BeckyD @ James Martin Chevy
Old 12-29-2012, 04:26 PM   #1
usmc-ashton
usmc-ashton's Avatar
Drives: 2010 camaro v6 black, bbk intake
Exclamation What causes a cylinder 5 misfire
My cel came on, went to autozone they diagnosed it as a cylinder 5 misfire. Also did an onstar diagnostics..they said multiple misfires what can cause this? How can it be fixed?? My car was in the shop for 4 months while I was deployed. Now I come back to this can it be fuel injectors or something? Help! I want to enjoy her lol
Happy holidays
usmc-ashton is offline   Reply With Quote
Old 12-29-2012, 05:58 PM   #2
ackeight
ackeight's Avatar
Drives: 10' 2SS/RS
check the plug and wire?
ADM tuned 412HP/407RWTQ. Kooks 2" headers w/ cats, ADM race intake, Vmax TB, Pedders XA coilovers and ZL1 sways. 1le clone
ackeight is offline   Reply With Quote
Old 12-29-2012, 06:18 PM   #3
usmc-ashton
If I do check it, what would I have to look for??
Old 12-29-2012, 06:37 PM   #4
GaBoy25
GaBoy25's Avatar
Drives: 2010 SS/RS M6/2500HD Lmm LTZ
Make sure plugs aren't cracked and that the plug wire is fully engaged in both ends (clicking into place)
Happened to me before
FASTER than my SS....for now
2500HD (with a couple parts)
Originally Posted by Coyotekiller View Post
I wonder if this could be why my car idles like its retarded...
GaBoy25 is offline   Reply With Quote
Old 12-29-2012, 06:47 PM   #5
AC
***GO HOGS GO***
AC's Avatar
Drives: 68/327 & 10 2SS SIM w/ CGM Stripes
At what RPMs did the misfire happen?
ProCharger F1A, ID1000 Injectors, SW Headers, SW full 3" Exhaust, BMR Suspension, CCW 10"/11.5", DBA Rotors, 3.91's, 560/570 hp/tq
ProCharger F1A, VMax TB, ID1000 Injectors, SW Headers, SW full 3" Exhaust, BMR Suspension & 4 Point Strut Tower Brace, 3.91 Gears, DBA Rotors
Heritage Grille, CCW SP16a Wheels 10"/11.5" Nitto 275/40 315/35, Painted Calipers, Blackout: Bowtie, Rear Panel, Markers & Side Vents,
SS Fender Badges, 6.2L Cowl Lettering, Pistol Grip Shifter, RPI SS Door Kick Plates, Billet Cup Holder, Fesler Shift Boot, Lloyd Floor Mats..(1/4: 12.917 @ 109.63)
AC is offline   Reply With Quote
Old 12-29-2012, 07:01 PM   #6
usmc-ashton
You dont really feel a misfire but around 2,000 rpms when you try to do a hard acceleration it'll kinda..well..it just won't pick up like before..and my wires seem fine there in properly. I hope it's nothing serious :(
Old 12-29-2012, 07:26 PM   #7
AC
***GO HOGS GO***
AC's Avatar
The reason i asked it sounds similar to what i had. when they ran the code it should have told them at what rpms the misfire happened. mine would misfire at about 3000 rpms on the 3rd cylinder. it was not misfiring under 3000 so it was very hard to diagnose. dealer had mine for 2 days tyring to figure it out, even gave it back to me 2 times thinking they fixed it. what finally fixed it was we switched the coils around....so im thinking bad connection maybe... they did put some updates on the computer and one updated rerouted the wiring harness. So not 100% sure what fixed it but that was 10,000 miles ago and all good.
Old 12-29-2012, 08:45 PM   #8
tonyko1
Banned
Drives: 2012 Camaro 2SS/RS Convertible, IBM
On a different car, not my Camaro, but I had misfire cylinder #3 on the diagnostic tool. Turns out the end of the spark plug that meets up with the wire harness came undone, like it wasn't screwed in all the way, which I never knew it could do (autolite spark plug). I changed out all the plugs to Bosch and it has been fine since.
Spark plugs are cheap, easy place to start.
tonyko1 is offline   Reply With Quote
Old 01-01-2013, 06:56 PM   #9
05stram
Drives: 2013 RS - 2013 2SS/RS - 1971 RS
misfire? a plug misfire or an injector misfire? Code would me most helpful. Setting for a little bit may be the key - fully charge the battery, run injector cleaner through it, and if it is still there let the dealer figure it out - cheapest in the long run instead of chasing parts.
05stram is offline   Reply With Quote
Old 01-01-2013, 07:05 PM   #10
Russell James
Russell James's Avatar
Drives: Camaros
I'd take it to the dealer. Many possible causes from simple to ... needs a new motor. Only way to tell will be to have a technician diagnose it.
A friend of mine went through some misfire problems with an LLT. One dealer farted around with it trying top engine cleaning, a few other things... then another dealer fixed it right by - replacing the engine. Really no way to know until a skilled technician looks at it. There are several bulletins for things to look for ... from minor to order a new engine.
Old 01-02-2013, 12:05 PM   #11
TooCool5
Take it to the dealer, there is a re-flash for this.
Old 01-02-2013, 02:37 PM   #12
SirPhobos1
Mean Machine!
SirPhobos1's Avatar
Drives: Formerly '10 SGM
Do you happen to know the TSB to reference for this? I experienced a rough idle/CEL this morning that I believe is related to the weather. A phone call to the service tech resulted with nothing.
If I have a TSB # to give him (and the document number #2542524 referenced in another thread was not a legit TSB number, at least to him) It would greatly help my case.
SECOND 2010 Synergy Green Metallic - 5/4/2012-4/15/2016
2010 Synergy Green Metallic - 4/21/2010-7/15/2011
Tint|RS Wheels|Tails Blackout|Bowtie Blackout|RS Halos
Heritage Grille|Kenwood Amplifier|Kicker Subwoofer|RS Gauges|General Tires
SirPhobos1 is offline   Reply With Quote
Old 01-03-2013, 08:05 PM   #13
TooCool5
Its SB PI 0284.
Let us know how it works out.
Old 01-07-2013, 10:41 PM   #14
SirPhobos1
Mean Machine!
SirPhobos1's Avatar
Its SB PI 0284.
The strangest thing happened.... my CEL light turned off before the shop could look at it. Guess I'll have to wait for it to happen again, IF it happens again.
I had the codes read at Autozone. Random misfires, Misfire in Cyl 01,04,06. Only happened once after letting it sit for a few days when we got a bunch of snow.
