SDPC
Old 01-01-2013, 01:10 AM   #1
Kiwi_Camaro_2010
Kiwi_Camaro_2010's Avatar
Drives: Camaro 2SS/RS 2010 L99
LC1 wideband controller X3 analog logging issue
Hey Guy's, just have installed LC1 wideband controller with adm gauges, I'm trying to log analog on second output from LC1 to SCT X3, I'm using 0-5v output on firewire pins 3(+) (analog1) & pin 4 (-)(analog1 GND) using Livelink GEN 2, I cannot get it to register any readings in Livelink Gen2 either in voltage or AFR, I have check firewire cable & I have voltage at end of cable that plugs into SCT X3 but thats it, all my other PIDS are logging correctly just no analog input, any ideas most appreciated as I need this working to finish tune with my tuner as I think I'm running rich at WOT, gauge read roun 10.2. SCT X3 says it's running latest firmware, Livelink GEN 2 is ver 2.0.16.0
Camaro 2SS/RS 2010 / L99 / Whipple SC /Dynatech Headers & Catts (gutted), ID 850 injectors, ZL1 fuel pump +BAP & ADM pump controller, ZR1 3Bar MAP, Dual Elite Catch Cans, 91 octane ,Eibach sway bar kit , Driveshaft loop, oil cooler delete, ADM dual gauges (AFR/Boost) LC1 wideband controller, D/D, ARP stud kit ,Callies forged slayer crank 3.622", callies ultra rods, wiseco forged pistons, L99-LS3, rollmaster double row steel timing set & comps cam timing cover,blower cam 630/660 lift,3/8 pushrods, pac gear 8deg, yella terra ultra lites. LS9 head gaskets. Texas speed custom oil pump. Asm by me.
Kiwi_Camaro_2010 is offline   Reply With Quote
Old 01-02-2013, 11:51 PM   #2
Kiwi_Camaro_2010
Bump
Old 01-03-2013, 11:42 AM   #3
Badbubba
GrINned & JUICEd
Badbubba's Avatar
Drives: '15 STI, EB Expy,'10 2SS/RS M6, KB1
Is it a 6 or 7 wire cable for your lc1? If it is a 6 wire cable, the + from your lc1 should go to 3 on the firewire and 4 on the firewire should go to a good ground. If it is a 7 wire cable, the lc1 manual states there is an analog ground wire from the lc1, so that would be connected to pin 4 on the firewire. I'm guessing you have the 6 wire cable and have used a digital voltmeter to measure the voltage. With the lc1 on and the car not running, afr should be spiked and the analog voltage should be 5 volts. Be certain you have a good ground and your logging more than 1 pid. If your getting voltage, then it's time to call SCT. My firmware is about 6 months old, not as up to date as yours. Mine will log afr voltage, but will not convert it to afr.
Nitrous Outlet Plate (progressive, fuel hose upgrade, remote opener, heater, filter, console switches), LNC2000, ARH 1 7/8" LTs/gutted cats/X pipe/mufflers, Jet Hot coated LTs, JRE SCT Tune, CAI, Scoop, Rx Catch Can, Gates heater hose relocation, Remote clutch & auto brake res, Metco loop, Momentum Tunnel Brace, TSW Nurb 18" 555 & 555R, Pfadt trailing arms & toe rods, Autometer wideband, Fesler Pillar Pod, LED strips (int), Lloyds floor & trunk mats, LED DRL/front turn & license plate, DRL harness, VLEDs tail lights, Plasticoat Bowties. Ord: Oct 5, 2009 Rec: Nov 19, 2009 13.17 @ 112.6 stock
Badbubba is offline   Reply With Quote
Old 01-03-2013, 02:22 PM   #4
Kiwi_Camaro_2010
Hey thanks for reply, yes mine is only 6 wire setup, was a bit confusing, adm using old instructions with their gauge setup, I do have air leak issue to sort which is upsetting my afr reading at moment but i'm still getting voltage (1.9v) at end of firewire cable so technically should still get a analog reading from it. I have selected approx 15 PIDs with analog1 & 2 just in case & all other PIDS are logging correctly except analog. I have emailed SCT, they want me to ring to sort out, so I will need to do that, unfortunately time zones mean calling at 2.00am, another late one
Old 01-03-2013, 05:23 PM   #5
Badbubba
GrINned & JUICEd
Badbubba's Avatar
What is your firmware # on the handheld?
Old 01-06-2013, 05:57 PM   #6
Kiwi_Camaro_2010
X3 is at 1.2.140 ver 2.003PGUSC
say's it's latest in auto update program, still can't get it to log yet, another phone call in order I think.
Old 05-14-2013, 04:05 AM   #7
Kiwi_Camaro_2010
Thought I'd post in case someone else has same problem, issue resolved finally. Ended up being firewire cable incorrect color coding, apparently all manufacturers do not stick to standard color format for firewire, purchase approved SCT firewire cable now all logging AFR as it should.
Old 05-14-2013, 07:05 AM   #8
Badbubba
GrINned & JUICEd
Badbubba's Avatar
Good and nice to know why.
Old 05-14-2013, 10:48 AM   #9
JANNETTYRACING
PRESIDENT CALIBRATOR JRE
JANNETTYRACING's Avatar
Drives: YELLOW 2013 ZL1 AUTO
Great info, thanks for Sharing.
Ted.
Technical information, Parts Sales, Professional Installation, and Custom Dyno Tuning.
Please vist our web sites for all your performance needs!
Ted Jannetty
Jannetty Racing Ent Inc.
2984 East Main St.
Waterbury Ct. 06705
203-753-7223
tedj@jannettyracing.com
www.jannettyracing.com
www.turboaddictionparts.com
Performance Parts
Old 04-16-2014, 03:49 AM   #10
Tuborg
Tuborg's Avatar
Old thread but, i am trying to datalog from sct x3 to laptop, has ben working great until now when i trying to log Wb from analog, i have readings to the sct but when i using that pid (analog1) it is not showing annything, not analog or any of the other pid`s. Do anyone no what to do. It does record but not showing any readings.
Thanks.
Slp supercharged, Halltech Cai, Jannetty tuned, Custom exhaust, Pfadt lowering springs, Pfadt rear trailing arms,Pfadt tierod link,
Catchcan.
Tuborg is offline   Reply With Quote
Old 04-16-2014, 07:04 AM   #11
JANNETTYRACING
Thanks.
Are you using an SCT Brand firewire cable?
Ted Jannetty
2984 East Main St.
Waterbury Ct. 06705
203-753-7223
Performance Parts
Old 04-16-2014, 08:51 AM   #12
RickRay
INJACC
RickRay's Avatar
Drives: 2010 CGM 2LT/RS AUTO
Thanks.
Maybe your laptop might have still Windows XP & it doesn`t support it anymore...just my guess
Member of 'Club Elite' #70
2LT/RS Auto / Solo HFC /Solo Mach X-LLT J-Pipe / JBA Headers Shorty
CAI - Cold Air Inductions / VMAX TB / Trifecta Tune
Hotchkis Max Strut Brace / Blade Dovetail Spoiler / Elite Catch Can
ACS T3 Hood Ports / T2 Bumper Ports / T2 Splitter / ACS T1 Led Light Kit
ACS Rockers / ACS Composite Hood Liner / ACS Upper Rear Quarter Ports
ACS Front Wheel Mud Flaps / ACS Rear Wheel Mud Flaps / Vitesse Throttle Controller
Pedders Drop Suspension / BMR Lower Control Arms / Style 41 ZL1 Wheels /
Oracle Afterburners / Oracle Concept SMD Side markers
Complete SS Brembo Brakes Set
RickRay is offline   Reply With Quote
Old 04-16-2014, 09:13 AM   #13
Tuborg
Tuborg's Avatar
I am jusing Windows 7,loging without analog1 is fine not a problem,and i have a cable from a computercompany that i have cut one end of and conected to lc1 using pin 3 and 4 and i got it working in the sct but not to the computer i am pretty sure i got the cabels right i did not go by color i used an ohm meter.
Thanks.
Catchcan.
Old 04-16-2014, 10:39 AM   #14
2SSCAMARO
2SSCAMARO's Avatar
Drives: 2010 Camaro Auto
Thanks.
It sounds like you have not set up the hand held analog function to work in pass through mode. You need to select the monitor setup function on the hand held and then select the analog1 function and then select the proper formula for your WB. You only need to do this once and then after that the analog data will pass through the hand held and into the lap top loaded with the live link software. You also (one time) need to bring up the config file in live link, select tools, then equations, the select one of the preset equations like for example (v*2)+10 and then click on the green arrow for analog input 1. You should be good to go.
Just livin' life
2SSCAMARO is offline   Reply With Quote
