SDTW Custom Wheels & Tires
Old 06-10-2009, 08:49 AM   #1
My First Camaro!
My First Camaro!'s Avatar
Drives: 03Dakota4.7 1SSLS3RS
Question Carbon Fiber Drive Axle
Hi everyone first post so please take it easy ok? Has anyone played around with carbon fiber drive axles?
My First Camaro! is offline   Reply With Quote
Old 06-10-2009, 10:55 AM   #2
CamaroSpike23
Truth Enforcer
CamaroSpike23's Avatar
yes. they are cool, lightweight, and expensive.
ive used them on full race cars before and blown them up. good part tho was that it doesnt damage things under the car as badly. but i'll stay with steel/aluminum for mine
I piss excellence
and fart awesomeness
Old 06-10-2009, 11:09 AM   #3
My First Camaro!
I would like to see how much gain you would get in rev speed/tq compared to your $$$. My concerns are:
1. Heat-how much heat is going to transfer from the exaust/heat soaked pavment?
2. Duribality- how many miles before it fails?
Any suggestions on what company to avoid?
Old 06-10-2009, 11:27 AM   #4
CamaroSpike23
Truth Enforcer
heatsoak isnt as big an issue as some might think. having a spinning shaft allows for heat transfer.
for durabilty.... thats not fully capable of being tested via number of miles. its more of the power you are applying thru it as well as the shocks/vibrations that get sent thru it
I piss excellence
Old 06-10-2009, 11:48 AM   #5
My First Camaro!
That's about what I though. I'm not going for anything extreme. I like the idea of a sleeper. If I had someone built it to 600 ft pounds it would be right in line with the TR6060.
Old 06-10-2009, 11:57 AM   #6
speedster
SST...
speedster's Avatar
Drives: SST Camaro 2010
You will not get a noticable gain with a CF driveshaft. Listen to Spike and stay with steel. I use 3.5" chromoly with billet ends and they have been bulletproof. If you are targeting 600 HP/600 TQ, the factory shaft should be fine. Your tires will give way long before the driveshaft. Put the $1000 or so for a CF driveshaft towards upgraded exhaust or another "noticable" performance addition.
Old 06-10-2009, 11:58 AM   #7
CamaroSpike23
Truth Enforcer
the stock d/s will hold 600 ft lbs.
I piss excellence
Old 06-10-2009, 12:00 PM   #8
My First Camaro!
Hmmmmm... Thanks for the info, us new guys are all the help/wisdom/experience we can get. Keep it coming!
Old 08-07-2009, 03:28 PM   #9
GFORCE1320
Drives: 05 GTO
Were working on carbon fiber as well as aluminum driveshafts for the Camaro.
Stay tuned
GFORCE1320 is offline   Reply With Quote
Old 09-03-2009, 10:35 PM   #10
Bentley78
Rice Cooker
Bentley78's Avatar
Drives: Avalanche Z/71, 2010 Camaro2SS
Wouldnt a CF shaft transfer more torqe energy to the wheels, less weight to transfer power through???
Bentley78 is offline   Reply With Quote
C&D Test Drive of new BMW M3 LSxcellent General Automotive + Other Cars Discussion 5 10-15-2010 02:00 AM
Carbon Fiber? Chewy Cosmetics and Lighting Modification Discussions 25 10-15-2008 02:29 PM
What else do you drive? Urthman General Automotive + Other Cars Discussion 82 06-24-2008 01:11 AM
