Old 12-19-2012, 11:21 PM   #1
SinisterEcho
SinisterEcho's Avatar
Drives: 2010 2SS/RS M6/LS3
19x10.5 wheel offsets
I'm looking to get a new squared set of wheel for my car that are lighter than the stock wheels. Something like the TSW Nrings or Forgestar f14's. I know a I have seen a few people run this setup but can't seem to find the correct offsets to prevent any rubbing or interference with the wheel/tire and anything else on the car. Any help in finding this out will be greatly appreciated.
Oh.. I'm also lowered about 1.5" all around as I'm sure that makes a difference and will be getting aftermarket swaybars soon. Thanks again!
My Mod Journal <-- Its updated... again!
SinisterEcho is offline   Reply With Quote
Old 12-20-2012, 10:10 AM   #2
SinisterEcho
Anyone?
Old 12-20-2012, 10:49 AM   #3
carrs_crew
Livin the Dream
carrs_crew's Avatar
Drives: sold
Without someone who owns the Romans measuring for you, most people will not give up that info unless they are the ones who are producing them, asked that same question months ago to some vendors, I respect that. You might find the info on the manufacturers website
carrs_crew is offline   Reply With Quote
Old 12-20-2012, 11:04 AM   #4
SinisterEcho
Thanks. Thats what I was figuring. The vendor that Ive spoken to cant verify if their wheels will fit with this configuration on a 27mm offset. I may have to drop the size down to a 19X10.... wich wouldnt be too bad... but i really want the 10.5 wide.... ill keep looking around....
Old 12-20-2012, 11:25 AM   #5
grocerygetter
instigator
grocerygetter's Avatar
I have 20x10 with a 35 offset. It works fine with up to 1-1.5 deg of neg camber....275 nitto nt05s. 27 is going to be 8mm further to the outside of the car. I would say that would probably put the edge of the rim lip flush with the fender if you drew an imaginary line at 12 oclock. It would probably look similar to the ZL1 offset which sticks out more than mine. I don't know about the 10.5...but quick math says 25mm offset for 10.5 is needed. If my math is correct you could roll with it and it if rubs the strut use a 5mm spacer. This will limit your tire width though....I'm not sure what to. You need someone else in here.
-John S.
Thanks to:
Tony@ dv8motoring
TCAudio in Benton AR
Old 12-20-2012, 12:35 PM   #6
SinisterEcho
Thanks for the input! Wheel offsets and what not are all new to me....
Old 12-20-2012, 12:37 PM   #7
2SS45th
2SS45th's Avatar
Drives: 11 Seconds or Faster
Maybe talk to LPE, they put 10.5s all the way around on the L28 car. Don't know if they'll give that info out, but it is worth a shot.
I Ain't About That Stock Life.
2SS45th is offline   Reply With Quote
Old 12-23-2012, 08:17 PM   #8
madmaxx18
madmaxx18's Avatar
Drives: 07_tundra/08_zo6
I wonder if the TSW nurburgrings 19 10.5 et27 fit in the front of the car? anyone tried this yet?
madmaxx18 is offline   Reply With Quote
Old 12-24-2012, 06:01 PM   #9
Avalnch
Avalnch's Avatar
Drives: Rally Yellow Camaro+Avalanche
The problem with TSW and Forgestar is that they do not make custom offsets. You buy what they got. You should be sending your question to them. If they can't give you a definitive "YES", then go some where else (like Forgeline).
Vengeance Kaotik Cam, C.A.I., ARH LT, Pypes Cat Back, ZL1 Shifter+2012LS3VERT bushing, Quantum Brake Ducts, JDP Tow Hook Scorch Yellow Trim Kit, Shark Fin, AAC DRLs+ABLs+SMDs, ZTA Rear Spoiler, R.Y. 1LE Splitter. Pfadt coilovers, camber plates, trailing arms, Pegasus Solid Subframe. Pedders ZL1 barz, radius arm & steering rack bushings. BMR adjustable toe-rods. Hotchkis Max Chassis Brace. ZL1 GMPP Driveline Upgrade. TurnOne P/S pump.
447 HP @ 6180 RPM / 418 TQ @ 5100 RPM
Avalnch is offline   Reply With Quote
Old 12-24-2012, 06:20 PM   #10
edneyens
edneyens's Avatar
Drives: 1SS/RS/M6-White/Beige
I have 20x10 +40mm offset wheels all the way around with 275 tires on front and 305 on back.
I had a minnor issue inthe front where I had to restrict the camber setting to - 1/2 degrees or risk some tire rubbing on the strut tower until I replaced the lowering springs with Pedders Coil Overs.
The Pedders Coil Overs give you 10mm widder tracking per side. Having this extra clearance I can now get the more agressive camber settings like Grocerygetter talked about in his post (neg 1 1/2 degrees).
So if you are running stock struts with lowering springs look for wheel offsets of +30 to +20 in the front, if you have or will get a coil over suspension (Pedders or Phadt) offsets of +40 to +30 is what you should be looking for...
Hope this helps.
Note: A 10 inch wheel verses a 10.5 wheel with the same offset will not change clearances seen by the same size tire, being the tire when properly sized for wheel is always going to be wider than the wheel and therefore it determines the clearance you have.
edneyens is offline   Reply With Quote
Old 12-24-2012, 07:46 PM   #11
madmaxx18
madmaxx18's Avatar
so these will work TSW nurburgrings 19 10.5 et27 since i have coil overs ? on all 4 corners?
Old 12-24-2012, 09:04 PM   #12
Synner
Drives: not stock
Buy some and let me know, I don't want to spend 5k for forgelines. LOL.
Old 12-25-2012, 12:27 AM   #13
grocerygetter
instigator
I don't know for sure but my fear wouldn't be the front...it would be the rear hitting the fender with a 27. You can adjust height I guess.
-John S.
Thanks to:
Tony@ dv8motoring
Old 12-25-2012, 12:38 AM   #14
47AJV8
Drives: A White Car
I sometimes use carid(.com) to find rims that will fit, unfortunately they aren't ones for precise specs which is a pain but supposedly they will only show you rims with the correct offsets and such to fit your car, hope that helps.
"From ABS shudder that came on surprisingly early in the lousy brake pedal's travel to a looser rear end than Kim Kardashian"
47AJV8 is offline   Reply With Quote
