Old 01-04-2013, 02:24 PM   #1
Blackandwhite
Blackandwhite's Avatar
Drives: 2015 Camaro ZL1
Question Replica SS rims on My LS
Hey guys,
I have a 2012 LS camaro, obviously v6. I need help because i'm really not a genius when it comes to upgrades but i always research and think everything though. The rims i want are very cheap and very nice looking. I'm tired of the unappealing heavy stock rims on the new LS's. Here's the info for the rims. 20x9" 5x120 with a 35mm offset i believe. Not too positive. Now i think i remember reading for a LS, the front rims are 40mm and the rear rims are 50mm offset? Yet again, not positive. So how would i make that work out with the rims? Also, just to be sure what size tires would i need? my stock tires are P245/55R18. I tried compatibility matches and it said 265/40/20. If that's right, what are the best tires i should get? Please try to explain it as simple as possible, as i'm only 19 right now but i'm a proud lover of my v6 that i have bought all by myself, no help. I'm also planning on getting SLP loudmouth 2's on it soon but, one upgrade at a time
Blackandwhite is offline   Reply With Quote
Old 01-04-2013, 02:40 PM   #2
GEEKFREEKSCOTTY
Autoboticus Roboticus
GEEKFREEKSCOTTY's Avatar
Drives: 2011 Camaro 2SS/RS
on that 20", you are looking at 275/40/20 on all corners. The added benefit is additional cornering stability as well as you can do a normal tire rotation.
GEEKFREEKSCOTTY is offline   Reply With Quote
Old 01-04-2013, 02:48 PM   #3
Blackandwhite
Alright so it's better like that? and the tires won't be too big?
Old 01-04-2013, 02:49 PM   #4
plus1zero
Back in a V8 ;)
plus1zero's Avatar
Drives: 2013 F-150 5.0 4X4 Screw PAST 2LTRS
I love having the RS 20's on my 2LT, I think they're better looking. I also have a love/hate relationship with the tires being bigger in the back. You can't rotate them, which sucks.
plus1zero is offline   Reply With Quote
Old 01-04-2013, 02:57 PM   #5
Deke736
COTW 12/3/12
Deke736's Avatar
Drives: 2012 Ashen Gray ZL1
The SS comes with a 245/45/20 on the front on a 20x8.0 wheel and a 275/40/20 on the rear on a 20x9.0 wheel. I would think that if all 4 of your tires are 20x9.0 you should go with the 275/40/20 that comes stock as GEEKFREAKSCOTTY mentions above.
Deke736 is offline   Reply With Quote
Old 01-04-2013, 03:00 PM   #6
daveagogo1
TRI COUNTY TAMPA
daveagogo1's Avatar
Drives: 2011 1SS/RS VR/BLK A6
For the cost of the "cheap" rims and 4 new rear tires. You might be better ahead just buying a set of OEM takeoffs in the F/S section. Unless you really want 9" fronts
Originally Posted by HufferSS View Post
Fast cars have rubber on the quarter panels...you sissies need to knock it off.
daveagogo1 is offline   Reply With Quote
Old 01-04-2013, 03:07 PM   #7
Blackandwhite
Well the LS has 245/55 front and back. and the rims are 18x7.5. So if i got 275/40 with 20x9 in all 4 corners it would be fine? Would the front and back offset when they're being put on matter? and i know it might be a little expensive but i pretty much like these rims. As annoying as it is to change tire size as well, i think it'll be worth it. The only thing that sucks is that the tires are new.
Old 01-04-2013, 04:10 PM   #8
Blackandwhite
So i think it's settled on getting 275/40 all around with the 20x9 rims but i'm still worried about how i need to do the offsets.
Old 01-04-2013, 04:17 PM   #9
Deke736
COTW 12/3/12
Deke736's Avatar
I don't know how much you are going to pay for your replica rims and tires, but here's a set for sale in the marketplace for a great price and you don't have to worry about offsets.
http://www.camaro5.com/forums/showthread.php?t=236539
There are also several other threads with OEM SS wheels and tires listed.
Old 01-04-2013, 04:18 PM   #10
SimpleGreen
Drives: 2013 1SS/1LE IOM
If I recall, 20x9 with a 34mm+ offset is what you are looking for with those tires.
You can run factory take offs but you can't do a normal tire rotation. Personally, that's important to me, so I opted to use the same wheels and tires all around when/if I ever upgrade to 20s.
2016 Jeep Wrangler Willys 2DR
2013 Camaro SS/1LE SOLD 4/27/16
SimpleGreen is offline   Reply With Quote
Old 01-04-2013, 04:22 PM   #11
Blackandwhite
These are the rims i want to help out. http://www.discounttiredirect.com/di...w=9&vid=020773
That other post is a nice price and that's low mileage but the thing is, this is a brand new camaro, 3k miles on it and i'm the first owner. So everything is pretty much brand new, so i'd rather spend the extra money on new everything. So I guess 275/40 all around would work for full tire rotations and the rims would fit without any problems, and if its 34+mm offset, if i get the put on at a shop will they do the offsets right?
Old 01-04-2013, 04:28 PM   #12
Deke736
COTW 12/3/12
Deke736's Avatar
That other post is a nice price and that's low mileage but the thing is, this is a brand now camaro, 3k miles on it and i'm the first owner. So everything is pretty much brand new, so i'd rather spend the extra money on new everything. So I guess 275/40 all around would work for full tire rotations and the rims would fit without any problems, and if its 34+mm offset, if i get the put on at a shop will they do the offsets right?
Yeah, that link is helpful. Those are nice looking wheels, I love the dark finish (but I am biased). I also know a little bit about brand new Camaros and wanting everything new for it (I've bought 2 in the last 12 months), so I understand your thought process.
I'd go with 275/40/20's all around and be done with it. I would think a 34+mm offset should be fine. If you are still not sure, why don't you create a thread in the Wheels&Tire section of the forum, you might have some more luck over there.
Old 01-04-2013, 04:28 PM   #13
SimpleGreen
You have to buy the wheel with the correct offset built into it
If you are buying a replica SS wheel however, that isn't likely to be an issue.
Old 01-04-2013, 04:31 PM   #14
Mooch
Drives: 2010 camaro
This. I just bought a set of four factory SS 20's with tires, polished 5 spoke off Craigslist for $600. That was a steal, but there are plenty in the 1,000 range, with very good rubber.
Mooch is offline   Reply With Quote
confused, offset, rims, tires
