BeckyD @ James Martin Chevy
Old 12-24-2012, 12:33 AM   #1
hapisok
crazier than a coconut
hapisok's Avatar
Drives: 2010 2SS/RS LS3
beginners guide
i've been over on HPTuners (since i have the pro tuner and wide band AFR) and EFI live, LS1 Tech, Performance Trucks... forums and have been looking for a decent "beginners" how to guide. there are numerous ones floating around, but are there any newer/up-to-date ones available?
CPigs and "Beginners Guide" were done on older software that don't match up with the current version, especially when trying to create the VE histograms or changing other parameters that don't seem to exist or have taken on a different name.
yes, i could continue to read and read for hours on end or just take it to a tuner (which i already have and i trust)...so if that's your answer, save it. this is something i'd like to learn but not ready to drop $600 on some DVD's that may or may not be up to date with the current software.
thanks,
hapisok is offline   Reply With Quote
Old 12-24-2012, 12:17 PM   #2
realcanuk
realcanuk's Avatar
Drives: 2007 Corvette C6 983 RWHP
The Bannish stuff is a good start, either DVD or read the book. The software is basically the same. They add a few parameters with time but the basic tuning stuff doesnt change much.
2007 C6 vert, auto, F55, LT3
LME LS402 , WCCH 245 Heads, Pat G. Custom cam
YSI / 3.0 pulley, ARH 1 7/8 headers, NPP
Dewitts / dual spals, A&A dual pump fuel system.
3.42 polished gears, hardened shafts, Alky control meth, Cartech line lock, ECS axle loops, Trans brace, 6L80 built by me.
ID 1000 injectors, comp rockers, Morel lifters, BT springs, Trend 3/8 pushrods, ATI 10% OD Damper
Circle D Triple Disc stall
1009 RWHP @ 7000, 817 RWTQ @ 6000, Built & Tuned by Seth at FEDERAL PERFORMANCE
realcanuk is offline   Reply With Quote
Old 12-24-2012, 01:27 PM   #3
hapisok
hapisok's Avatar
yeah, the guides i've been trying to use have screen shots and with data fields that are not in the newer version of HPT as well as some of the settings for creating the histograms for logging. my question to the books & dvd's is this...are they up to date to mirror the changes that have been implemented?
thanks, i'll definitely give them a second look.
Old 12-31-2012, 04:09 PM   #4
Tampa Tuning
Drives: TAMPA TUNING FACEBOOK & INSTAGRAM
Camaro Corvette GTO CTS G8 Firebird Truck performance tuner in Tampa Orlando
I like the Banish's CDs and I help teach at "The Tuning School" here in Odessa, Fl.
The main issue with both of them is they still teach 2.22 version of HP Tuners, and most people are using BETA which has differant methodology for setting up the PIDs and additional tables to touch. Without the finish product of 2.24 being release, you really cant teach the BETA tables because you dont know what the final product will be, but you should be able to figure them out.
The knowledge of both is great. When HP Tuners goes to 2.24, everyone will have to catch up their books. The VE tables on the new vehicles are Co-Efficients.
Phil
www.TampaTuning.com
Tampa Tuning is offline   Reply With Quote
Old 01-01-2013, 02:17 AM   #5
Scourage
Syntax Error
Scourage's Avatar
Drives: 2010 Camaro 2SS/RS
I bought Greg's DVD and Book, he has some youtube videos also. Great info on HPT forums and some good stuff posted here by Bluetorp in the tuner section.
Scourage is offline   Reply With Quote
Old 01-01-2013, 08:43 PM   #6
hapisok
hapisok's Avatar
sweet...i'll keep digging around.
thanks for the info Phil.
