DJ Grilles
Go Back   Camaro5 Chevy Camaro Forum / Camaro ZL1, SS and V6 Forums - Camaro5.com > General Camaro Forums > 2016 Camaro: 6th Gen Camaro forum, news, rumors, discussions
Old 01-22-2013, 09:19 AM   #151
The IOM Ninja
Drives: 10' IOM 2SS/RS, 13' GB Shelby GT500
Originally Posted by Norm Peterson View Post
I like how you think.
I'd insist on the continued availability of at least 1LE-level chassis specs, but stop short of ZL1 dampers (unless the damping programming offered multiple choice and/or user tweaks).
Norm
Chevy should do exactly what Ford is doing IMO. The Benchmark for the 6th Generation Mustang GT is, allegedly to exceed, the Current BOSS 302. The next Generation Camaro SS/Z28 (Whichever it is, really the Z28 should be the track oriented model) should match or exceed the current 1LE Package. No more of that handling like a boat BS like the 2010+ Camaro without the 1LE Package...
I think Chevy should treat the Camaro more like the Corvette (Make Higher Trim option parts like PTM and Magnetic Ride Control Available on all model's or at the very least use Bilsteins on the SS/V6 to give an option between Firm and Soft Suspension on the Lower Trims.
Also get rid of the Automatic on the ZL1 and NA Track Models (Use either a Stick Shift or a Dual Clutch Transmission, However I doubt we will get that before the Corvette..., If that's not possible please match the feeling of the 370Z Automatic... It really knows how to kick you back in your seat on shifts)
The IOM Ninja is offline   Reply With Quote
Old 01-22-2013, 09:22 AM   #152
Mr. Wyndham
I used to be Dragoneye...
Mr. Wyndham's Avatar
Drives: 2014 Camaro 1LE
The ride of the 1LE and Boss can be somewhat harsh for the non-track daily-drivers out there buying GTs and SSs, though...I think it's a good thing to make such superior suspension calibrations optional.
"Keep the faith." - - Read Before You Post.
Past: 2012 Camaro ZL1 (For sale through Tom Henry Chevrolet)
Old 01-22-2013, 09:22 AM   #153
Gzilla
Drives: 2012 Camaro LS Silver Ice
Add to the 6th Generation Camaro
I would prefer my 6th Generation Camaro to have a Short Shifter come standard for the 6-speed Manual editions. Chevy may also want to consider a Targa top!
Gzilla is offline   Reply With Quote
Old 01-22-2013, 09:27 AM   #154
The IOM Ninja
Well the nice thing about the Boss 302 over the 1LE IMO is that you can adjust the suspension to soften it up (I can't for the help of me though remember if that is only on the Laguna Seca or across the Boss Line up). However a track oriented car will always be a lot stiffer than than say the GT or SS without 1LE. However the weigh loss should seriously benefit both cars in the handling department. They won't need as stiff of suspension with the weight loss! Again why I said make Bilstein Adjustable's available for the lower trims or allow MSRC as an option (at least on the higher trims)
Old 01-22-2013, 09:40 AM   #155
Mr. Wyndham
I understand what you're saying.
I guess what I was getting at was that I think it was wise of both Ford and Chevy to build the GT and SS with slightly more compliant suspensions for the sake of ride-quality for the masses. For that minority of us that would appreciate and use a stiffer, more sporty suspension could opt for the more expensive equipment. But this time, offer those packages from the get-go, instead of three years later.
Even the bilstein adjustable shocks can be pricey for a 'base' model of these cars. And as I understand it, they have two modes; stiff and stiffer.
Old 01-22-2013, 09:49 AM   #156
The IOM Ninja
I can speak from my experience with driving an M3 (with Bilsteins) as well as my GT500 it's actually quite a difference between the two suspension modes. It's undoubtedly stiffer than say MSRC but not to the degree that some people say (of course I have a different idea of what is stiff compared to the average person, my Camaro for example is looser than Pam Anderson IMO)
I agree that it would probably be too much of a cost to be standard unfortunately...
And yes I just started a GIF war with you!!!
Old 01-22-2013, 10:08 AM   #157
Mr. Wyndham
Whatever you need to believe to make you feel better about your..."shortcomings"...
Do not disagree, though. I've never driven with Bilsteins...and I'm openly a MagRide "fanboy". )
Old 01-22-2013, 10:12 AM   #158
fbodfather
fbodfather's Avatar
..............i wanna see more "Panics DuJour!"
Old 01-22-2013, 10:25 AM   #159
Mr. Wyndham
Welcome to Camaro5, kind sir!
We offer a selection of varying panics du jour, one for each day of the week at the discretion of our fine patrons. All of our dishes are prepared in-house using a recipe passed down for nearly 5 years!
Please take a moment to look over our menu:
Headlights brulee
SS grille con fail
Weight a la mode
Interior wish a side of pre-production texturing
Stuffed side-view mirror puffs
And presenting new additions:
No-V8 trifle
Poached new-gen design
Old 01-22-2013, 11:23 AM   #160
LT4Lover
LT4Lover
LT4Lover's Avatar
Drives: 2011 SG 2SS/RS,'97 30th Z28 SS LT4
Definately should have cooled front seats, also the color-coded grid in the rear camera view, and how about some more high-impact colors reminiscent of the muscle car era!
LT4Lover is offline   Reply With Quote
Old 01-22-2013, 12:30 PM   #161
Norm Peterson
corner barstool sitter
Norm Peterson's Avatar
Drives: 08 Mustang GT, 10 Legacy 2.5GT, ...
I don't think that the 6th gen Camaro is working under the same conditions as the upcoming generation Mustang. It's going to be a bit easier for Ford to set the new IRS GT at or above the current stick-axle Boss level simply because there's suddenly more NVH and ride quality headroom to work with. Once you're at IRS with a fairly seriously developed suspension and wheel/tire package, the gains tend to be smaller.
You have to keep them optional. Otherwise the package would either be unsatisfactory to most of the people at one end of the spectrum if it was tuned for the folks at the other, or not entirely satisfactory to many at both ends if an attempt is made to find a single hopefully acceptable point somewhere in the middle.
Norm
Norm Peterson is offline   Reply With Quote
Old 01-22-2013, 12:31 PM   #162
woodside783
Casey Woodside
woodside783's Avatar
Drives: 2010
3000lbs 500hp 500 tq z28
2013 camaro5 fest 4 camarocross modified champ
Instagram @caseywoodside
http://youtu.be/CSc9aPh_X_w
woodside783 is offline   Reply With Quote
Old 01-22-2013, 12:39 PM   #163
whiteknight012
+Will+
whiteknight012's Avatar
Drives: 2011 CAMARO RS (1LT) CGM/BLK
Two words:
T.
Tops.
"Celeste" - 2011 1LT/RS CGM/BLK -A member of CVC- Central Valley Camaros [Build]http://www.camaro5.com/forums/showthread.php?t=237634
whiteknight012 is offline   Reply With Quote
Old 01-22-2013, 01:02 PM   #164
Awill
Married
Awill's Avatar
Drives: 2011 Camaro 1LT/RS
Originally Posted by KMPrenger View Post
I don't really understand the "cartoonish" comments about the Camaro. It looks almost exactly like the concept Camaro, which was a jaw dropping design at the time, and still turns heads even today. Not trying to be an A-hole here, but sorry if your not into it, you are clearly in the minority.
I wouldn't mind a little better visibility, but the high beltline is one of the reasons the car looks so damn good. If that was lowered, it would look awkward. GM, do what you must to make the next design just as killer as this one.
Make the car lighter, and feel more nimble out on the road, and you have a winner. If the current car had those traits, it would still be top dog in the performance categories.
Awill is offline   Reply With Quote
Old 01-22-2013, 01:09 PM   #165
tony_c
tony_c's Avatar
Drives: 2010 Camaro 2SS, 2010 Equinox LTZ
New Hydro Silver paint
Less weight
More Z28
RS lights on all models
Bigger Spoilers on all models
Z28
Twin Turbo V6
Direct Injection V8
Z28
New Upper grill, not like the ZL1. Maybe like the Leno
Gills that you can see
New Rear Diffuser
Z28
Redesigned interior to make it even more sick
2014 release year
and Go Sabres
2SS/SIM L99
added:
New Era CAI, ARH LT's, HP tune, side SS badges, SLP Hood & Spoiler and gill stripes, Painted extended Black Rally Stripes
tony_c is offline   Reply With Quote
Old 01-22-2013, 02:33 PM   #166
cmoz28
Drives: 2011 Black 2SS/RS LS3
Twin-Turbo V6
Z/28
Completely Redesigned Interior (but keep it retro)
More Customization
cmoz28 is offline   Reply With Quote
Old 01-22-2013, 02:34 PM   #167
lbls1
lbls1's Avatar
Drives: 2002 Camaro SS SOM; 2009 Malibu LT
1. Improved acceleration against Mustang variants.
2. Reduced weight.
3. Distinctive styling with cues to the camaros of yesteryear. Refrain from using contemporary japanese or european styling trends.
4. Don't even think about a turbo v6 for the Camaro SS and above. It would be better to eliminate the 'SS than to compromise it with a 6 or 4 cylinder engine.
5. More exciting color choices. For me, the 5th gen left me wanting a bit for enticing color choices. The ABM was a nice start but since it was eliminated, I was left without a suitable replacement (BRM and CRT were nice choices though).
The fifth gen did a great job in resurrecting the camaro. The camaro has to gain a bit more ground in its acceleration and power numbers with the top of the line camaro going forward.
'02 CAMARO SS SOM; 5.7L LS1/FLS6B
'08 TBSS AWD Black Granite Metallic
'09 Malibu LT Dark Gray Metallic
'14 CAMARO ZL1 Blue Ray Metallic
lbls1 is offline   Reply With Quote
Old 01-22-2013, 02:46 PM   #168
SS4Fun
and that it is!!
SS4Fun's Avatar
Drives: 2010 SLP ZL575 #70
Paint.................. it currently sucks!!!!!
SS4Fun is offline   Reply With Quote
Old 01-22-2013, 02:47 PM   #169
fbodfather
fbodfather's Avatar
Headlights brulee
SS grille con fail
Weight a la mode
No-V8 trifle
Oh my!
You're as surly as I am!!!!!
(...I KNEW I liked you for some reason!!!)
to everyone else: Just kidding!
We ARE looking at your notes.
Some are doable - some are not.
Further, you're very well represented by our "12 Disciples of which there are 15!"
Old 01-22-2013, 02:59 PM   #170
fbodfather
fbodfather's Avatar
ah yes -- hideaway headlamps.
Now - before I go further: I LOVED hide-away headlamps on the 1st gens - as well as Corvette and Caprice (68, 69) and El Dorado (67 and 68) --
That said: has anyone EVER seen a 1st Gen Camaro where the headlamp doors align properly?
Also - it adds a ton of weight.
What IS true: lighting comes in several forms today -- does it HAVE to have doors? What about 'hidden' behind grille bars?
I see some good stuff here....but a word of caution: I want you to think about the weight issue. How important is it? Remember -- the car must remain 'refined' as the 5th gen in terms of everyday use - and it must earn a 5-star crash rating. I bring this up because if you look thru the thread - there are many "lose weight!" followed by "Cooled seats" ( +weight!) "Cimate Control" ( ++ weight) "Hideaway headllights" ( + weight!) "T-tops" (++++++++++++++++ weight!) etc.
Take some time and think it thru............we're listening.
(...but while our engineers are amazing, they haven't yet figured out how to change the rules of physics......they're workin' on it...........but...........)
Old 01-22-2013, 03:07 PM   #171
BigRed82
Drives: 2013 1LT RS Camaro
Blind spot monitoring. My wife's car (Mazda) has it and it's fantastic.
Standard rear view reverse camera. Again, my wife's Mazda has it.
NAVIGATION without a monthly fee. It's 2013!!!
BigRed82 is offline   Reply With Quote
Old 01-22-2013, 03:18 PM   #172
v6sonoma
v6sonoma's Avatar
Drives: 2010 SS RS
Hmm good point about the weight. Guess we'll just have to fix that with Horsepower!
9/26/09 Took delivery!
Old 01-22-2013, 03:24 PM   #173
kobSS
kobSS's Avatar
Drives: 2010 2SS/RS
Agree with the fbodfather... Hide aways are a cool concept, but have too many negatives.
I actually think the HID RS lights are spot on. Great functionality, and make the car recognizable.
2010 CGM 2SS/RS:
Pfadt'ed Out Level 4, Pfadt Featherlight Coilovers, Pfadt ZL1 Sways, Pedders Radius Rod Inserts, CTS-V Brakes, Borla S-Type, Quad Tips, Forgestar 22" F14's (Show), CAI Intake w/ scoop, Rx Catch-Can, AAC Lighting, Showstopper Sidemarkers
"Information is the oxygen of the modern age"
Build Thread
kobSS is online now   Reply With Quote
Old 01-22-2013, 04:28 PM   #174
tsnow
tsnow's Avatar
Drives: 12' ZL1, AGM 6M
fbodfather, thanks for posting your thoughts!
Many great ideas posted so far.
Weight target should be 3400 with a v8.
Continue the 1st gen theme, the next gen will be slightly smaller, and on a different platform so it will look different than our current car. Dont forget 1st gen cues are why the current car has been so successful.
I love my 12', but-
Slim the rear end a bit, current car has a "fat butt" look. 1st gen cars have that muscular, sporty look but have a simpler, lean feel too.
Front end- less pinched, less evil. Still sporty, but like the first gens, cleaner and leaner.
Paint durability, if europe can do it we can too. Strategiclly placed clear film another option.
LED lighting packages. Like the behind grille light bar vs actual hideaway lamps idea.
Updated interior electronics package (color graphics, HD screen(s), many guage display options) abllity to choose from ECM PIDS what to display in HUD or dash info center. C7 and current ZL1 come to mind here.
In dash shift light bright enough to work from peripheral vision.
Yes Fbodfather, auto climate control. A sensor or two and programing, worth the minimal weight gain.
Modern interior with minimal cues to previous generations.
Same LT1 v8 as vette option. No detuning.
No t-tops.
Hold the line on pricing, 35G for loaded v8 trim.
LT HO 4 or DI V6 engine options (sporty, fun, fast)
SS V8, sport suspension (affordable muscle) Mag ride optional?
Z28 V8, with manually adjusted shocks, track suspension (affordable, track capable)
ZL1 Blown or larger displacement V8 (650-700hp), mag ride (top dog)
Yes, the next gen is a huge challange. Keeping the car within weight targets without the use of carbon and other exotic materials that would drive the price up is difficult. Ok, we have to remember this is not a Corvette, but it better be lighter than the next Mustang.
If this is done and paired with these new DI V8s and trick V6's we will have another American Hot Rod that goes in the history books.
Team Camaro you have done a great job so far, LT and SS and esp. the 1LE and ZL1!
tsnow is offline   Reply With Quote
Old 01-22-2013, 04:38 PM   #175
Mr. Wyndham
Originally Posted by tsnow View Post
but it better be lighter than the next Mustang....
Devil's advocate....if the Mustang is lighter (again...only this time, it's not as huge a difference due to earning an IRS), yet the Camaro is a solidly-build vehicle and the Mustang is a comparably flexy car....how would you feel?
2015 camaro, 2015 camaro forum, 2015 camaro forums, 2015 chevrolet camaro, 2015 chevy camaro, 2016 camaro, 2016 camaro forum, 2016 camaro forums, 2016 chevrolet camaro, 2016 chevy camaro, 2017 camaro, 2017 chevy camaro, 6 gen camaro, 6th gen camaro, 6th gen camaro forum, 6th gen camaro forums, 6th gen camaro info, 6th gen camaro news, 6th gen camaro rumors, 6th gen chevrolet camaro, 6th gen chevy camaro, 6th gen chevy camaro forum, 6th generation camaro, 6th generation camaro info, 6th generation camaro news, 6th generation camaro rumors, 6th generation chevy camaro, camaro 6th gen, camaro 6th generation
Copyright ©2000 - 2014, vBulletin Solutions, Inc.
