Cold Air Inductions
Old 01-04-2013, 06:42 PM   #1
stickystuff
stickystuff's Avatar
Drives: 1LE ordered
Camaro letters/logo
Can you remove the camaro lettering on the front quarter panals?
stickystuff is offline   Reply With Quote
Old 01-04-2013, 06:45 PM   #2
OzzySS
OzzySS's Avatar
Drives: 2013 2SS/1LE, 2004 Cavalier
yep. same way as with most badges - heat it up a bit, then slide some floss under it. a little paint-safe adhesive remover, and you're done. there's some other methods, but all the same idea
OzzySS is offline   Reply With Quote
Old 01-05-2013, 12:09 AM   #3
ST1LE
ST1LE's Avatar
Drives: E92 BMW M3
I used a heat gun to heat the up a bit, be careful they can melt pretty easy. Then I used a handle thing with a removable plastic razor blade I bought from autozone. Worked great!!
SOLD - 2013 1LE - Pat G Spec'd Cam, NPP with 1 7/8" Long Tube Headers with High Flow Cats, Intake w/scoop, Ported Throttle Body, and Apex 1.25" Lowering Springs.
J-Rod Built and Matt@FSP Tuned
ST1LE is offline   Reply With Quote
