BORLA
Old 01-06-2013, 08:11 PM   #1
racer3j
Drives: 2011 Camaro RS
Supercharger or Nitrous
Was dead set on getting a supercharger but the investment has me scared a little bit . Now after looking into a Nitrous kit is starting to look like a good option. Could some people with both set ups weight in and give me some insight on what both options have to offer. Having a lot of trouble making up my mind, so any help would be appreciated. Thanks in advance.
Summit White 2011 2LT RS Camaro. K&N Cold air intake, Magnaflow cat back exhaust, Black out kit.
racer3j is offline   Reply With Quote
Old 01-07-2013, 04:32 AM   #2
lscamaro
lscamaro's Avatar
Drives: 2011 CGM Camaro LS A6
The obvious reason most are gonna give you is that nitrous can only be used on a race track and you can have a supercharger all the time. But I'm looking at nitrous as well just because of how much hp/$ you get.
Old 01-07-2013, 08:25 AM   #3
sycraft
COTW 5/06/2013
sycraft's Avatar
Whats the cost of Nitrous refills, could equal a payment on a SC system....
Old 01-07-2013, 12:12 PM   #4
DarkneSS
Drives: 2010 Camaro 2SS/RS 6MT
~$50-75 depending on where you live. That is for a 10 pound bottle. That amount would last you something like 40-60 seconds from experience maybe a little more. You will probably spray for like 8-10 seconds per 1/4 pass so figure you can get a solid 6 passes out of a 10lb bottle.
So even if you went to the track 4-5 times a year you would still save a ton of $ using nitrous.
DarkneSS is offline   Reply With Quote
Old 01-07-2013, 01:32 PM   #5
lscamaro
lscamaro's Avatar
Refills are usually only 50-75 dollars a bottle. If he doesnt go to the track often, he could go through a bunch of nitrous bottles before its even close to the price of a supercharger. Then theres the point of being able to get more power out of the bottle than the supercharger.
Old 01-07-2013, 01:33 PM   #6
Neal@NitrousOutlet.com
Drives: The Blue Vert
It does take a lot of nitrous fills to get up into the price range of a supercharger. Even if you pay 1600 for your nitrous system.
Like said before superchargers do give you that all the time performance. Depending on how much you spray, nitrous sometimes doesn't require upgrading your fuel pump. If anything you have to get a boost-a-pump like with the supercharger. It wouldn't need injectors if it was a wet kit as well so you will save some money there.
Both are great you just have to decide what is best for you.
Neal@NitrousOutlet.com is offline   Reply With Quote
Old 01-07-2013, 03:42 PM   #7
scrming
Red Brick of Vengeance!
scrming's Avatar
Drives: 12 Second Brick
Love the rush of the instant torque of N2O!!!
scrming is offline   Reply With Quote
Old 01-07-2013, 06:19 PM   #8
SC2150
I would have to agree.....a 100 wet shot used only when needed, not every time you want to play, would be the most economical and Nitrous Outlet has an excellent system.
Old 01-07-2013, 06:26 PM   #9
lexlueger
lexlueger's Avatar
Drives: V10 BMW M5, Supercharged 2SS/RS
BOTH!
MAST 416 STROKER: STAGE 3 TVS 2300
CUSTOM CAM
TPIS 102 TB
IW 8 RIB PULLEY W/ OD COG REARS
NX EXPRESS/NANO KIT
KDI HEAT EXCHANGER/ROTOFAB RESERVOIR
CIRCLE D 2800 TC/FLEX PLATE/ADM TRANS COOLER
DSS DRIVESHAFT/1400 HP AXLES
EATON TRUETRAC -LPE 3.27 GEARS
DYNATECH HEADERS/MAGNAFLOW EXHAUST
SQUASH RETURN STYLE FS ID 850's E85/ FLEXFUEL
BMR/EIBACH SUSPENSION
KILL MODE, ON.
lexlueger is offline   Reply With Quote
Old 01-07-2013, 06:49 PM   #10
Sikoriko
Sikoriko's Avatar
Drives: 2011 V6 IOM
Just hope 100 is plenty for him. Some get the itch and want more. Then its off to J__'s for a crate 682cu 820hp big block
Old 01-07-2013, 06:51 PM   #11
GretchenGotGrowl
GretchenGotGrowl's Avatar
Drives: 11 F150 EB/13 Sonic RS/15 Z06
Nothing wrong with that. We all aspire to bigger things.
New Ride -- 2015 Z06 2LZ (stock) -- Journal
Old Ride -- 2012 Camaro 2LT/RS (647 RWHP & 726 RWTQ) -- Build Thread
GretchenGotGrowl is offline   Reply With Quote
Old 01-07-2013, 10:53 PM   #12
CiscoBee
Drives: 2010 Camaro Rally Yellow 2LT
Been having lots of fun with my Ny-Trex Triple Threat NOS System!!! Running a 100 shot currently but will be increasing that to 125 & 150 to see how it does at the track.
Refills are less than $50 and under $1000 for the system.
CiscoBee is offline   Reply With Quote
Old 01-07-2013, 11:27 PM   #13
MaxKamai
Mad Ninja Skills
MaxKamai's Avatar
Drives: 2011 Camaro SS/RS M6
Nitrous is hard to beat dollar for dollar. Relatively cheap initial investment, easy to install, great power, easily upgradeable with engine mods, and no power loss from heat soak. I ran the ZEX kit on my V6 and I'm still using the same kit on my SS. Superchargers are great too,and with a centri heat soak isn't that bad, but you have a much much larger initial hit to the wallet.
2011 Camaro SS/RS M6 - 633whp/679tq Gave to the wife
Custom stainless 2" primary headers / Custom stainless 3" header back exhaust / Hurst short shifter / ZEX nitrous kit / Vararam intake / Spohn chrome moly trailing arms / Sin City Performance Tune / SCP custom ground cam / SCP ported & polished heads
New Car 2007 Corvette Z06 - Headers / Vararam / Magnaflow Catback / SCP Tune / Nitrous / BTR Stg IV Cam and Springs
MaxKamai is offline   Reply With Quote
Old 01-08-2013, 11:56 PM   #14
simt3k
Drives: 2011 Camaro RS 2LT
Why not go both?
simt3k is offline   Reply With Quote
