12-26-2012, 07:34 PM | #1 |
Drives: 2023 Black ZL1 Auto Join Date: Oct 2009
160 thermostat
Would a 160 thermostat help with an almost stock setup, or should I wait until i install an upper or lower pulley for more boost? The only mod I've done so far is a Rotofab CAI.
12-26-2012, 07:39 PM | #2 |
Drives: '21 ZLE A10 Join Date: May 2012
can't hurt...might help
12-26-2012, 09:24 PM | #3 |
12-27-2012, 12:28 AM | #4 |
Drives: 2013 Ashen Gray Metallic-M6 Join Date: Aug 2012
I asked a very reputable vendor on here about 160* thermostats and was told it wasn't a necessary thing so I'm holding off for now.
12-27-2012, 07:56 AM | #5 |
Drives: 2012 ZL1, 1996 Z28 Join Date: Jun 2012
With the factory the tune, the 160 ts will reduce normal driving temps about 10 to 15 degrees as long as the car is moving. For performance driving it's not much benefit because the fans don't come on at the same time. Also, it does not cause any CELS.
12-27-2012, 08:27 AM | #6 |
Drives: 2011 Camaro SS/RS LS3 Join Date: Aug 2010
Yeah, I'll get around to it...
12-27-2012, 08:51 AM | #7 | |
Drives: 2017 ZL1 A10 Join Date: Sep 2009
I finally got tired of having to bring my laptop with me every morning just to clear the code so my a/c would work, so I put an 180 degree thermostat in.
2017 ZL1
A10 Redhot with stripe |
12-27-2012, 09:42 AM | #8 |
general answer to a general question...every aftermarket supercharger kit comes with a 160 thermostat so I assume that it is ok for a factory installed supercharged motor to use a 160 t-stat. Can't hurt...meaning that running a 160 t-stat has no ill effects...might help...meaning if the t-stat opens sooner than the factory one, it may aid in keeping overall temps lower under normal operating conditions. Hope this helps.
12-27-2012, 09:53 AM | #9 |
It sounds like a tune is needed to run the 160 thermostat without throwing a code, so it might not be a good idea unless other mods are performed and the car is tuned at the same time. I'll pass on it for now.
12-27-2012, 10:02 AM | #10 |
Drives: 2013 ZL1 #659 Join Date: Aug 2011
My car runs a 160 and i can see for everyday driving my temps have lowered about 8 degress
Order# QKTDRT
2013 ZL1 Ashen Gray |
12-27-2012, 10:44 AM | #11 |
mine too...it definitely doesn't run in the 160s
12-27-2012, 12:49 PM | #12 | |
12-27-2012, 01:03 PM | #13 |
Drives: #1 CAMARO FAN Join Date: Nov 2011
Not a good idea for a stock set-up.
12-27-2012, 01:14 PM | #14 | |
2011 2SS/RS L99
2017 Chevy SS 1979 Z28 Mods: Kooks Long Tube Headers, RotoFaB EForce CAI, American Thunder Catback Exhaust, PFADT Stage 1 Drag Kit + Front Sway Bar, GM Strut Tower Bar. ZL1 Fuel Pump. Nitto NT05R. RX Catch Can.LS9 Cam and Springs.LS3 Conversion.JRE Fuel Rail Upgrade.Edelbrock Eforce.60# Eforce Injectors.Extreme Racing Tune. 523/495 MY BUILD THREAD |
