Old 12-27-2012, 04:59 PM   #1
sixty9fordkiller
bowtie junkie
sixty9fordkiller's Avatar
Drives: 2010 2SS/RS LS3 M6
power mirror switch removal and install
does anyone know how to remove and re-install the power mirror switch on the driver side inner door panel? i somehow managed to crack mine so im gonna replace it. im picking up the new switch from the dealer tonight on the way home from work for $17. has anyone ever done this so i can maybe get some tips? thanks in advance
sixty9fordkiller is offline   Reply With Quote
Old 12-27-2012, 05:29 PM   #2
sixty9fordkiller
bowtie junkie
nevermind. i figured it out. its a quick 3 minute job
Old 07-14-2015, 06:17 PM   #3
camarograna2
Car Enthusiast
camarograna2's Avatar
Drives: 2010 Rally Yellow Camaro 2SS A/T
Send a message via MSN to camarograna2
bump because i just had to do it. Easy 3-5 min job. I did not have to remove door panel. Using plastic trim tools lifted the mirror switch to its maximum position. which for me wasn't much (not sure if my audio guys taped it off shorter or if normal). Took some pliers and cracked the middle plastic brace at the bottom of the connection. Using some small tools then lifted the connection to allow the switch to be pulled out. Holding on to the connection (because like i mentioned mine was very short) i grabbed new one and slipped it through the top. And thats all folks.
2010 Rally Yellow 2SS/RS
Performance Upgrades: Custom Flowmaster X system Exhaust Audio Upgrades: Too much to write down. Visit http://www.camaro5.com/forums/showthread.php?t=206016
camarograna2 is offline   Reply With Quote
