Cold Air Inductions
Old 12-29-2012, 07:40 PM   #1
camaro actual
camaro actual's Avatar
Drives: 2010 Camaro 2SS/RS L99
pulley squeak/whistle
Started up my car and there was a whistle like sound coming from the engine. Opened it up and is seems like it is coming from the pulley on the top right behind the CAI tube? does it need to be changed out, belt tension seems okay? I don't have a problem getting under the hood but I just need to know what to do
Thanks
camaro actual is offline   Reply With Quote
Old 12-29-2012, 11:28 PM   #2
koolcamaro
Impossible=only a opinion
koolcamaro's Avatar
Drives: 2010 Camaro 2LT/RS RJT
You could always us a piece of wood, like a dowel or something you can put to your ear, put it on the little piece of metal behind the pulley and see if the noise is amplified or not. be careful not to hit the pulley while its running. (or you can but a stethoscope from a auto parts store. Does the noise go away after the car is warmed up?
koolcamaro is offline   Reply With Quote
Old 12-30-2012, 12:01 AM   #3
camaro actual
No, it got to temp and was still going. Will see what happens in start up etc. tomorrow.
Old 12-30-2012, 03:45 PM   #4
EvilBoost
Evil
EvilBoost's Avatar
Drives: 2012 Chevrolet Camaro SS
Mine does that whistle too, didnt notice it till I turned off my music lol which is rare... I think its semi normal....
Taking Performance Technology to a New Level
EvilBoost is offline   Reply With Quote
Old 12-30-2012, 11:37 PM   #5
camaro actual
Was checking it out. I think it is normal, and just like you it was because I had my music off that i noticed it lmao
Old 01-04-2013, 07:38 PM   #6
cornerspeed92
cornerspeed92's Avatar
Drives: 2013 1SS 1LE
I had a weird sound today,it was like a soft bearing noise coming from what i think is the top pulley, by the throttle body,is this what you are hearing?
cornerspeed92 is offline   Reply With Quote
Old 01-19-2013, 07:34 PM   #7
GATORJAK
GATORJAK's Avatar
I'm hearing this on mine too! I took the air intake tube off the throttle body. Then replaced it and tightened everything back down. The whistle is still there. I checked to see if it was coming from the by pass on the supercharger and it is not. It's running strong.
GATORJAK is offline   Reply With Quote
Old 01-21-2013, 12:53 AM   #8
DJ_BigC
Rockin' Steady
DJ_BigC's Avatar
Every time I worked on a Camaro or any GM vehicle that was fairly new that had a belt squeal, it was all related to the AC stretch style belt.
Eric Carrier, proud GM Technician for over 8yrs.
2010 Camaro 2SS Black, L99, SLP headers, GMPP axle back, complete JRE tune, 22" Boss 337's, Nitto Invos 5% tint, Eforce Supercharger w. 3" pulley, ADM FPCM, ID850's, JRE fuel rail mod, Eforce CAI, Moroso catch can, spark plug insulators.
DJ_BigC is offline   Reply With Quote
Old 01-30-2013, 07:46 PM   #9
SS_wicked_z28
Drives: 2012 Camaro SS
mine did this about 1000 miles ago and i thought it was water pump related.. dealership just changed th ebelt and it went away...then the other day the belt squeak came back and i feel like its the idler pulley..but mine gos away after its warmed up..either way it still annoys me because it never did it before..any thoughts?
SS_wicked_z28 is offline   Reply With Quote
Old 02-01-2013, 10:46 AM   #10
DCC1464
COTW 5/27/13
DCC1464's Avatar
Drives: '11 S/C SS/RS CGM
Im at the dealership right now getting my a/c belt changed for the third time for hopping off the pully.
622RWHP/512FTLBS on 91 octane
2.9l Whipple 4" pulley. Vengance VRSP3 cam. Lots of BMR & AAC. Body work by Gary's Customz. Nic D tuned
My build thread
DCC1464 is offline   Reply With Quote
Old 02-02-2013, 08:18 AM   #11
heymatt
heymatt's Avatar
Drives: 2012 IBM 2SS Vert.
If the belt is coming off the pulley that frequently. The pulleys are not in line! That's the first thing they should be checking.
LS3/M6 K&N, VMAX throttle body, RX Catch Can, skip shift eliminator, DT shorties and Solo HFC, DRL harness and 5K LED DRL, ZL1 rear sway, 1LE front sway
heymatt is offline   Reply With Quote
Old 02-03-2013, 11:08 AM   #12
blake-b
blake-b's Avatar
Drives: Black 2010
When mine made a noise, it turned out to be my power steering fluid was low.
blake-b is online now   Reply With Quote
Old 02-06-2013, 10:39 AM   #13
Chevrolet Customer Svc
Drives: GM Vehicles
We apologize for the inconvenience. How did the third repair on this go?
Brandon
Chevrolet Customer Service
Chevrolet Customer Svc is online now   Reply With Quote
