Emblempros
Go Back   Camaro5 Chevy Camaro Forum / Camaro ZL1, SS and V6 Forums - Camaro5.com > General Camaro Forums > Chevy Camaro vs...
Old 12-19-2012, 01:56 AM   #1
bada450r
Drives: 2011 2ss blk on blk convertible
What would it take to beat 2002 ls1 built/spray
So what would It take to beat in the 1/4 mile a built 2002 ls1? Built auto trans. Stoke bore/stroke.also giving it a 150 to 200 shot.
That would be with a SS 5th gen Camaro. Any input would be great
2011 2ss black on black, v3 blown hauling ass and burning gas.
bada450r is offline   Reply With Quote
Old 12-19-2012, 07:45 AM   #2
VADER SS L99
VADER SS L99's Avatar
Drives: 2013 A6 GT 5.0
If you are a M6 it will take a ton of parts. Heads, cam, LT headers, supercharger, and or nitrous. Clutch, 9inch rear, full suspension, 18inch or smaller wheels with drag radials or slicks. Most importantly a big time driver mod. If that 02 LS1 is not running mid 10's or better in good DA I would be very surprised.
Old 12-19-2012, 11:32 AM   #3
Neal@NitrousOutlet.com
Drives: The Blue Vert
It sounds like the car has some good money into it. It could honestly be a 9 second car on spray. and a 10 on motor. Depends on what the set up is.
Neal@NitrousOutlet.com is offline   Reply With Quote
Old 12-19-2012, 12:59 PM   #4
bada450r
[QUOTE=Neal@NitrousOutlet.com;5934934]It sounds like the car has some good money into it. It could honestly be a 9 second car on spray. and a 10 on motor. Depends on what the set up is.[/
Wow, no wonder this guy with the ls1 is talking big money.....thanks....we plan on going to famoso on track days in feb of next year.....I'll have a cam and maybe I'll be spraying.....but I'll sit watch and learn a thing or two, and work on my driver mod.
Old 12-20-2012, 09:22 AM   #5
Bad70supreme
Bad70supreme's Avatar
Drives: 2010 aqua blue SS/RS M6
You have no chance in h$ll with just a cam! That car should be mid 11s on motor VERY easy with 10s possible depending on the rest of the setup!
Maybe 9s on the spray!!!
Your 5th gen...
Cammed
17" rims with a real slick
200 shot spray
You have gears already so thats good
good axles
one piece drive shaft
If you can launch the h$ll out of that thing and drive well, then you have a fighting chance. With a cam and spray you have a 10 sec car, but will it actually run 10s is a hole different story.
10.91 at 122 H/C stock block N/A
Bad70supreme is offline   Reply With Quote
Old 12-20-2012, 09:26 AM   #6
SSOOCH
Camaro SL,UTs
SSOOCH's Avatar
Don't forget a 4th GEN weighs a lot less than a 5th GEN as well.
Old 12-20-2012, 09:48 AM   #7
dekan513
chevy pride
dekan513's Avatar
Drives: 2ss/rs
yep 4th gen are monsters on the track.
check out ky speeds fb page https://www.facebook.com/kyspeed
dekan513 is offline   Reply With Quote
Old 12-20-2012, 01:35 PM   #8
casper sc/1ss/rs
casper sc/1ss/rs's Avatar
Drives: 2011 camaro ss vortech supercharged
and with better aerodynamics also imo.
casper sc/1ss/rs is offline   Reply With Quote
Old 12-20-2012, 03:21 PM   #9
bada450r
I'm in the process of replacing my drive shaft and axels, I'll also be doing a cam. My complete mod list would hopefully be as follow from here to feb of next year.
1.4:11 gears
2.trailing arms and tie rods
3.axels and drive shaft
4.305/35/19 drag radials m/t
5.cam DONT know which one..tsp 231/236 or night fury
6.h&r lowering springs
7.bassani lt and full exhaust
8.sct tuned
9.cold air inductions intake
10.ported throttle body and intake
11. Ported stock heads if I have the dough
I'll also be a getting a KB so I'll really have to do my homework see what cam would work best with that set up..... $$$$$$$$$$$ wife not likey the Camaro
Old 12-20-2012, 05:49 PM   #10
VADER SS L99
You are going to need a strong clutch, 18inch drag radials at a minimum like a 305/45r18, maybe even a 16 or 17inch slick. Forget 4.11 gears with a blower. You will run out of gear in 4th not to mention have no 1st gear traction. Leave the 3.45's or do 3.70's. Whipple is a much better blower than KB so I would recommend that one instead. With your mod list plus my alterration recommendations you will have a chance IF you can drive REALLY well.
Old 12-20-2012, 05:54 PM   #11
Supercharged SS
Drives: 2010 Camaro
Just to piggy back on this. The fastest stick car (Gen5) that I am aware of, I'm sure someone has gone quicker, has every part available, makes over 800 rwhp and is a 10.48 car. Take that for what it's worth but it's very difficult to get the M6's to go fast. In an auto, I make 733 and ran a 9.81 with the stock suspension. Just goes to show ya! Good luck!!!!!!!!
Old 12-20-2012, 09:22 PM   #12
VADER SS L99
Yeah I was trying to say his chances are slim even with all those parts while still being nice about it. Furthermore the guys I know of who are really fast in a stick car will tell you to have at least 1 spare trans, clutch, and rearend because its not a matter if something will break but when. Really hard and EXPENSIVE to go fast in a stick car.
Old 12-20-2012, 09:27 PM   #13
Supercharged SS
Drives: 2010 Camaro
Exactly. He's better off fighting that dude in the pits!
Old 12-21-2012, 01:26 AM   #14
Detoxx03
ЯєŧąяĐ Єlímíиąŧ°я Ö
Detoxx03's Avatar
Drives: 2008 Corvette
Better gather your coins cause its gonna take a lot to beat that f body.
D1SC Procharger 932/758 on E85
A Futral Motorsports Creation
https://www.facebook.com/DetoxxAtomic
Detoxx03 is offline   Reply With Quote
