Gen5DIY
Go Back   Camaro5 Chevy Camaro Forum / Camaro ZL1, SS and V6 Forums - Camaro5.com > General Camaro Forums > Chevy Camaro vs...
Old 12-20-2012, 10:55 AM   #1
willhe64
willhe64's Avatar
Drives: 2012 45th Vert, 2011 4x4, 9sec Vega
ZL1@15psi vs. GT500
I was surprised to read that the GT500 runs 15pounds of boost. No wonder it has a HP advantage. Doesn't leave much room for improvement though.
If you jacked a ZL1 up to 15psi it would walk all over the GT500. Am I correct?
I feel it only fair to warn you, I have a black belt in CAPS LOCK.
willhe64 is offline   Reply With Quote
Old 12-20-2012, 12:06 PM   #2
Stew
Drives: 92 Luminadead/01 Dakota/97 F150 4x4
The ZR1 runs 10.5 PSi for 638 HP, but is stronger internally than the LSA. GM will NEVER put the boost up to 15 for reliability reasons and I am sure to safely handle it, it would need to be beefed up, so we are in a modding war and there is no fair comparison, we might as well be saying the GT500 needs .4 liters of displacement.
Stew is offline   Reply With Quote
Old 12-20-2012, 01:26 PM   #3
casper sc/1ss/rs
casper sc/1ss/rs's Avatar
Drives: 2011 camaro ss vortech supercharged
casper sc/1ss/rs is offline   Reply With Quote
Old 12-20-2012, 02:14 PM   #4
_Nick_
Drives: '87 T/A, '87 IROC, '70 Grand Prix
Maybe once, but the GT500 will make it home.
_Nick_ is offline   Reply With Quote
Old 12-20-2012, 03:10 PM   #5
VADER SS L99
VADER SS L99's Avatar
Drives: 2013 A6 GT 5.0
A more accurate comparison would be to bolt on a TVS 2300 and spin the blower at the same blower rpm as the GT500. Since the GT500 is a 5.8 liter 15lbs on it may only be 13lbs give or take on a 6.2 with a TVS2300. Of course the ZL1 would have to have a better heat exchanger and intercooler to handle the added boost but the motor could totally take it. Boost is just a measure of restriction.
Old 12-20-2012, 04:03 PM   #6
LimaCharlie
LimaCharlie's Avatar
Drives: 2011 Camaro SS/RS - 2004 Silverado
The GT500 has a bigger supercharger (2.3, compared to the ZL1's 1.9). I don't think 15 PSI is possible with the small 1.9 blower on the ZL1. If it is possible, it won't be reliable.
2011 Summit White Camaro 1SS/RS
-6.2 LS3, TR6060, 3.45, G80
2004 Black Silverado 1500 2WD Regular Cab, Short Bed
-5.3 LM7, 4L60E, 3.42, G80
LimaCharlie is offline   Reply With Quote
Old 12-20-2012, 04:18 PM   #7
trademaster
Drives: 12 MP4-12C, 16 Quattroporte
The blower on the ZL1 would just be blowing hot air at those boost levels. You would need the bigger 2300 that is on the LS9. Even then, you have to consider why GM would use different internals in the LS9 if it were as simply as just pumping up the boost and having a 640hp LSA with stock reliability.
trademaster is offline   Reply With Quote
Old 12-20-2012, 05:15 PM   #8
ace32x
Drives: 2013 ZL1
where are you guys getting this information lol? people are running 15 psi on zl1s and cts v's all over the place. the lingenfelter 2.38 upper pulley is about 15 psi. people are seeing upper 600's with minor bolt ons and 15 psi of boost wether it be the upper or lower pulley. the zl1 stock rods are good for over 700whp. theres people running around with a cam and bolt ons making 730 on the stock blower.
2013 victory red zl1, 2012 1500 silverado, 95 nissan 240sx 383 ls1 11:1 stroker dart 225 heads ms4 cam fast 102 manifold ;D
ace32x is offline   Reply With Quote
Old 12-21-2012, 03:03 AM   #9
mikeSS
mikeSS's Avatar
Drives: 2015 c7
i would take the 15 PSI stock and under warranty than a modded ZL1 tuned/modded to keep up with a stock GT500 .
Old 12-21-2012, 08:34 PM   #10
BLACK10
BLACK10's Avatar
We 15+psi on a few Zl1s. That's perfectly safe on the LSA. Heck we run 15psi on the LS3s. Many passes at the track with no issues.
Old 12-21-2012, 08:39 PM   #11
sycraft
COTW 5/06/2013
sycraft's Avatar
Old 12-22-2012, 10:14 AM   #12
WHAMMO
WHAMMO's Avatar
Drives: 13' 1LE
Originally Posted by sycraft View Post
While this GT500 is badass, I dont see the point of it in this thread since it has nitrous(how much of a shot I dont know)...
Some plp got away on a stock bottom LS1 with a 300shot BTW.
TSP 231/236 111 lsa cammed 1LE
WHAMMO is offline   Reply With Quote
Old 12-22-2012, 10:16 AM   #13
sycraft
COTW 5/06/2013
sycraft's Avatar
that pull was without the nitrous and boost turned up
Old 12-24-2012, 12:51 PM   #14
WHAMMO
WHAMMO's Avatar
Drives: 13' 1LE
ahh
