BeckyD @ James Martin Chevy
Old 01-07-2013, 03:57 PM   #1
Mikamaro
MikeNoMaro
Mikamaro's Avatar
Drives: A 2016 Challenger R/T M6 STP
GM performance Availability for Track pack?
HI,
Does anyone knows when and where will the track pack will be on sale?
PART NUMBER # 23102311
(I'm not taking about the individual parts already available)
Track Day Videos: http://www.youtube.com/user/mrgoodman2000/videos
Built #83817, Born January 18th, Christened June 11th 2010, Stolen October 3rd 2016.
Mikamaro is offline   Reply With Quote
Old 01-07-2013, 04:22 PM   #2
slick rick
SoCal Mayhem
slick rick's Avatar
Drives: 2010 Camaro 1SS/RS
Subscribed
Old 01-07-2013, 04:59 PM   #3
scubadoo7
Airborne Recondo
scubadoo7's Avatar
Drives: Crystal Red 2SS 1LE
I have the 2013 performance catolog, and you have the correct parts #. Did you call parts at your dealership? I would think you could order now.
scubadoo7 is offline   Reply With Quote
Old 01-07-2013, 06:32 PM   #4
Mikamaro
MikeNoMaro
Mikamaro's Avatar
Both guys from PArtsTaxi.com and craneenginedepot.com have told me they are expecting it by the end of the first Quarter...so any day now!
Old 01-07-2013, 10:42 PM   #5
Mikamaro
MikeNoMaro
Mikamaro's Avatar
I will put together the first group buy for this package, leave your name if you are in..
Old 01-07-2013, 10:44 PM   #6
sycraft
COTW 5/06/2013
sycraft's Avatar
That part number is not a valid number, the catalog has some part number problems. You can order all the individual parts now, not sure is the kit will be available as a single part number.
Old 01-08-2013, 12:03 AM   #7
Mikamaro
MikeNoMaro
Mikamaro's Avatar
Not valid? Number problem? Hummm...where did you get this information?
Some parts listed from the kit in the catalog are not yet available individualy either.
Old 01-08-2013, 10:18 AM   #8
tramtwo
tramtwo's Avatar
Drives: 2013 1LE
Probably could get better results cheaper with an aftermarket suspension setup. Remember the 1le performance is more than just wheels and shocks...
tramtwo is offline   Reply With Quote
Old 01-08-2013, 06:04 PM   #9
GraySS2011
GraySS2011's Avatar
Drives: 2011 Cyber Gray 2SS 6 speed
Only the 3:91:1
and the exhaust. The LS3 is the same as the SS.
2011 2SS RSS , MN6, CGM
http://www.angelfire.com/hi/nicecorvette <----- My Cars and Trucks
GraySS2011 is offline   Reply With Quote
Old 01-08-2013, 07:38 PM   #10
edgehead2000
2016 Camaro 1LT 2.0T
edgehead2000's Avatar
Drives: Nemesis
So, what's suppose to be included in the track pack? $3500, correct?
edgehead2000 is offline   Reply With Quote
Old 01-08-2013, 07:51 PM   #11
newb
newb's Avatar
Drives: 2013 1LE
Already answered several times over.
http://www.camaro5.com/forums/showpost.php?p=4707707
But the transmission is the only not "available" as a retrofit
Sent from a rainbow while riding a unicorn
It's a Dingledarm. It's there to dampen side fumbling. If your marzelvanes fumble too much they can cause total protonic reversal. It gets ugly from there. This is really the biggest problem with the new Camaro. That and the tri-pronged blivot.
Delivered 21 Jan 2013
newb is offline   Reply With Quote
Old 01-08-2013, 09:18 PM   #12
edgehead2000
Drives: Nemesis
Ok. Wheels & tires too?
It just seems like a long-shot that GM would also include the wheels & tires, which alone are at least $3k, with the suspension parts in a bundled pack for $3500. Judging by our current economy and GM, you'd think that they'd want to make more money by forcing you to piece the package together.
Old 01-08-2013, 09:33 PM   #13
slick rick
SoCal Mayhem
slick rick's Avatar
$3,500 is if you get the 1LE package from factory.
Track Pack is this
Camaro 1LE Track Pack NEW 231023311
Give your 2010+ Camaro SS or Camaro V6 greater capability in curves with
the same suspension components used in the production 1LE performance package. Contents include a larger, 27-mm solid front stabilizer bar, and 28-mm solid rear stabilizer bar for improved body control, as well as ZL1 wheel bearings, toe links and rear shock mounts for improved on-track performance.
the system includes:
part number Detail Qty
22812942 Front Stab Bar Asm (bar, links, bushing, clamp, nut) 1
22786260 Rear Stab Bar Asm (bar, bushing, clamp, bolt) 1
22761221 Rear Stab Bar Link 1
22812982 Front Strut Asm, LH (strut, spring, mount) 1
22812983 Front Strut Asm, RH (strut, spring, mount) 2
22981391 Rear Shock 4
22922445 Rear Shock Mount, LH 4
22922446 Rear Shock Mount, RH 4
22845487 Rear Toe Link 4
20941932 Rear Cradle Bushing, Front 4
20941933 Rear Cradle Bushing, Rear 4
23102312 Installation Instructions 4
Check out the GMPP catalog
http://www.camaro5.com/forums/showthread.php?t=258441
Old 01-08-2013, 09:39 PM   #14
newb
newb's Avatar
Drives: 2013 1LE
It's $3500 from the factory including the transmission as an RPO. To build one or retrofit your current car will cost considerably more. No one (to my knowledge) has a price for the suspension package although many of the pieces are available. So currently, you can almost piece one together but it will be more than $3500 and you still won't have the transmission. To add the wheels will easily push to over $4k. I think you can stay well under $3500 for suspension and rear gears.
