Old 12-25-2012, 12:17 AM   #1
47AJV8
Drives: A White Car
Rim Width Vs. Tire Width, help me?
Once again I'm probably being a big noob, so bare with me, but I'm looking at 2 different sets of rims on tirerack and they are both 20"x10" (at the rear) but the one says required 255/45-20 and the other is 285/40-20, why does the one need wider tire than the other, if the rims are the same width? And also I noticed that tire sizes don't quite match up to rim sizes, about what amount of wiggle room do you have when fitting tires to rims? Thanks for dealing with my lack of basic knowledge! :P
Here are the rims in question btw:
http://goo.gl/gKcNh
http://goo.gl/zdEkb
"From ABS shudder that came on surprisingly early in the lousy brake pedal's travel to a looser rear end than Kim Kardashian"
47AJV8 is offline   Reply With Quote
Old 12-25-2012, 02:23 PM   #2
47AJV8
Drives: A White Car
plox? :P
Old 12-25-2012, 02:30 PM   #3
Angrybird 12
7 year Cancer Survivor!
Angrybird 12's Avatar
Drives: 16 Encore, 07 G6, 99 Astro, 16 VW
See if this explains it
http://www.tirerack.com/tires/tirete...jsp?techid=198
The Bird is the word!
Angrybird 12 is online now   Reply With Quote
Old 12-26-2012, 01:20 AM   #4
47AJV8
Drives: A White Car
that helped a lot, thanks
Old 12-26-2012, 12:14 PM   #5
Norm Peterson
corner barstool sitter
Norm Peterson's Avatar
Drives: 08 Mustang GT, 10 Legacy 2.5GT, ...
It appears that the two vendors you're looking at have different ideas about fitting tires to wheels. Appearance is likely part of the reason behind recommending the 285-wide tire, while "crisper" cornering behavior is apparently something that the guys suggesting 255's are more concerned with.
285/40-20 is generally accepted for fitment to rims between 9.5" wide and 11" wide.
255/45-20 is generally accepted for fitment to rims from 8" wide to 9.5" wide. It appears that this vendor is willing to stretch them another half inch. The first half inch "over-max" isn't something to get very excited about, as the "go/no-go" line for mass market tire size decisions has to be drawn somewhere.
In most cases, mounting tires on wheels half an inch above the widest recommended width is better than mounting the same tires on wheels that are half an inch below the minimum recommended width. At least from a sidewall heat buildup point of view, which is arguably more critical than either ride quality (firmer) or rim scuff protection (not as good).
Actual tire measurements are permitted to vary slightly (there's a spec for this permissible variation). Tires of a given size from some mfrs run wider than do the same size tires from other mfrs.
Norm
Norm Peterson is offline   Reply With Quote
help me i'm a noob, rims, size, tires, width
