Old 01-06-2013, 01:34 PM   #1
inferno camaro
inferno camaro's Avatar
Drives: 2010 camaro pace car, 2008 cts bl,
stall converter comparison
Is there any advantage having a multi disc coverter compared to single disc. I have a precision industries single disc and I'm pulling it to get it loosened up. There is an fti multi disc for sale in the rpm I want. My question is get my free reflash or go with the multi disc and sell mine?
Mods, 2r max cam, ls3 conv,kooks lt w/hf cats,kooks street sleeper cat back with magnaflow res x-pipe, roto fab cai, v-max TB, vigilante 3700 stall, 3.70 LPE, 442hp/392tq, Mike Norris Tune 11.71@116.24 1.63 60' m&h DR's
inferno camaro is offline   Reply With Quote
Old 01-06-2013, 01:39 PM   #2
Rhino79
Rhino79's Avatar
Drives: 2010 Camaro SS L99/Auto
Only benefit would be wot lockup. this is more popular on nitrous and boosted setups, but if your gearing was where you could lock it and carry say 3rd out without having to hit 4th, then it would help et. on a naturally aspirated setup.
GM LSX parts, builds, and calibration. Home of some of the fastest LS powered vehicles in the world!
shop.gwatneyperformance.com ryan@gogwatney.com josh@gogwatney.com aaron@gogwatney.com
Rhino79 is offline   Reply With Quote
Old 01-06-2013, 01:39 PM   #3
Rhino79
Rhino79's Avatar
Edit, you have 3.70s. what rpm are you in 4th at crossing the traps??
Old 01-06-2013, 01:51 PM   #4
inferno camaro
I don't have any way to log it but by the tach 6-6100 roughly.
Old 01-06-2013, 01:58 PM   #5
inferno camaro
What is the best way to log this info? Will a tuner log this info, if so can I also thange my shift points with it?
I don't feel like I'm running it quit as high as I could before shifting. I don't know if it would make any et diff or not but would like to experiment with it.
Old 01-06-2013, 02:19 PM   #6
Rhino79
Rhino79's Avatar
Yes a nice tuning suite like efilive or hp has awesome datalogging and tuning capabilities. If your tuner uses either he could work with you remotely if you had whatever he uses.
Old 01-06-2013, 02:31 PM   #7
inferno camaro
He used hp to tune my car, so what would you suggest. Are you talking hand held when you say suite.
I'm still a newb to this electronic tuning thing.
Old 01-06-2013, 02:36 PM   #8
Rhino79
Rhino79's Avatar
Hp isn't a handheld and can have a steep learning curve. Is your tuner available to log at the track with you? What rpm did it pek hp at. Do you have a graph?
Old 01-06-2013, 03:10 PM   #9
inferno camaro
I'm 2 hours from my tuner and don't get down to his area very often. I tried at the fest last year but he was super busy,but he did make some shift point changes at my request. I was shifting into 5th before the 1/4 so it was shifting way to early since I'm only at 6000 in fourth. So my guess is it may be shifting the rest of the gears to soon but not sure of that. I could probaly meet him some other time at lucas oil to do some fine tuning. camaro
iTrader Rating: 4 reviews, 100%
OK here is mine. Seems kind of low to me, what do you think. Mods are kooks lt headers, hf cats, ls3 conv, rotofab cai, 2r cam, 235/242 608/613 114 lsa, 3000 stall.
Old 01-06-2013, 04:32 PM   #10
Pro Stock John
Writer
Pro Stock John's Avatar
Drives: 2010 SS / 1951 Mercury
I would check over your shift points, plus your cam is still pulling up there. You shouldn't be shifting into 5th with your cam, gear, and overall combo. Sometimes you have to go over tunes and adjust one or two things, not a big deal.
Triple disc can be locked more, and would work better for a blower combo.
PROJECT HEAVY CHEVY
13.15@106 1.95 | 100% Stock
Old 01-06-2013, 04:45 PM   #11
inferno camaro
So sounds like I should just get my free reflash and reinstall mine then . When we kept it in 4th gear it picked up .4 and 4 mph.
I would really like to have something to data log and adjust shift points and other little things.
Old 01-06-2013, 05:43 PM   #12
jrpxxii
jrpxxii's Avatar
If you are going to drive your car on the street much I would get a triple disc with lockup but if its mainly a track car I would run a single disc with no lockup
Old 01-06-2013, 05:56 PM   #13
inferno camaro
Its mainly a street that will see the track half a dozen or so times per year. Whats the advantage of the triple disc? I only put about 3000 miles a year on it and not concerned with mileage or stuff like that.
Old 01-06-2013, 06:09 PM   #14
Rhino79
Rhino79's Avatar
What rpm does it shift? Is say it needs to shift about 6600 to 6800 and you only want it drop to 5200-5500 on the shift.
