Emblempros
Old 12-21-2012, 10:54 PM   #15
ChadG
ChadG's Avatar
Drives: 2010 Black Camaro LS
Originally Posted by kjkjr27 View Post
If you go to the wiki section they list all the weights of the different wheels/tires
Thanks! Yeah going from 32.9 lbs per wheel to 18.5 lbs per wheel should yield some noticeable performance gains I would think!
ChadG is offline   Reply With Quote
Old 12-21-2012, 10:54 PM   #16
rtcat600man
having FUN now 13.66@101
rtcat600man's Avatar
Drives: 2010 2LT IOM
Originally Posted by KMPrenger View Post
I'm thinking that RTcat600man will have some good info for you.
I'd love the know the weights of various tires so I can maybe lose a few lbs of rotating mass that way in the future. I hear the General-Tire GMax tires are good performers for a good price, but I wonder what they weigh? I believe RTcat is running those as well.
Thanks for the invite...........LOL.
Just catching up to this thread.
Here is all my weights that I know of from my own experience.
MRT 2.0 Axle Back 9.5
Stock 25.5
savings 16
Total both sides 32
OBX Headers 12
Stock 20
savings 8
Total both sides 16
Total weight savings for exhaust 46
Wheel and Tire weight savigs over the stock 19's with 245/50/19
TSW Nurburgring 20 X 9 & General G-MAX - AS-03 (275/40/20) 5 lbs each 20 lbs total
front seat from a 2LT trim with leather and electric can save ......aprox. 48 lbs.
rear seat bottom is another 12 lbs.
rear seat back is another 18 lbs
for a total seat removal of 78 lbs.......
Old 12-21-2012, 11:10 PM   #17
BaylorCamaro
Track > 1/4 Mile
BaylorCamaro's Avatar
Drives: 2016 C7 Z51
Thanks for the input guys. Will update tomorrow when I'm home. Problem with going smaller is clearing the brembos, and I might be upgrading to 6 piston fronts. We'll see.
Keep the info coming!
Sent from my SAMSUNG Galaxy S III using telekinesis.
BaylorCamaro is offline   Reply With Quote
Old 12-21-2012, 11:24 PM   #18
kjkjr27
COTW 9/16/13
kjkjr27's Avatar
Drives: 2011 2LT/RS Camaro IOM
Hey jw since we are talking about weight here, do you know how much weight was gained when you did the brembo upgrade? I assume the brembos weigh more? and so do the rotors?
kjkjr27 is offline   Reply With Quote
Old 12-21-2012, 11:49 PM   #19
camaro2lt
camaro2lt's Avatar
weighted some things
stock spare tire-40lbs
stock jack&lug nut wrench-8lbs
stock battery-45lbs
Old 12-22-2012, 12:16 AM   #20
SPCBA
Drives: pleather and Chiclets
Not a v6 owner but, concentrating on unsprrung weight and rotating mass reductions. For every one pound is worth 10 on other parts of the car.
SPCBA is offline   Reply With Quote
Old 12-22-2012, 01:00 AM   #21
ChadG
ChadG's Avatar
That's what I was thinking, just by going with 18" Forgestar F14's or TSW Nurburgring that would be 14.4 pounds per wheel, so 57.6 pounds total. That would be like shaving 576 pounds off!?!?!
What would that feel like, HP-wise?
You'd get a little more with a shorter tire vs. the stock tires too.
Old 12-22-2012, 02:27 AM   #22
BaylorCamaro
Track > 1/4 Mile
Drives: 2016 C7 Z51
I have the weight of the brakes for the SS on the list. However I do not know the weight for the V6 brakes :(
stock battery-45lbs
Thanks! Will update tomorrow.
I've lost a lil over 40 lbs in my wheel / tire set up. It wasn't a huge gain in performance, however acceleration and responsiveness definitely increased.
Old 12-22-2012, 07:30 AM   #23
rtcat600man
Here is a build that did many weight reduction things. Read thru his build for more ideas.
http://www.camaro5.com/forums/showth...doc+blue+angel
Then check out this thread, he got his 5th gen down to 3475 lbs with roll cage. Look at post # 40 & 42.
Good Luck, keep us updated on what you do for your weight reduction.
Old 12-22-2012, 10:10 AM   #24
SC2150
A diet is the cheapest most effective way to run lower ET's in the 1/4 mile. every 100# is a tenth on average and the battery swap to a braile or other lightwieght unit is app 40# savings alone.
Good thread!
Old 12-22-2012, 10:39 AM   #25
Sikoriko
Sikoriko's Avatar
Drives: 2011 V6 IOM
If price is not an option. Get rid of those doors and go fiberglass, plexiglass windows. Just saying
Old 12-22-2012, 11:11 AM   #26
kjkjr27
COTW 9/16/13
kjkjr27's Avatar
Hopefully someone can chime in with the weights for the v6
Old 12-24-2012, 12:59 PM   #27
KMPrenger
KMPrenger's Avatar
Saw this in the wheels and tires section and thought it was very interesting. It basically confirms what we all knew about how wheel/tire weights affect power to the ground. Its cool that the test was on an SS, and likely has a similar, or maybe even bigger affect for our V6:
Article with dyno graph came from http://teamspeed.com/forums/aventado...orsepower.html
Test:
Davenport Motorsports (Custom Performance Parts and Service : Davenport Motorsports) of Canada, wanted to see the dyno effects of running different wheels on cars. They took a factory 2012 Camaro SS and ran 3 dyno runs. They ran the first run with a set of aftermarket wheels, the 2nd run with a set of stock factory wheels and the 3rd run with a set of HRE P45S wheels, all in 20” sizes.
These results highlight the effects of rotational inertia on drive-train losses (the hp lost between the engine crank and the ground). Wheels and tires contribute to drive-train losses as energy is used to spin up the wheels (and decelerate the wheels under braking). From the dyno chart you can see the effect of replacing factory wheels with lighter HRE wheels and see the negative effects of installing heavier aftermarket wheels.
Results:
1. (Blue curve) Factory wheels: 20”x9.0” with Pirelli 275/40-20 tires weighing 68 lbs combined per rear wheel. – Max hp: 371 hp, Max Torque: 375 ftlbs - (Baseline)
2. (Red curve) Aftermarket wheels: 20”x9.0” with Pirelli 275/40-20 tires weighing 72 lbs combined per rear wheel – Max hp: 369 hp, Max Torque: 373 ftlbs - (A [-] loss of 2 hp and 2 ftlbs)
3. (Green curve) HRE wheels: 20”x11.0” with Nitto 315/35-20 tires weighing 60 lbs combined per rear wheel – Max hp: 380hp, Max Torque: 384 ftlbs - (A [+] gain of 8 hp and 9 ftlbs and that is running a 2” wider wheel/tire combo)
Conclusion:
The engine obviously still cranks out the same amount of hp and torque, the lighter HREs simply waste less of it before it gets to the ground. Also interesting to note is that the gains are not just peak gains, but gains across the entire rev range. If they had done a braking test, we would have seen similar results as the rotational inertia effects also have a significant effect on how much energy is used to stop the wheel/tire combo vs. stopping the car. We talk about these effects all the time and focus on designing lightweight wheels with low rotational inertia, but it isn’t every day that you get to see real hard data showing the true effects.
Old 12-24-2012, 01:39 PM   #28
ChadG
ChadG's Avatar
Yeah this is precisely the reason I'm drooling over the Forgestar F14 and TSW Nurburgrings in 18"!
light weight, weight loss, weight reduction
