HeadlightArmor
Go Back   Camaro5 Chevy Camaro Forum / Camaro ZL1, SS and V6 Forums - Camaro5.com > General Camaro Forums > Camaro ZL1 Forum - ZL1 Specific Topics > ZL1 Wheels/Tires
Old 12-29-2012, 09:46 AM   #1
ZL12013
ZL12013's Avatar
Drives: 2013 ZL1 & 2005 F150
Adding air to tires
Is there a way to add nitrogen to your tires at home? Cold weather finally set in and my tires are showing a little low. I was told that you can add air and just replace at a later date.
ZL12013 is offline   Reply With Quote
Old 12-29-2012, 10:00 AM   #2
One-Bad-ZL1
So easy to love Camaros
One-Bad-ZL1's Avatar
Drives: 2013 ZL1 VR #3457
Send a message via Yahoo to One-Bad-ZL1
Are you telling me our cars tires come nitrogen filled? Or did you have them filled?
One-Bad-ZL1 is offline   Reply With Quote
Old 12-29-2012, 10:10 AM   #3
ZL12013
ZL12013's Avatar
My car came with nitrogen check the caps on your valve stems, I got 2 sets, one has a N on the top.
Old 12-29-2012, 10:12 AM   #4
DangerZL1
Drives: Future ZL1 Owner
Maybe his dealer put it in. I think mine did because the stems have a green cap.
I don't think you could do it unless you had a nitrogen tank. The tire places have a machine that removes the O2 from the air. It's too much trouble to go to a tire store and have them put air in, so I've decided nitrogen is more trouble than its worth.
DangerZL1 is offline   Reply With Quote
Old 12-29-2012, 10:14 AM   #5
Mouse6.2
Mouse6.2's Avatar
Drives: 2013 2SS/RS M6 NPP
I'm sure others will chime in on this. Just add air to them. The nitrogen is a joke if you ask me. I thought I would try it out when we got new tires on our Acadia. I kept fuel mileage records and the nitrogen didn't make a difference. Also the pressure changed just as much with the heat and cold like normal air did. So to me it was a waste of money. Unfortunately my camaro came new with nitrogen filled tires that the dealer installed. I had to pay for that, not like I could have them reclaim it and refill with normal air. I was tired and just wanted to get my baby home. They already took the pinstripe off for me at no charge. Heck, the air we breath is 78% nitrogen anyway.
Mouse6.2 is offline   Reply With Quote
Old 12-29-2012, 10:17 AM   #6
One-Bad-ZL1
I just went out and checked. No green caps with N on them and I didn't read anything when I got the car about nitrogen. So I'm thinking I'm ok cuz I added air to over inflate them for winter storage on the car. Thanks for the response.
Old 12-29-2012, 10:21 AM   #7
Mouse6.2
Mouse6.2's Avatar
You either get a cap with a green N on it of just green caps to indicate you have nitrogen in the tires.
Old 12-29-2012, 10:23 AM   #8
DangerZL1
The Nitrogen still leaked out of my Accords tires over time, so I decided not to use it again. The Camaro has been a little more stable. I think the dealers add it for mark up and to reduce complaints about the air pressure sensors since it is supposed to not leak out as fast.
Old 12-29-2012, 01:29 PM   #9
RiCorvette
RiCorvette's Avatar
Drives: 2017 Corvette Grand Sport 3LT
KOOK stuff (Keeper Of Odd Knowledge)
http://www.tirerack.com/tires/tirete...jsp?techid=191
RiCorvette is offline   Reply With Quote
Old 12-29-2012, 01:38 PM   #10
hairtrigger
Drives: 69 Chevelle SS396 2013 ZL1
We use nitrogen in our race tires and find the pressure dosen't grow as much due to less moisture.
Nitrogen in car DD tires is a waste of money, just maintain your car and keep the inflation in check. IMO
hairtrigger is offline   Reply With Quote
Old 12-29-2012, 06:02 PM   #11
lambo3
Drives: black
I would beg to differ with the thinking re; nitrogen. We purchased nitrogen machines in some dealerships we owned. I installed nitrogen in all my performance cars and it held an absolute pressure cold or hot and did not require adding more nitrogen or air for nearly 12 months in my Porsche turbo as an example. I am a nut about tire pressure and check it offen. If an installer has a good nitrogen machine it first cycles out all the air, and then it installs the nitrogen to the set pressure. Nitrogen is 99% dry and therefore is not technically affected by ambient air temps. Tires also carry less heat in hot temps with nitrogen.
lambo3 is offline   Reply With Quote
Old 12-29-2012, 06:14 PM   #12
Skylane765
Skylane765's Avatar
Drives: ZL1-1LE, Z/28, Challenger
I have a nitrogen tank at home with a regulator, I have nitrogen already for the plane. If it is dry air it will be ok, air is about 80% nitrogen. It is the water in the air they do not want to get to the sensors. Nitrogen leaks out just like air. We use nitrogen because of the high pressure and dry air. When you fill your tires with air it's no different than nitrogen, as long as it is dry.
Skylane765 is offline   Reply With Quote
Old 12-29-2012, 06:20 PM   #13
Skylane765
Skylane765's Avatar
the shops do not remove O2, they remove the water with a air conditioner type unit the cools the air to get the water out.
The dealer tried to sell me nitrogen fills for my tires, that a load of crap and a waist of money.
Old 12-29-2012, 06:26 PM   #14
Skylane765
Skylane765's Avatar
You are right, as long as the air does not have allot of water in it.
