Elite Engineering
Old 06-11-2009, 08:08 AM   #1
larietrope
Drives: 1970 Boss 302
anyone changed their own oil yet ?
How hard/easy to get get to filter/oil plug ?
8 quarts synthetic ?
larietrope is offline   Reply With Quote
Old 06-11-2009, 09:10 AM   #2
jody
Drives: 1968 camaro 496 bbc
Yea I changed mine this past weekend It's easy as it gets I used 10w40 valvoline sythetic blend it helped the oil psi about 5 pounds.It holds just over 8 qts w/filter
jody is offline   Reply With Quote
Old 06-11-2009, 09:12 AM   #3
jody
This is for 6.2 engine
Old 06-11-2009, 09:21 AM   #4
Geno
Drives: 2013 Hyundai Genesis Coupe GT
I DID NOT THINK 10-40 WAS RECOMENDED FOR ANY NEW ENGINE ANYMORE??????
Geno is offline   Reply With Quote
Old 06-11-2009, 09:43 AM   #5
2010 2-Tone
2010 2-Tone's Avatar
Drives: 2010 RY 2SS with Custom Stripes
What weight and viscosity does the 6.2 ask for? Anyone??
2010 2-Tone is offline   Reply With Quote
Old 06-11-2009, 11:00 AM   #6
bumblebee rules
bumblebee rules's Avatar
Drives: 2010 BumbleBee ready to go now
6.2 l should have 5w30 sythetic ......... Very easy to do , just have a BIG drain pan LOL ... OOPPSS 8 l :-)
bumblebee rules is offline   Reply With Quote
Old 06-11-2009, 01:20 PM   #7
larietrope
Can you get under the car without jacking it up to change oil/filter ?
Old 06-11-2009, 04:07 PM   #8
Scott@Bjorn3D
Scott@Bjorn3D's Avatar
10-40, ohh boy, get ready to replace some seals. You will start blowing by them with that oil making that kind of pressure in the engine.
Scott@Bjorn3D is offline   Reply With Quote
Old 06-11-2009, 04:43 PM   #9
bumblebee rules
You have to lift the car ........ Or have 8foot skinny arms .... Also use jack stands --- saftey first
Old 06-13-2009, 10:47 PM   #10
02b4c
02b4c's Avatar
Drives: 63 splt wnd 55 chev 08 1500
changed mine today 775 miles. Drained oil filter,small shiney STUFF came from the filter.I will cut open the filter tomorrow to look inside.
02b4c is offline   Reply With Quote
Old 06-14-2009, 06:17 AM   #11
maxdmax
maxdmax's Avatar
Drives: 2010 Camaro SS/RS
I changed my oil last week and my floor jack would not fit under the car. I used 2 of the square RV honeycomb square leveling blocks. I used one under each front tire, it raised the car an inch or two just enough to get the floor jack under the front cross member. Found great places for the jack stands without a problem. Even though the filter is vertical there is a lot of oil that comes out when you remove the filter. The oil plug is in a good place and does not get any oil on the frame at all. The oil pan looked and felt like aluminum so remember to be careful and do not over tighten the oil plug.
Also save your receipts and document the mileage and your work, you may need it down the road if you have issues and have to take your car to the dealer in the future. I save my receipts and box tops of my filters
LPE 417 - TVS2300 787 RWHP 759 Torque - Built by WWW.KYSPEED.COM
maxdmax is offline   Reply With Quote
Old 06-14-2009, 08:25 PM   #12
Ject
aka Patrick
Ject's Avatar
Drives: '10 Camaro 2SS '04 Silverado
Send a message via Yahoo to Ject
5w30 Mobil 1 Synthetic.... 8 qrts... sounds about right.
Current Modifications: Your average Bolt-ons & Suspension Upgrades
GForce Engineering: 9" Rear End, Strange Pro Iron Case w/Moser Nodular 3.70:1 Detroit locker, 3.5" Solid Drive Shaft
Ject is offline   Reply With Quote
Old 06-14-2009, 09:14 PM   #13
b4z
Drives: '06 Pontiac GTO M6, '09 V8 SRX RWD
why would you put 10w-40 in?
5w-30 or if you live in a hot climate maybe 10w-30, but not 10w-40.
b4z is offline   Reply With Quote
Old 06-14-2009, 09:21 PM   #14
mlee
www.CamaroFest7.com
mlee's Avatar
Drives: 2016 Silverado
5W30 and it does NOT take over 8 qts... It may look like it needs more but it takes a few minutes to settle.
I bought a K&N filter for 15 bucks at a local parts store. Then you don't have to worry about the oil change place not listing your filter or putting a generic brand on. Get ready to shell out 100 for a good oil change...
How about a barrel of oil for around $16? Blownhotrodder General Automotive + Other Cars Discussion 19 03-06-2009 08:25 PM
Synthetic? shroomjohn Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons 40 09-18-2008 02:31 PM
The 3,000 Mile Oil Change Myth KILLER74Z28 General Automotive + Other Cars Discussion 35 07-20-2008 10:02 PM
