Flowmaster Exhaust
Old 12-22-2012, 10:08 PM   #1
Kiwi_Camaro_2010
Kiwi_Camaro_2010's Avatar
Drives: Camaro 2SS/RS 2010 L99
Whipple setup lost power & leaking water
Hey Guy's, just went out for a hard run to show a friend the performance, when car has lost power won't rev & brought up a misfire DTC, when parked up it's leaking water now from back of the engine somewhere near the oil filter but more to the middle, haven't had chance to get it up in the air yet to see properly. Also exhaust was alot quieter than usual with some rattling coming from exhaust I think & was extra hotter than usual. Any idea's from anyone who has experienced this before with whipple SC.
My guess is either, high flow catts have blocked up & now I have blown head gasket maybe, or Whipple intercooler is leaking into cylinders.
Camaro 2SS/RS 2010 / L99 / Whipple SC /Dynatech Headers & Catts (gutted), ID 850 injectors, ZL1 fuel pump +BAP & ADM pump controller, ZR1 3Bar MAP, Dual Elite Catch Cans, 91 octane ,Eibach sway bar kit , Driveshaft loop, oil cooler delete, ADM dual gauges (AFR/Boost) LC1 wideband controller, D/D, ARP stud kit ,Callies forged slayer crank 3.622", callies ultra rods, wiseco forged pistons, L99-LS3, rollmaster double row steel timing set & comps cam timing cover,blower cam 630/660 lift,3/8 pushrods, pac gear 8deg, yella terra ultra lites. LS9 head gaskets. Texas speed custom oil pump. Asm by me.
Kiwi_Camaro_2010 is offline   Reply With Quote
Old 12-22-2012, 10:40 PM   #2
Nitroman28
Nitroman28's Avatar
Drives: 2010 Camaro SS 416/4L80
Did you check the oil to see if you had water in it?
Nitroman28 is offline   Reply With Quote
Old 12-22-2012, 11:37 PM   #3
Kiwi_Camaro_2010
Yes checked that & all good, no color change or rise in level.
Old 12-22-2012, 11:44 PM   #4
grocerygetter
instigator
grocerygetter's Avatar
You didn't throw the belt did u?
-John S.
Thanks to:
Tony@ dv8motoring
TCAudio in Benton AR
Old 12-23-2012, 12:43 AM   #5
Kiwi_Camaro_2010
Nope, belt looks still in good condition, thought it may have been slipping to start with until I checked it. It will free rev up to 6000rpm but when I load engine it won't go above 4500rpm & does not sound pretty, but still idles & drives normally when cruising which makes me think 1 of the catts has clogged up which has caused to much heat & pressure causing head gasket to give. Friends got a Radiator pressure tester so trying that tomorrow first.
Old 12-23-2012, 08:56 AM   #6
MA2010SS
Do your basics first, check engine coolant level, check SC coolant level, pressure test both systems then start diagnosing from there, also what was the misfire code? P0300 is random misfire, P030X (X) represents the cylinder that is misfiring. Let us know what you find
2010 Camaro SS Whipple SC, CAI Inc Intake, TSP 1 7/8" LT headers no cats, 3" magnaflow exhaust, HPT, RX Catch Can, LSR Toe Rods, LSR Trailing Arms, ALKY Control Meth, McLeod RXT Twin Disc, ZL1 fuel pump, 3.73 ZL1 Differential Kit, BTR PDS Stage 2 Cam, Tuned by SLOWHAWK Performance Bridgewater MA
MA2010SS is offline   Reply With Quote
Old 12-23-2012, 09:00 AM   #7
thebeast916
Drives: Blown G8 GT
Could have melted and spark plug.
If a cat was plugged you would have reduced engine power mode.
thebeast916 is offline   Reply With Quote
Old 12-23-2012, 09:14 AM   #8
realcanuk
realcanuk's Avatar
Drives: 2007 Corvette C6 983 RWHP
The symptoms you describe are exactly what I had when my cats blocked except the leaking says more going on. If the cats blocked and you pushed it hard the added boost (pressure) possibly blew a head gasket. I hope not worse than that. Good luck and let us know what you find.
2007 C6 vert, auto, F55, LT3
LME LS402 , WCCH 245 Heads, Pat G. Custom cam
YSI / 3.0 pulley, ARH 1 7/8 headers, NPP
Dewitts / dual spals, A&A dual pump fuel system.
3.42 polished gears, hardened shafts, Alky control meth, Cartech line lock, ECS axle loops, Trans brace, 6L80 built by me.
ID 1000 injectors, comp rockers, Morel lifters, BT springs, Trend 3/8 pushrods, ATI 10% OD Damper
Circle D Triple Disc stall
1009 RWHP @ 7000, 817 RWTQ @ 6000, Built & Tuned by Seth at FEDERAL PERFORMANCE
realcanuk is offline   Reply With Quote
Old 12-23-2012, 09:17 AM   #9
realcanuk
realcanuk's Avatar
My cats totally plugged up and I didn't get any light or reduced power mode.
Old 12-23-2012, 03:43 PM   #10
wrp
Drives: 2004 QSM GTO
Boost leak? Check all the connections to see if anything is loose. I would think the manifold intercooler would run water directly into the intake runners. Did you check the supercharger itself and the intercooler-heat exchanger hoses?
wrp is offline   Reply With Quote
Old 12-23-2012, 09:09 PM   #11
thebeast916
Drives: Blown G8 GT
Mine went right into limp mode after the cats melted.
Old 12-24-2012, 12:34 AM   #12
Kiwi_Camaro_2010
I have sorted it now, the catts are toast! only in car for three months & completely blocked, Ive gutted them now. The water leaks may have been a coincidence, coming off the oil cooler, so have taken that off & blocked off water, no water leaks now. Power seems to be restored, will check plugs later, having a beer now thank f*^k, feel more relaxed. I will post pics later of catts, really disappointed paid good money for crap!
Old 12-24-2012, 12:47 AM   #13
Kiwi_Camaro_2010
These are what they look like, when removed, I will be talking to manufacturer bout this, if no joy I maybe bad mouthing them till sorted. Really pissed bout quality, If no good for supercharging this should be stated.
Old 12-24-2012, 01:02 AM   #14
realcanuk
realcanuk's Avatar
Glad you found the problem. I went to ARH high flow cats and they have held up perfectly.
