Old 12-31-2012, 01:37 PM   #1
Retro69
Retro69's Avatar
Drives: 2011 2SS M6 Synergy Green
So Why Not Use Rear O2 Sensors LT Headers?
Just wondering why rear O2 sensors are not used with long tube headers?
Sent from my DROID BIONIC using Tapatalk 2
480 rwhp ERL 416 ci with JDP Stage II Big Bore Cam
JDP tune, CAI intake, Dynatech LT headers, hi-flow cats
VMAX CNC Ported TB. GMPP Z/28 suspension package
Prothane sub-frame bushings.
Retro69 is offline   Reply With Quote
Old 12-31-2012, 01:42 PM   #2
Matt @ FSP
Matt @ FSP's Avatar
Drives: 2011 Camaro SS
You can still install them, however, they are useless after being put so far down line, behind (Or in) a high-flow cat or non-catted pipe... They basically just grab information to tell if the catyllitic converter is working efficiently or not. Once you go with the LTs with the highflows or no cats, the calibration is too far off to work with them so thus rendering the rear o2's useless. So no reason to install them or not.
Matt @ FSP is offline   Reply With Quote
Old 12-31-2012, 01:54 PM   #3
Retro69
Retro69's Avatar
So are they useless due to the reduced exhaust temperature?
Old 12-31-2012, 03:58 PM   #4
Tampa Tuning
Drives: TAMPA TUNING FACEBOOK & INSTAGRAM
You can tune around your Cats to make the rear 02 works effectively, but most shops just turn them off because the rears are only used to measure the effectiveness of the cats.
You do need your front O2s in working order.
Phil
www.TampaTuning.com
Tampa Tuning is offline   Reply With Quote
Old 12-31-2012, 04:05 PM   #5
Retro69
Retro69's Avatar
So is this basically why LTs can't get CARB certified?
Old 12-31-2012, 04:20 PM   #6
Matt @ FSP
Matt @ FSP's Avatar
Goes a lot deeper than that too. You cannot get the proper emissions from the LT header/aftermarket high-flow cat.
However, ARH's SHORTY headers actually are cleaner emissions-wise than the stock exhaust manifolds. They are CARB certified. Once again, Shorty's with the stock cats though.
- Matt
Old 01-01-2013, 07:29 PM   #7
Retro69
Retro69's Avatar
Thanks for all the great info guys.
Old 01-01-2013, 08:23 PM   #8
LBV
LBV's Avatar
Drives: G8 GXP manual
Use the rear holes for a wideband to measure your AFR when tuning or checking on a canned tune.
2009 GXP, Manual with Sunroof
Zeta platform, LS3,TR6060 tranny ... ya, it's a 4-dr Camaro!
Borla cat-back, H&R springs, & Sprintbooster & I love it!
LBV is offline   Reply With Quote
Old 01-01-2013, 09:44 PM   #9
rberns
rberns's Avatar
Drives: 2011 Camaro 2SS/RS
I just bought some ARH LT. question, when installing do you still plug the rear O2 sensors in even thought they don't do anything or do you just let them dangle?
2011 Camaro 2SS/RS, Circle D 3200, ADM Transmission Cooler, BTR Valvetrain, Cam Motion .621 .595 228/244 113+4, ARH 1 7/8, Cold Air Inductions, Katech C5R TC, Melling HV, BTR SLR lifters, Trunion Upgrade, LS2 Dampner, LS9 head gaskets, Bo White PTB, RX CC, GFX, Subs.
rberns is offline   Reply With Quote
Old 01-01-2013, 09:50 PM   #10
Matt @ FSP
Matt @ FSP's Avatar
You can plug them in that's fine.
