BeckyD @ James Martin Chevy
Old 12-30-2012, 04:48 PM   #113
2cnd chance
Too Many Great Choices
2cnd chance's Avatar
Drives: Grand Sport/Z07
According to the article, the 1LE would have bested the GT500 if they had not had a missed shift that waisted a couple of seconds.
"Remove that one regrettable slip-up...and you have a sub-three-minute car for the low, low price of $37,930."
2cnd chance is offline   Reply With Quote
Old 12-30-2012, 05:10 PM   #114
Z/28orSs
Z/28orSs's Avatar
Drives: 2000 ss
Originally Posted by KMPrenger View Post
Yes, the Camaro is too heavy...unfortunately the Zeta chasis they used was/is heavy. Its really the only thing that holds this car back from being top dog even with the Mustangs performing as good as they do....I mean look at how well the Camaros are performing even with the additional weight.
As to your question about whether or not GM is going to do anything. I'd say the answer is yes and no. You won't see the 5th gen going on a big weight loss. But I bet we see more tweaks and what not before the 6th gen arrives. (LS7 engine anyone??)
The next generation Camaro...the 6th gen, will be built on a lighter chasis. Most likely the Alpha platform, and based on the Cadillac ATS, which is built on the Alpha platform as well, I think we could see a base Camaro in the 3,300 to 3,400 lb range for sure. A V8 equipped model likely in the 3,500+ lb range. I can't wait!
the 2.0t ats is 3500 + why would a v8 Camaro weigh 3500+ more like 3700
Z/28orSs is offline   Reply With Quote
Old 12-30-2012, 05:39 PM   #115
doc7000
Drives: 2004 Pontiac Grand Prix
Originally Posted by Z/28orSs View Post
[/B]
The ATS 2.5 (standard) is 3,315 pounds
The ATS 2.0 (turbo standard) is 3,373 pounds
the ATS 3.6 (Luxury) is 3,461 pounds
Of course depending on options and trim levels these cars can pick up weight, most of the 2.0T as tested weight I have seen has been 3,430-3,450 pounds.
doc7000 is offline   Reply With Quote
Old 12-30-2012, 06:02 PM   #116
2cnd chance
I'd figure 3,650+ for a 6Gen V8 Camaro.
Old 12-30-2012, 06:13 PM   #117
SUKXOST
Do you even lift, bro?
SUKXOST's Avatar
Drives: 2013 1LE Camaro
SLIGHTLY narrower and shorter wheel base alone will save a good chunk of weight. I'm guessing it will drop from 3900ish to 3500ish.
My 1LE (645WHP/597WTQ) build/journal Thread:
1st ever 1LE COTW http://www.camaro5.com/forums/showthread.php?t=255461
SUKXOST is offline   Reply With Quote
Old 12-30-2012, 06:19 PM   #118
doc7000
If the Camaro was to use the same wheel base as the ATS sedan then consider this, the V-6 Camaro is 3,750 pounds and the V-6 ATS is 3,461 pounds. That is roughly a 300 pound weight savings, if that carries through next Camaro that would put 3,850 pounds to 3,550 pounds.
Old 12-30-2012, 06:43 PM   #119
69NMYSS
69NMYSS's Avatar
Drives: '69 Camaro SS and '12 ZL1
Originally Posted by SRT8Tech View Post
Would be nice to get a ring time from the ZL1, 1LE, Boss 302 LS, and 2013 GT500 with track pack all on the same day and same driver..........
Would be a little embarrassing for the blue oval fans.
69NMYSS is offline   Reply With Quote
Old 12-31-2012, 12:08 AM   #120
Z/28orSs
Z/28orSs's Avatar
Drives: 2000 ss
insideline has a auto 2.0t auto at 3515 which isn't bad ?? I don't know who to believe keep getting different numbers
I would say you are spot on sir!!!
http://www.motortrend.com/roadtests/...son/specs.html
car and driver has the weight of the 3.6 at 3535 so I could see a 3500 ibs v6 but at 200lbs will there be enough of a performance difference how much faster is the ats 3.6 vs the Camaro and why no ats at VIR it would have been perfect to see what it can do and how to properly see the alpha in action!
Old 12-31-2012, 12:31 AM   #121
NASTY99Z28
Drives: 99z28 with bolt-ons and a mwc fab 9
Not to take anything away from any of the cars but does anyone know which cars were tested on the same day? A lot of speculation about the gt500 having to run on a damp course while the camaro's ran on a dry track.
I like my woman like my milk shakes, THICK!!!!
NASTY99Z28 is offline   Reply With Quote
Old 12-31-2012, 01:08 AM   #122
doc7000
The thing about looking at the weights used for car rag testing is it is not a base weight, you are looking at the weight of the vehicle with options (and which ones). Plus sometimes those posted weights are est. and guesses, the official curb weight that I posted is from the Cadillac ATS official web site and Edmunds has updated its weights as follows.
In the Motor Trend test they tested I believe a fully loaded ATS (or near fully loaded) with an as tested price of $49,185. In the earlier Motor Trend test of the 2.0T ATS vs the BMW 328i the 2.0T ATS is priced at $45,910 and was stated in their test to be 3,433 pounds.
This isn't a matter of who to believe, its a matter of the difference in weight between a base model and a fully loaded model (which includes but isn't limited to bigger wheels and tires).
Though for the sake of apples to apples I like to compare base curb weight with base curb weight. The current lightest V-6 Camaro is the 1/2LT at 3,741 pounds, the 1LS weighs in at 3,780 pounds and the 2LS weighs in at 3,769 pounds (per chevy web site). They have both 1SS and 2SS at 3,860 pounds though I have seen the SS Camaro with a test weight of over 3,900 pounds.
With that said the base curb weight of a 2LT Camaro is 3,741 pounds and the base curb weight of the ATS 3.6 is 3,461 pounds a difference of 280 pounds. Also when the ATS was in development there were tricks that they did not take to reduce the ATS weight because it was a luxury vehicle which they could use for the next Camaro.
How much of a performance difference will you get with a 300 pound diet????.......With 323BHP and 3,741 pounds the 1LT Camaro has a power to weight ratio of 11.5 pounds per horsepower. A 3,441 pound 321BHP V-6 Camaro would have a power to weight ratio of 10.7 pounds per horsepower. That gives it a power to weight ratio not that far from the 2002 SS Camaro (325BHP and 3,411 pounds). Food for thought....
Old 12-31-2012, 01:09 AM   #123
doc7000
The GT500 was tested with the ZL1 Camaro and 1LE Camaro (same lightning lap issue) as far as the GT500 having to run on a damp track IDK. It is possible that given how many cars that tested that they tested over weeks and as a result conditions could have changed.
Old 12-31-2012, 02:24 AM   #124
2SSJIM
2SSJIM's Avatar
Drives: 2012 CRT ZL1 #1400
ZL1, 1LE and GT500 were run on the same day according to the article.
2SSJIM is offline   Reply With Quote
Old 12-31-2012, 04:40 AM   #125
NASTY99Z28
Where does it say that?
Old 12-31-2012, 07:47 AM   #126
SRT8Tech
2013 Super Bee
SRT8Tech's Avatar
Drives: 2013 Super Bee
Ehhh, I dont know......The ring has alot of long sweeping turns and straights that would make it more of a GT500 type of track.
2007 Procharged SRT8 Charger..........SOLD
2010 Mopar 10 Challenger.................SOLD
2010 R/T Classic Challenger...............SOLD
2011 392 Challenger.........................SOLD
2012 mid 10 second 1/4 mile GT500.... SOLD
Current ride 100% stock 2013 Plum SuperBee............best of 12.407 @ 114.28 for now.
Tune, CAI and Drag radials. Best of 12.00 @ 115.74
SRT8Tech is offline   Reply With Quote
