SDPC
Old 01-16-2013, 04:26 PM   #29
Harley Kidd
Drives: Black 2013 2SS/RS LS3 M6, Hurst
Thanks for the post and instruction. I did this a couple of days ago on my 13' 2SS and now I like my car even better.
Harley Kidd is offline   Reply With Quote
Old 01-16-2013, 04:57 PM   #30
FINALLYSATISFIED
Est.1775
FINALLYSATISFIED's Avatar
Drives: '15 Challenger Hellcat
Glad I could help!
FINALLYSATISFIED is offline   Reply With Quote
Old 01-16-2013, 09:19 PM   #31
ZL1ster
ZL1ster's Avatar
Drives: '13 ZL1 IOM M6
+1, much thanks!
Did the Fuse Pull...and the wow-factor just spiked!
ZL1ster is offline   Reply With Quote
Old 01-16-2013, 09:29 PM   #32
FINALLYSATISFIED
Est.1775
Originally Posted by ZL1ster View Post
+1, much thanks!
Old 01-27-2013, 09:56 PM   #33
camguynj
camguynj's Avatar
Drives: '13 SS/RS LS3 NPP BRM
Great specs, thanks. In other posts regarding how to get to fuse box to install Mild2Wild exhaust controller it mentions & shows the need to lift the rubber trim on top of the liner. Did you have to touch that at all ? Also, the top liner rivet can be removed fairly easly with a hard plastic trim tool without ripping the liner . It will bend some of the rivet threads but it can still be used to put back in.
camguynj is offline   Reply With Quote
Old 01-27-2013, 11:29 PM   #34
FINALLYSATISFIED
Est.1775
Rubber trim? Not sure what that is? Did the DIY work for you?
Old 01-28-2013, 06:42 AM   #35
camguynj
camguynj's Avatar
Here' the rubber trim piece (ie. deck lid seal) I was referring to in the other post about how to get to the fuse box to install the Mild2Wild controller... "Remove the deck lid seal...just enough to pull the trunk latch carpet panel up and out." Did you have to lift the trunk latch carpet panel in order to lift the passenger side carpet panel to access ther fuse box?
I have not yet done the DIY. I just removed the rivets to see how hard the top one was to remove. I'm currently waiting on the Mild2Wild controller to come b4 procedding, but I'd like to do the "fuse pull" first using your technique.
Performance:
CAI, Ported TB, Hurst ShortShifter,SkipShift Eliminator, 3.91 gears, Spohn rear TAs, BMR rear swaybar, Hedmen Shortys, Solo HF Cats, QTP Cutouts, DashLogic,Elite CC,Vitesse Throttle Controller,CurbAlert
Appearance:
20" Nitto Redlines, Rocket Muscle Boosters w/knockoff spinners,
Underbody LEDs, Footwell ,Dome & Door pull LEDs, RapidFire LED Tailights , DRL LEDs, Chrome Ghost parking lights,
Lloyds Mats, SS Kick Plates, Bowtie Hoodliner, '67 fender flags, Billet pedals, Heritage SS grill & deck emblems, rear deck blackout, custom engine brace
Old 01-28-2013, 07:21 AM   #36
SUKXOST
Do you even lift, bro?
SUKXOST's Avatar
Drives: 2013 1LE Camaro
Did mine with finally filming:
My 1LE (645WHP/597WTQ) build/journal Thread:
1st ever 1LE COTW http://www.camaro5.com/forums/showthread.php?t=255461
SUKXOST is offline   Reply With Quote
Old 01-28-2013, 10:13 AM   #37
camguynj
camguynj's Avatar
To get to the fuse box were you able to lift up the passenger side carpet panel (after removing rivets & net fasteners) without having to lift up the carpet panel under the trunk latch?
Performance:
Appearance:
Old 01-28-2013, 10:13 AM   #38
FINALLYSATISFIED
Est.1775
Oh, ok. I'll take a pic of that area to include in the DIY.
Old 01-28-2013, 10:24 AM   #39
camguynj
camguynj's Avatar
I've seen pic's of it in the other post. I just want to know did you have to remove the deck lid seal just enough to pull the trunk latch carpet panel up and out in order to lift the passenger side carpet panel ?
Performance:
Appearance:
Old 01-28-2013, 11:24 AM   #40
FINALLYSATISFIED
Est.1775
I didn't have to remove a seal. Just had to pull the carpet down from the fastener on the top of the truck.
It took literally 5mins for everything.
Old 01-28-2013, 11:54 AM   #41
camguynj
camguynj's Avatar
Good, thanks for clarifying as I really wasn't looking forward to lifting up the trunk seal. Thanks again for the quick replies.
I'm an ole muscle car driver from back in the day ...prior vehicles: new '66 GTO, new '66 442 (everybody who didn't go to college had em)... I went at nite after being drafted. Now that I'm retired I got myself a new one again. 6 speed 426HP with Hurst short shifter with CAGS eliminator,NPP and aqua LED inside & underneath. I'm 18 again! Really helps to have the forum with guys like you sharing.
Performance:
Appearance:
Old 01-28-2013, 01:26 PM   #42
FINALLYSATISFIED
Est.1775
No problem! This site has helped me in sooo many ways the least I can do is put a DIY up for this. I didn't see anyone who had one so I snapped a few pics and wrote one up. I tried to be as detailed as possible. Hope it helps!
