Old 01-03-2013, 08:01 PM   #1
47AJV8
Drives: A White Car
Paint over Plasti-Dip?
I was wondering if anyone knew if paint would adhere to a surface already painted with pasti-dip? And also, after it was painted over, could it still be removed like plasti-dip normally can? I am not a fan of the matte look, and their "glossifier" doesn't really seem to make it look much better, I really like metallic paints so.. You can probably figure out what I'm getting at!
"From ABS shudder that came on surprisingly early in the lousy brake pedal's travel to a looser rear end than Kim Kardashian"
47AJV8 is offline   Reply With Quote
Old 01-03-2013, 11:13 PM   #2
Stud
Stud's Avatar
Drives: 2012 1LT RS RY
I'm not sure if you have seen this, but dipyourcar sells plastidip that makes plastidip metallic.
https://www.dipyourcar.com/home.php?cat=11
If that doesen't help, try contacting dipyourcar by phone and they can give you a straight up answer.
Stud is offline   Reply With Quote
Old 01-04-2013, 10:37 AM   #3
carrs_crew
Livin the Dream
carrs_crew's Avatar
Drives: sold
the gentleman at home depot suggested going with a poly to go over the plasti dip to give it that gloss look, haven't tried it yet but have the paint to try. I would think if you mask off so the poly does not extend past the dip then you "should" be able to peel off. keep us posted
carrs_crew is offline   Reply With Quote
Old 01-04-2013, 11:40 PM   #4
MoCamaro10
Drives: 2010 Inferno Orange Camaro
I had the same question too, so i had tried it on an old motegi wheel. I painted over the plastidip with some blue metalcast spray paint. It does work, but make sure you do plenty of coats with the dip first. If you don't you wont be able to pull off big strips it will only come off in dime sized pieces.
MoCamaro10 is offline   Reply With Quote
Old 01-06-2013, 12:10 AM   #5
Camaro2SS2012
Drives: Land Rover LR4
I did it, and would not recommend it. The answer to your question would be yes, it will come off as long as enough coats of plasti-dip are applied first (with no glossifier on top).
It didn't look right, and began to peel around the edges of the rim after just a week or two. I ended up going the powder coat route after wasting a lot of time (and money). My recommendation would be to do it the right way and powder coat them. It makes a world of difference.
Camaro2SS2012 is offline   Reply With Quote
Old 01-06-2013, 01:53 AM   #6
47AJV8
Drives: A White Car
okay thanks, seeing how sick your car looks sounds like a good idea!
dip, paint, pasti
