Gen5DIY
Old 01-08-2013, 01:57 PM   #1
KalCorp
Space Coast Camaros
KalCorp's Avatar
Drives: 2012 Camaro Vert
What to look for in Data Log?
V6 LLT
Did a quick WOT datalog with my EZFlash. and just checking it out with Data Log Visualizer
What do i want to look for to see if there is anything that can be improved?
Using 93oct Gas and reset ECU before run
Just some info i noted:
Ambient Air Temp- AAT@73.4
Log frame 35 1 Gear RPM 651.75 @ 0mph Intake Air Temp@98.6 - Knock Retard: 0
Log frame 76 1 Gear RPM up to 6349.25 @ 45.98mph Intake Air Temp@91.4 - Knock Retard: 2.988281
Log frame 113 2 Gear RPM up to 6891.25 @ 72.70mph Intake Air Temp@86 - Knock Retard: 2.988281
Log frame 189 3 Gear RPM up to 6395.25 @ 105.01mph Intake Air Temp@86 - Knock Retard: 2.197266
Log frame 200 3 Gear RPM 3733.5 @ 103.14mph Intake Air Temp@86 - Knock Retard: 0
Here is a log in CVS format
http://floridacamaroclubs.is-into-ca...ile.php?id=146
KalCorp is offline   Reply With Quote
Old 01-08-2013, 08:23 PM   #2
2SSCAMARO
2SSCAMARO's Avatar
Drives: 2010 Camaro Auto
The biggest thing that stands out is your are getting a ton of knock retard. You either found the worst gas station in your state or something is triggering the knock sensors like exhaust hitting the cross member. The ecm should not have to pull timing like that.
2SSCAMARO is offline   Reply With Quote
Old 01-08-2013, 09:48 PM   #3
KalCorp
Space Coast Camaros
KalCorp's Avatar
Thanks i will look into this.
Would be nice to see a log from someone else :-)
Should there just be no Knock? or just a little on WOT? whats the common for everyone ?
The WOT run was from 30 to 200
Old 01-08-2013, 10:07 PM   #4
Supercharged SS
Drives: 2010 Camaro
But from what i can see the timing advance is not changed because of the Knock retard. Or a, I just looking at this wrong.
Should there just be no Knock? or just a little on WOT? whats the common for everyone?
I don't have a log handy on my phone but other than a very very tiny knock ( burst knock)on the launch my car has zero knock on a 9.8 pass. One thing that helps is I run a full tank of 104 octane but I also run 16+ psi and nitrous.
Old 01-08-2013, 10:27 PM   #5
KalCorp
Space Coast Camaros
KalCorp's Avatar
Remember this is a LLT V6 don't know if it is different.
I only had 93 octane from normal Florida pump maybe i will try something better and see if it helps.
But i just checked a normal drive around data Log with no WOT. But i was getting on it some and it has 0 Knock. I would think if it was anything hitting something i would see it in normal driving also. Or maybe it only hits when i am in WOT?
IDK :-(
Old 01-08-2013, 10:39 PM   #6
Supercharged SS
Drives: 2010 Camaro
IDK :-(
My bad. I'm retarded!! I need to start reading what category I'm in.
Could be false knock caused by anything. I had the converter bolts loosen up and start banging and it was getting serious knock. Happened to be going into the semi final of the camaro fest but that's racing. If it looks like a lot of knock its prob false. Could def only hit only wot.
Old 01-17-2013, 02:04 PM   #7
KalCorp
Space Coast Camaros
KalCorp's Avatar
OK got my response back from sending in my DataLog
"We've reviewed the log and it looks absolutely spot on. Infact, this is one of the strongest running LLT cars we've seen a log from. Whoever made those comments about the timing doesn't have any experience with tuning LLT Camaros. They have a "Ton of knock retard" even on the stock tune- this is due to the way GM calibrated how knock is reported"
Going to have the Dyno done and see where i stand.
Old 01-17-2013, 02:32 PM   #8
2SSCAMARO
2SSCAMARO's Avatar
Whom ever the we are in "we've reviewed the log and it looks spot on", I believe are the people who have little experience in tuning and reading a log. If you look at the CSV file provided at lines 67 to 191, you'll see as much as four and one-half degrees of timing being pulled. If the ecm had been tuned by a tuner instead of a tooner, there would not be a single degree of retard except for perhaps a small brief amount of burst knock at launch. If you want to see what a WOT 1/4 mile log with not even one degree of retard looks like, let me know and I'll show you some.
Old 01-17-2013, 09:49 PM   #9
rberns
rberns's Avatar
Drives: 2011 Camaro 2SS/RS
What is "knock retard"? And what kind of issues could arise if left untreated?
2011 Camaro 2SS/RS, Circle D 3200, ADM Transmission Cooler, BTR Valvetrain, Cam Motion .621 .595 228/244 113+4, ARH 1 7/8, Cold Air Inductions, Katech C5R TC, Melling HV, BTR SLR lifters, Trunion Upgrade, LS2 Dampner, LS9 head gaskets, Bo White PTB, RX CC, GFX, Subs.
rberns is offline   Reply With Quote
Old 01-17-2013, 09:50 PM   #10
The Stig
knows 2 facts about ducks
The Stig's Avatar
Knock retard = ECM pulling timing = car performs worse than it should.
Click to view my build thread
Old 02-08-2013, 03:57 PM   #11
KalCorp
Space Coast Camaros
KalCorp's Avatar
I would agree if we where talking about a V8. However if you read the post we are not.
And the "WE" was "Trifecta" you know the ones that made the tune in the first place. I take it you dont have a LLT or LFX?
And even after the Dyno the car did very well. its listed in the mid to top spots for the mod's that i have. And the dyno even made the Knock 2 times worse up to 8 degrees! The same issues most everyone else is getting with these LLT/LFX Camaros!
Old 02-08-2013, 06:19 PM   #12
2SSCAMARO
2SSCAMARO's Avatar
No, mine is not a six cylinder but I would ask this question....Whether it's a four, six, eight, or ten cylinder, if the ECM is going to pull four to eight degrees of timing when you go WOT, what benefit is there to have the excess advance timing in the tune if the ECM is only going to remove it. I still suggest that if the fueling and timing is correct, the ECM will not pull that much timing. Perhaps some of the professional tuners on the forum can comment.
Old 02-08-2013, 06:33 PM   #13
KalCorp
Space Coast Camaros
KalCorp's Avatar
There are reports of it going 10+. And alot of people tuning these V6's have seen false knock on a near factory vehicle and on supercharged ones.
It s big issue they are still trying to work out.
I am hoping soon, people working with the knock sensor charts, by logging and analyzing data (Not just removing them!!) They can scale back the knock sensors to allow for resonance due to modifications that may set off factory sensors (Such as headers, superchargers, etc.). - Thanks Matt@FSP for some of that!
Old 02-08-2013, 10:39 PM   #14
Tampa Tuning
Drives: TAMPA TUNING FACEBOOK & INSTAGRAM
here's a couple things I see if im reading your graph properly, but nothing crazy:
While in WOT, looks like bank 2 is pulling about 3% of fuel and bank 1 isn't. If they were both pulling fuel, Id like the picture of information better.
Most of the time being + or - is carried over from the overall LTFT being slight off. Since they are not even, you may have a slight intrusion of unmetered air on the bank 2 side. That can be a little leak from the exhaust. I can live with the bank 1 numbers.
Looks like you have 1-3 degrees of KR (General). I like to remove knock before it occurs not where it occurs. Id remove 1 degree in the predicated G/CYL vs RPM area to see if it removes the rest of the KR in the affected area. Easier to do with a vehicle on 93 octane than 87. Most guys in V6 use 87 octane and its a PITA to calibrate the spark tables.
Its not clear why the RPMs drop from 6349 to 4416 and your MAF Hz withdrew lower while still in WOT. Looks like the pedal is still to the metal, but torque management is reducing performance.
Being a V6, there has been some reported calibration problems while your committed to 100 % throttle, the ECM didn't commit.
Really nothing crazy off, just a couple things I saw.
You can gain more HP and add more timing if you numb your knock sensors. Ill take the lower number, and keep the car safer.
Tampa Tuning is offline   Reply With Quote
