JUICEDMOTORSPORTS
Old 12-28-2012, 05:27 AM   #43
rtcat600man
having FUN now 13.66@101
rtcat600man's Avatar
Drives: 2010 2LT IOM
Originally Posted by ChadG View Post
I was just thinking back of the envelope calculations where 1 pound of unsprung rotational mass = 10 pounds weight reduction. (If someone has a better number please chime in)
The 18" TSW and Forgestar F14's are about 18.5 pounds a piece, which is a 14.4 lb weight savings per wheel. So a total of 57.6 pounds of unsprung rotational mass (assuming you go with the same tires) would be worth ~570 lbs of weight loss? That seems unreal, but if that number is correct you'd definitely feel it I would think.
I have heard that rotational mass is somewhere bewteen 4 and 10 lbs stationary mass. This would put that number for your weight drop on the wheels between 230 to 580 lbs. Probably much closer to the lower end. For sure something you will notice when accelerating.
Old 12-28-2012, 10:57 AM   #44
KMPrenger
KMPrenger's Avatar
I just read recently, that the 1lb of rotating mass equalling 10lbs of sprung mass is not the norm. Possible yes, but not the norm. I can't remember the explaination given unfortunently.
In our case, its probably on the low end, and so losing 57lbs of unsprung weight is probably more like 2 - 4 times that amount in sprung weight, so 100 - 200 lbs I'd guess.
Even so, that is a FANTASTIC weight loss to unsprung weight. I'd be extremely happy.
Old 12-29-2012, 08:34 PM   #45
'11CamaroLS
'11CamaroLS's Avatar
Drives: 2011 Camaro LS
That's what I wanted to hear! Really hoping to be able to pull of the upgrade soon, those heavy steelies are killing me.
dropping the steelies is one of my favorite mods lol, looks so much better and the 44 lbs i dropped made a big difference in driving feel. car feels more nimble and spins the tires easier now.
'11CamaroLS is offline   Reply With Quote
Old 12-29-2012, 09:21 PM   #46
OOLIE
OOLIE's Avatar
Drives: 2011 LS
Amen! Also KMP post on weight is a great post to show how weight affects on dyno. Also overall tire diameter as stated in poor man gear change will add as well. This may have been already stated but I got behind on this thread and didn't read all.
OOLIE is offline   Reply With Quote
Old 12-30-2012, 11:04 PM   #47
camaro2lt
camaro2lt's Avatar
rs headlights weigh 10lbs each
Old 01-01-2013, 09:20 PM   #48
camaro2lt
camaro2lt's Avatar
weighed and took out the washer fluid resivor today it weighed 12lbs filled!
Old 01-08-2013, 10:27 PM   #49
horizon670
horizon670's Avatar
Drives: 2010 Chevy Camaro 2LT / RS / Auto
To be able to calculate the equivalent chassis weight of a specific value of Rotational Mass, you will need to compute the following:
  1. The car's weight
  2. The Time it takes to reach a certain speed ( 0-60mph)
Camaro V6 2LT (3751 lbs) (0-60mph: 6s)
40 lbs of (Wheel/Tire saving) = 255 lbs of chassis weight
Camaro V8 2SS (3935 lbs) (0-60mph: 4.7s)
40 lbs of (Wheel/Tire saving) = 233 lbs of chassis weight
Hope this helps
horizon670 is offline   Reply With Quote
Old 01-14-2013, 04:02 PM   #50
BaylorCamaro
Track > 1/4 Mile
BaylorCamaro's Avatar
Drives: 2016 C7 Z51
Updated.
BaylorCamaro is offline   Reply With Quote
Old 01-26-2013, 03:08 AM   #51
lscamaro
lscamaro's Avatar
Drives: 2011 CGM Camaro LS A6
Nobody knows the weight of the v6 rotors?
Old 01-26-2013, 09:02 AM   #52
kjkjr27
COTW 9/16/13
kjkjr27's Avatar
Drives: 2011 2LT/RS Camaro IOM
I wish someone did, because I am trying to find some light weight drilled/slotted rotors or depending how how drastic the weight diff is between the ss brake system, upgrading.
kjkjr27 is offline   Reply With Quote
Old 01-26-2013, 09:53 AM   #53
rtcat600man
The forum search button is our FRIEND.
Type in rotor weight. two finds come up
http://www.camaro5.com/forums/showth...t=rotor+weight
See post 2 and 3 for SS rear rotor weight and V6 rear rotor weight.
SS is 24 lbs.
V6 is 17.3 lbs.
See post 5 for front rotor weight for both.
SS front rotor: 25.2 lbs.
V-6 front rotor: 22.0 lbs.
Hope this helps you guys out.
Old 01-26-2013, 10:15 AM   #54
kjkjr27
COTW 9/16/13
kjkjr27's Avatar
SS is 24 lbs.
V6 is 17.3 lbs.
O yea I remember coming across that thread a like a couple months ago but forgot about it . Thanks! ...now its time to do some searching seeing if I can find some lighter aftermarket rotors.
Old 01-26-2013, 10:21 AM   #55
rtcat600man
Let us know what you come accross, rotors and pads are on my list to replace in the next 12 months. especially if lighter.
Old 01-26-2013, 10:27 AM   #56
kjkjr27
COTW 9/16/13
kjkjr27's Avatar
Same here, and will do
light weight, weight loss, weight reduction
