BORLA
Old 12-22-2012, 01:15 AM   #1
mikester0612
Camaro 5 Muscle
mikester0612's Avatar
Drives: 2010 CGM 2SS/RS L99
What's next?
Hey guys. I wanted to get your opinion on what to do next performance wise. I already got kooks stepped headers, CAI cold air intake, corsa cat back exhaust, and dyno tuned. What can I do next that could get me good numbers. Not looking to do a cam right now. Thanks guys!
TSW Donington 22" Matte Black / Corsa Cat-Back Exhaust / Kooks Signature Stepped Headers 1 3/4" - 1 7/8" / High Flow Cats / Custom Tune / CAI Cold Air Intake / BMR 1" Lowering Springs / VMax Ported Throttle Body / Heritage Grill / Havoc Rear Diffuser
mikester0612 is offline   Reply With Quote
Old 12-22-2012, 01:16 AM   #2
AdamZ
Drives: Eve - 2011 Camaro 2SS/RS
Scoop for your CAI? Nice little hp boost there.
AdamZ is offline   Reply With Quote
Old 12-22-2012, 01:22 AM   #3
Bad@ssCamaro
Rogers' Rocks :-)
Bad@ssCamaro's Avatar
Drives: 2015 1SS/1LE
What made you go with the stepped headers?
2015 CRT 1SS/1LE RS/Recaro's/NPP/Nav/Rear vision pkg./BA speaker upgrade.
ARH 1 7/8 headers, CAI, BMR 1.25 drop springs, JPSS Billet Bushings, Peddars Cradle Bushings, DSS driveshaft ...421 whp...so far.
Old 12-22-2012, 01:25 AM   #4
mikester0612
Camaro 5 Muscle
I was thinking about that but wasn't sure if I wanted to do all the grinding and all that work.
Read a bunch of good reviews on them and read that they produced a little more HP that standard headers.
Old 12-22-2012, 01:28 AM   #5
AdamZ
Not sure what else you can do really...I mean you have the whole world of suspension parts? Are you not lowered yet? That's like a must.
Old 12-22-2012, 01:32 AM   #6
Bad@ssCamaro
Rogers' Rocks :-)
I see that you had the car tuned, did the tuner tell you that you gained from the stepped headers? I read that they are better too if you're planning on going to add crazy horsepower. Is there a difference in price?
Old 12-22-2012, 01:34 AM   #7
mikester0612
Camaro 5 Muscle
Not done suspension yet. Any pros on doing suspension? I know the cons in Miami are scrapping every speed bumb I go over!
Really cant tell because I did not have normal headers to test and compare with.
Old 12-22-2012, 01:34 AM   #8
mikester0612
Camaro 5 Muscle
Couple hundred bucks more I believe.
Old 12-22-2012, 01:39 AM   #9
Bad@ssCamaro
Rogers' Rocks :-)
Did you have them coated too? what did you pay for them?
Old 12-22-2012, 02:07 AM   #10
AdamZ
Better handeling, less wheel hop, better hooking, many things. Do you plan on racing or showing off? If you're just showing off then just grab yourself some BMR 1.4in drop springs from Apex or another vendor...that will give your car a much more aggressive low stance. I love my BMR's. Love the lower stance. Definitely can tell a big change in handling on corners.
Old 12-22-2012, 02:12 AM   #11
mikester0612
Camaro 5 Muscle
I really don't race the car and don't plan on it. Mostly just for show and sound. Will it really handle that much better? Im iffy on them because I have a feeling that im going to start scraping everything!
Old 12-22-2012, 02:22 AM   #12
AdamZ
Oh yeah there is definitely an improvement...you will notice. You will scrape your front air deflector often on driveway curbs...but that's what it's there for lol. As for scraping the actual fascia I haven't had an issue. If you don't want to be that low then go with BMR's 1.4in front/1.0in back drops...that's what I have. If you go 1.4 on the fronts and backs then it will be considerably lower. So the 1.4/1.0s would probably be perfect for you.
Old 12-22-2012, 02:59 AM   #13
SPCBA
Drives: pleather and Chiclets
Reducing your unsprung and rotational weight. Wheels brake rotors driveshaft etc. The scoop is a nice little add on and easy diy dont forget the washer bottle relocate. Replacing various bushings is a great and relatively inexpensive suspension upgrade.
Gen5diy.com has a lot of diy type goodies if you want to check that out.
SPCBA is offline   Reply With Quote
Old 12-22-2012, 07:30 AM   #14
kmm1412
The Bolt-On Beast
kmm1412's Avatar
Drives: 2011 2SS/RS IBM w/CGM Stripes
I'd do a scoop. Isn't really a big deal to install. A few good install threads for it exist. I used tin snips to cut the plastic, instead of a Dremel or cutting tool, and it was an easy and clean install. Cheapest HP per dollar mod you can do at this point.
I'd also recommend a Vmax ported throttle body. Not much HP gain, if any, but fabulous throttle response. Big difference over stock. Simple bolt-on mod that can be done in minutes.
JMHO...but whatever you decide to do, keep enjoying that ride!
2011 2SS/RS 6M Imperial Blue Metallic|Cyber Gray Metallic Stripes|Gray Interior|Factory (KAE) Hurst Short Throw Shifter|Sunroof
MODS - 1LE Track Pack Suspension Upgrade|Kooks Custom Stepped Headers & HFCs|Cold Air Inductions Black CAI|ADM Performance Scoop|Vmax IBM CNC Ported Throttle Body|Rx Extreme IBM Catch Can & Breather|Borla S-Type Catback Exhaust w/Solo J-pipes|IBM Heritage Grill|LG ZL1 10 Spoke Replica Wheels w/Goodyear Supercar G2 Tires|Z/TA Rear Spoiler|463RWHP/459RWTQ Tune by Dale Cherry
kmm1412 is offline   Reply With Quote
