Jason 98 TA
Go Back   Camaro5 Chevy Camaro Forum / Camaro ZL1, SS and V6 Forums - Camaro5.com > Other Generations > 1st & 2nd Generation Camaros
Old 01-01-2013, 04:02 PM   #1
jmh1cam2
Drives: 1968 camaro R/S
1968 Camaro block heater box
My 68 Camaro has a small block heater box.
I would like to replace it with a big block heater box.
Will they match up or is there a big difference?
jmh1cam2 is offline   Reply With Quote
Old 01-01-2013, 05:18 PM   #2
Lorich1
Lorich1's Avatar
Drives: 2011 Camaro 2SS / 1968 camaro Z28
It will fit, but the heater cores are different. The metal lines are in a different location to clear the big block valve cover.
Sent from my iPad
Lorich1 is offline   Reply With Quote
Old 01-01-2013, 05:31 PM   #3
WiSSDiver
WiSSDiver's Avatar
Drives: 1968 Coupe, 2010 2SS, 2011 2SS/RS
There is a 1st Gen section on here as well.
That said, you may be able to check your local parts store to,see if they have an adapter that allows the big block heater to fit on the small block. If not, Check a Local speed shop as well to see if they know of some one that does custom mode work if you're not comfortable doing it yourself.
WiSSDiver is offline   Reply With Quote
Old 01-01-2013, 06:14 PM   #4
05stram
Drives: 2013 RS - 2013 2SS/RS - 1971 RS
they both come out the top but on the big block both lines come from the right side of the core while the small block has a line on the left and the right. If I remember right the core holes are different as well. The boxes the only difference is the big block box has more room to clear the exahust manifold and the 396 valve cover and of course the holes. If you are doing cooling I think you need to check the hoses as the big block if I remember right had a big crook on the suction side.
05stram is offline   Reply With Quote
Old 01-02-2013, 07:34 AM   #5
MLL67RSSS
Drives: car
Just a FYI, this thread will most likely get moved to the first gen section.
Shouldn't be a problem. On the small block heater box/core the lines come out on the extreme right end of the box (red arrows) and the lines interfere with the big block valve covers. The big block box is the same stamping but with a hole cut for the lines to come out the middle (blue arrow) and the heater core is different. Might even be able to cut a hole for the big block core in your original small block box. You'll have to change the heater core as well, but it would be pretty crazy to tear into something like this and not spring for a new core anyway. Link to a site with good price, plus it comes with some of the other stuff as well.
http://www.camarocentral.com/product_p/htr-57.htm
You'll also may need the big block core mounting clips:
http://www.camarocentral.com/1967_19..._p/htr-395.htm
With these two things (and the clips above) and a big block core you could mod your small box block box for big block core:
http://www.camarocentral.com/product_p/htr-62.htm
http://www.camarocentral.com/Product...uctCode=HTR-61
MLL67RSSS is offline   Reply With Quote
Old 01-02-2013, 11:00 AM   #6
67badbird
67badbird's Avatar
Drives: 2010 Camaro 2SS/RS 1967firebird 632
Yes it will work $80.00 for the Heater core $50.00 for Box assembly!.. from classic Ind.
67badbird is offline   Reply With Quote
Old 01-04-2013, 06:35 AM   #7
flyingskibiker
flyingskibiker's Avatar
Drives: Cars, Trucks, Bikes, ORVs, Planes
Send a message via Yahoo to flyingskibiker
Simple. As stated. But the clips don't fit worth beans. And the cores are incorrect from some vendors.
Go to camaros.net Team Camaro forums. There is all the info you will ever want to know about repairing or modifying your car. Or go to camaros.org to find out facts about Camaros.
1968 SS w/ 1966 427/425 Sequoia Green w/ Bumble Bee stripe. Always working on it...
Drooling over the ZL1s. It will be my next car if I can manage to pull it off...
flyingskibiker is offline   Reply With Quote
Old 01-19-2013, 09:53 PM   #8
lpar1969
lpar1969's Avatar
Drives: 2014 1SS NPP 1LE
1968 camaro heater box
I did the conversion because I did not like the look of the sbc heater core exiting out of the sides, like the look of the center exit like big block. made a template and drilled holes in the small block heater box. replaced heater core with big block heater core.
lpar1969 is offline   Reply With Quote
