Old 01-08-2013, 07:11 PM   #1
2012REDSS
Drives: 2012 Camaro SS
SCT Firmware 1.2.137.03 whos can email it to me?
Just like the title states who has the firmware and can someone email it to me? I cant finish datalogging my car for ted because the pids keep failing. After searching this seems to be the fix.
2012REDSS is offline   Reply With Quote
Old 01-08-2013, 07:17 PM   #2
grocerygetter
instigator
grocerygetter's Avatar
I haven't done any updates because my shiz has worked since late 2011. LOL. I don't plan on doing any either unless Ted says I have to.
-John S.
Thanks to:
Tony@ dv8motoring
TCAudio in Benton AR
Old 01-08-2013, 07:24 PM   #3
2012REDSS
I dunno if its the livelink II messing it up or what but every time I try to log the pids fail or most fail. I even loaded the pids I wanted to log on the sct itself and did two logs but when I tried to pull them off livelink II says no logs. This install has been a major pita.
Old 01-08-2013, 07:42 PM   #4
2SSCAMARO
2SSCAMARO's Avatar
Drives: 2010 Camaro Auto
http://www.sctflash.com/showdeviceup...0&DTYPE=&DTYPE=
The latest downloads are available here. Make sure you return your vehicle to stock BEFORE changing firmware or you will experience an even bigger PITA than you have thus far.
2SSCAMARO is offline   Reply With Quote
Old 01-08-2013, 07:47 PM   #5
2012REDSS
yea its returned to stock. Does it matter that I have a 3416 not 3400 SCT?
Old 01-08-2013, 07:49 PM   #6
2012REDSS
auto update says I'm up to date but I'm still on the 1.2.136 firmware WTF?
Old 01-08-2013, 07:52 PM   #7
2SSCAMARO
2SSCAMARO's Avatar
http://www.sctflash.com/showdeviceup...6&DTYPE=&DTYPE=
Here is the 3416
Old 01-08-2013, 07:54 PM   #8
2012REDSS
tried that too up to date but if you notice the firmware hasnt been updated since 2011.
Old 01-08-2013, 07:55 PM   #9
2SSCAMARO
2SSCAMARO's Avatar
Are you running the 2.9.8.45 updater software?
Old 01-08-2013, 07:57 PM   #10
2012REDSS
yep
Old 01-08-2013, 08:06 PM   #11
2SSCAMARO
2SSCAMARO's Avatar
The 3416 is loaded with "canned" tunes from SCT whereas the 3400 is strictly custom tunes. It looks like the version 2.136 is the latest version for the 3416. Maybe there was a misunderstanding regarding the 2.137 version being applicable to the 3416 model.
Old 01-08-2013, 08:09 PM   #12
DarkCry956
DarkCry956's Avatar
Drives: 2011 Camaro 2SS/RS
I had a hard time with live link as well. I spend hours on the phone with SCT and they told me I was good to go. They were wrong. I had to stay on the phone with them while they took over my laptop remotely and finally got it to work after a long time. Even then it I still had trouble getting all the PIDs Ted asks for and some failed while data logging. It was a PITA!!! After many attempts I was able to get it working enough for the logs. It's random now. Sometimes they work sometimes they don't. Call SCT and let them do whatever it takes. That was my only solution.
DarkCry956 is offline   Reply With Quote
Old 01-08-2013, 08:10 PM   #13
DarkCry956
DarkCry956's Avatar
I have 3400. Ted and SCT told me only some camaros have this problem not all.
Old 01-08-2013, 08:33 PM   #14
2012REDSS
yea I assumed we all had 3416s when I went to the sct site and looked up my car and thats the model it came up with. I guess I'll try calling SCT tomorrow afternoon. If they cant fix it looks like I'll be out another 600 for a dyno tune. FML
