JUICEDMOTORSPORTS
Old 12-18-2012, 08:21 PM   #1
SSSoon
SSSoon's Avatar
Drives: RY 2011 2SS A6
Do we actually need front brake dust shields?
Sorry, posted this in the wrong section before.
Been thinking about better brake cooling for when I am on a road course. It would seem that you'd get a lot better cooling if the dust shield wasn't there on the fronts. Has anyone just removed them? Pros and cons?
Dry sump LS7, cage, JPSS suspension, Wilwood brakes, fire suppression, ARH 3" headers/exhaust, Z/28 DSSV coilovers, Kirkey seats, TeamTech 6-point harnesses, 19" Forgeline GA3R, 325/30R19 Re11 tires, oil cooler, monster JPSS splitter/wickerbill, CAI, brake ducts.
SSSoon is offline   Reply With Quote
Old 12-18-2012, 08:22 PM   #2
Mr. iNCREDIBLE
Mr. iNCREDIBLE's Avatar
Drives: 2012 2SS/RS Convertible
we have dust shields?
then why the frack are my wheels full of dust 5 minutes after I wash them?
I'm only responsible for what I say, not for what you fail to understand.
Mr. iNCREDIBLE is offline   Reply With Quote
Old 12-18-2012, 08:28 PM   #3
SSSoon
SSSoon's Avatar
Here's a pic from another thread of a guy who routed a brake duct through it. It's kind of behind the rotor. Trying to figure out if taking it off would help and if so, if there would be any negative consequences.
Old 12-18-2012, 10:54 PM   #4
JusticePete
JusticePete's Avatar
Drives: Camaro Justice
You have tracked you car already, correct? Is the coating on the shield blistered from heat?
That will work
Old 12-19-2012, 12:11 PM   #5
SSSoon
SSSoon's Avatar
That will work
Have not really looked at the shield - will have a look though.
Is the "dust shield" really a heat shield that is there to stop things like brake hoses from melting? I'm on braided stainless but am still wondering what possibly negative effects effect taking off the shield would have. Wonder why GM put it there
Old 12-19-2012, 12:17 PM   #6
JusticePete
We literally melted and blistered the paint off them on the PUSA Camaro. We thought about ducting , there was no brake fade and then just took them off. Check the condition of yours. If they look good leave everything alone. If they are being overheated, you are driving fast enough to benefit from ducting.
Old 12-19-2012, 12:22 PM   #7
Mr. iNCREDIBLE
thanks I was being sarcastic..
Old 12-19-2012, 03:35 PM   #8
SPCBA
Drives: pleather and Chiclets
it looks like his started to blister at some point.
SPCBA is offline   Reply With Quote
Old 12-19-2012, 04:06 PM   #9
JusticePete
That is a good thing. It means you are using your 5th Gen well! If you are planning to be faster and run more track days installing ducts is a good idea. Before you do that, are you experiencing brake fade?
Old 12-19-2012, 07:59 PM   #10
carrs_crew
Livin the Dream
carrs_crew's Avatar
Drives: sold
would brake ducts using the complete zl1fascia with inner wells and ducts be enough or would I also need to exhaust the heat as well?
carrs_crew is offline   Reply With Quote
Old 12-19-2012, 08:03 PM   #11
JusticePete
The ZL1 ducting will do the job until you move from track days car to race car
Old 12-19-2012, 08:08 PM   #12
Synner
Drives: not stock
What I've been wondering is will the ZL1 fender liners work with SS fascia? And do they provide any extra tire clearance? I've heard that stated once but haven't seen anything definitive.
Old 12-19-2012, 10:02 PM   #13
JusticePete
I haven't tried a retro fit, but it sounds like someone will... soon.
Old 12-19-2012, 11:43 PM   #14
carrs_crew
Livin the Dream
carrs_crew's Avatar
Drives: sold
there is a portion of the well that extends under the front fascia that is screwed to the front. The ss fascia does not go as deep as the zl1 fascia. as for tire clearance, when I installed I didn't notice any extra room. the wells "bolt up" inside the wells at the same spots. Hope my wording was not too difficult to understand
