynatech exhaust, CAI intake, Stillen Slotted/Drilled Rotors, RB braided brake lines, BMR lowering springs, (reserved for definite future MODS)
OmniCamaro is offline   Reply With Quote
Old 02-26-2013, 08:47 PM   #3
Supercharged SS
Drives: 2010 Camaro
Carl
iTSX / TSX for Android Wireless Vehicle Programmer NEW! Live Link GEN II Data Logging SoftwareVersion: 2.1.6.0Release Date: 01-07-2013Description: SCT's Live Link Datalogging Software is used to view / data log / record & playback your vehicles PCM data on a laptop computer. Notes:
New features in this version include:
- Enhanced charts, including floating scales
- Updated database
- Calculated PIDs
Changes to this version include:
- New iTSX and Livewire TS support
- Database updates and support for new vehicles such as for Ecoboost 2.0L, 6.4L, 6.7L, and GM vehicles
- Many UI enhancements including cleaner charts, navigation buttons, faster histogram refresh rate, playback speed controls, floating windows, etc.
- Unit enhancements including unit conversions in DLF, CF4 and DLX files
- New merge configuration files feature
- Better analogs processing and support for up to eight analog signals
You need Live Link to log with the SCT handheld and I assume you'll need it to log with the ITSX. If that's the case then you'll need it.
Old 02-26-2013, 08:48 PM   #4
OmniCamaro
US Veteran
OmniCamaro's Avatar
Got this info right from the SCT website:
PRE-LOADED TUNE FILE ADJUSTABLE OPTIONS:
* Adjustable Options vary for each vehicle and are not available on all vehicles
Rear O2's Disabled
Disables the Rear O2s and eliminates CEL caused by rear O2 removal.
Fuel Injectors
Allows you to adjust for different sized fuel injectors.
CMCV Delete Plates
Allows you to disable the CMCV (Charge Motion Control Valve) in your vehicles PCM to prevent a Check Engine light and other issues associated with removing the CMCV plates in your vehicle.
Speed Limiter
Allows you to Remove, Increase or Decrease the vehicles speed limiter.
Idle Speed
Allows you to Increase or Decrease the vehicles idle speed.
Traction Control
Allows you to disable the vehicles Traction Control without using the button in the vehicle.
Spark Modification by RPM
Allows you to Add or Remove Timing by RPM Range. (0-2000)(2000-4000)(4000-8000)
WOT Fuel
Allows you to Add or Remove Fuel at Wide Open Throttle.
Shift Firmness Control
Allows you to change the transmissions shift pressure. Controls how firm the shifts will feel. * Vehicles with Automatic Transmissions ONLY
Axle Ratio
Allow you to set the axle ratio (gear ratio) to correct shift patterns and the speedometer on your vehicle.
Tire Size
Allows you to set the tire size to correct shift patterns and the speedometer on your vehicle.
Aftermarket Intake
Allows an aftermarket intake to be run on the vehicle without a Check Engine Light. For Intake Kits that require tuning, this will provide a selection of available intake kits.
Stores Stock Tune
Stores a true copy of your vehicle's stock file before programming. Used for warranty repairs and unlocking the programmer.
Supports Custom Tune
Supports and holds up to 3 custom tunes.
Fan Control
Lowers the Temperature at which the Fan turns on.
CUSTOM TUNE FILE ADJUSTABLE OPTIONS:
Idle Speed
Rev / RPM Limiter in Drive
Allows you to Remove, Increase or Decrease the vehicles Rev / RPM limiter in Drive
Rev / RPM Limiter Neutral
Allows you to Remove, Increase or Decrease the vehicles Rev / RPM limiter in Neutral
Speed Limiter
Fan Control
WOT Fuel
Axle Ratio
Tire Size
WOT Shift Points by Gear
Allows you to Increase or Decrease the Wide Open Throttle Shift points of each gear individually.
